Old 06-16-2020, 01:21 AM   #1
SoCalSlaughter
SoCalSlaughter's Avatar
89 S10 4.3 misfire
What do think of these readings??
Cyl 1 - 130 - Wet 140
Cyl 2 - 135 - Wet 155
Cyl 3 - 120 - Wet 130
Cyl 4 - 150 - Wet 160
Cyl 5 - 140 - Wet 150
Cyl 6 - 125 - Wet 130
1990 Chevy Suburban v2500
1990 Chevy/Geo Tracker LSi 4x4 2Dr
1996 Chevy/Geo Tracker LSI 4x4 4Dr
2011 Chevy Silverado Crew Cab LT
1991 Nissan 300zx SlickTop
SoCalSlaughter is offline   Reply With Quote
Old 06-16-2020, 07:49 AM   #2
AussieinNC
Moderator
AussieinNC's Avatar
Re: 89 S10 4.3 misfire
IMHO
These readings are indicative of a well used engine...
The variance between dry and wet are about standard, with the exception of cyl 2 which has some ring sealing issues.
Cyl 4 is the only one with a reasonable result....
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 06-16-2020, 11:08 AM   #3
truckster
truckster's Avatar
They're probably not directly related to your misfire. While some of them are low, early gasoline engines ran with 5:1 compression ratios.
However, as Aussie said, #2 readings indicate you may have some blow-by, causing spark plug fouling. How does that plug look?
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 06-16-2020, 06:07 PM   #4
SoCalSlaughter
We have pulled the plugs and none of them stuck out from another. All looked fairly normal. No smoke from the tail pipe. We have changed the plugs and wires a few days ago. We did notice, after starting the truck a few minutes after running, the exhaust smells like raw fuel. The hard misfire is only present at idle, and moving from a stop. The truck can cruse on freeway going 70mph no problem. We have found a good used (Compression tested) engine a county over with 98k miles for $450. Might be way to go
Old 06-16-2020, 08:40 PM   #5
vince1
I put quite a few hundred thousand kms on those. I think I changed at least three coils on the 90. One quit in the intersection and I had it changed before AMA arrived. They don't always quit outright. Keep a spare.
vince1 is offline   Reply With Quote
Old 06-16-2020, 08:47 PM   #6
SoCalSlaughter
We tried the MSD coil out of my 90 Suburban and the mis is still present
Old 06-17-2020, 06:53 PM   #7
AussieinNC
Moderator
AussieinNC's Avatar
This sounds like a leaky fuel injector...dribbling fuel into throttle body causing over rich mix flooding a plug or 2....
Grab a couple of second hand injectors from a wrecking yard and try it,,,they are not that expensive to buy new.
2012 Chevy Equinox
Old 06-18-2020, 09:13 PM   #8
SoCalSlaughter
Tried another set of injectors, problem remains. Time to get another engine.
Old 06-27-2020, 04:02 PM   #9
Wrenchbender Ret
If it has a vacuum outlet on the back part of the intake manifold, a vacuum leak can cause a misfire like that. Check power brake booster & trans modulator & a/c vacuum resavoir.
George
Wrenchbender Ret is offline   Reply With Quote
Old 06-27-2020, 05:27 PM   #10
vince1
Two of the three 4.3's I had leaked coolant into the rear left combustion chamber but you would have noticed that sooner it its life.
4.3, compression test, misfire
