Old 02-13-2020, 05:46 PM   #1
bigmoe
bigmoe's Avatar
Engine compartment done
I fired up my Gen IV 5.3 last weekend for the first time but I had to cobble together the air intake temporarily. Today the mailman brought me a 4" elbow that had long enough legs to allow me to clear the alternator. I heard the MAF likes a straight run so I centered it. My plan was always to have the top rad hose on the passenger side and the air intake to the drivers side, partly to obstruct the ECM and the associated mess of wires. I also made a block off for the big hole in the front ps of the engine cover and painted the cover with black vinyl paint to brighten it up. No deluxe heater makes for a cleaner look as well.
bigmoe is offline   Reply With Quote
Old 02-13-2020, 06:35 PM   #2
mongocanfly
mongocanfly's Avatar
Re: Engine compartment done
Very nice moe...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 02-14-2020, 01:40 PM   #3
MDPotter
MDPotter's Avatar
Looks nice and clean!
What kind of radiator did you go with? Inlet/outlet sizes? Upper and lower hose part #'s?
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 02-14-2020, 02:20 PM   #4
prodjay10
Where’d you get your intake?
prodjay10 is offline   Reply With Quote
Old 02-14-2020, 07:46 PM   #5
rsavage
rsavage's Avatar
Looks clean!
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 02-14-2020, 08:15 PM   #6
Gregski
Gregski's Avatar
looks moe bettah than factory
Gregski is offline   Reply With Quote
Old 02-16-2020, 10:49 PM   #7
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Looks great! I'm with MDPotter. I'd like to know info on your radiator, inlet/outlet sizes and hose PN's. I'm at a point where I'm trying to figure out radiator hoses for my K10 5.3L Gen III swap. Any info is greatly appreciated.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 02-17-2020, 05:52 PM   #8
bigmoe
bigmoe's Avatar
The motor is all stock 08 Tahoe 5.3.
Old 02-17-2020, 06:10 PM   #9
bigmoe
bigmoe's Avatar
The radiator is an RND Fabrication downflow. I told him it was for an LS swap and I wanted the upper on the ps and a steam hose fitting.
Upper rad hose is Gates 21970 that I had to shorten 3 1/2". 1 1/2" rad x 1 1/4" engine
Lower rad hose is Continental 61416
My motor is Gen IV. Not sure if that makes a difference for the hoses.
Old 02-18-2020, 01:47 PM   #10
bigmoe
bigmoe's Avatar
I should add that someone on here used a Continental 64143 for a top hose but for my Gen IV it was too short and too small at one end. Fits Gen III maybe?
Old 02-18-2020, 01:54 PM   #11
bigmoe
bigmoe's Avatar
Oh you mean the air intake? I just cobbled it together using an elbow, some 4" tube and a 4" filter I bought on Ebay. I had to hunt a bit to find an elbow long enough so it would clear the alternator. The Maf is stock. It's actually a bit smaller than 4". One end I was able to hose clamp down, but the other end was even smaller so I cut a plastic strip and wrapped and glued it around to bring up the diameter.
Old 07-28-2020, 01:48 PM   #12
rowdy11
I'm late to this but looks great Moe! Curious to know if you always planned to mount your ECM where it is. I've got a stock harness as well and have the same engine cover (L96) but want to route my harness and ecm either to back firewall or against the firewall in the cab.
1970 K10 Shortbed LS L96 6L90
Follow the entire mess below!
Lola: My Moon Shot
rowdy11 is offline   Reply With Quote
Old 07-28-2020, 06:34 PM   #13
bigmoe
bigmoe's Avatar
I had the stock harness thinned out but that’s the stock routing direction so I didn’t have much choice where the ECM mounted. The air filter hides it a bit. It would take a lot of work to re route a stock harness to move the ECM location but you can buy aftermarket ones that will work for what you want.
Did you notice the block off I made for the front ps of the engine cover?
