11-29-2020, 02:23 AM | #1 |
Serpentine pulley conversion question
Hey guys, I bought a serpentine belt system to convert my 327. While I was pulling everything off the donor 4.3.... I started thinking....
Do I need to grab the harmonic balancer from the 4.3? Or do I use the balancer on my 327? Is there a difference between the V8 and V6 balancer pulley’s? And if there is then should I be using the V8 pulley instead of the V6 pulley? Any help is appreciated
1965 c/10 swb 1969 c/10 lwb |
11-29-2020, 08:02 AM | #2 |
Re: Serpentine pulley conversion question
Try the 327 one first, not even sure what if any difference between a V6 and V8 balancer.
11-29-2020, 11:26 AM | #3 |
You probably already know this, but in case you don't, you'll need to get a reverse rotation water pump.
11-29-2020, 01:55 PM | #4 | |
I’m only concerned about the balancer pulleys being different from the V6 to V8. And if I need the balancer from one or the other to put on the 327.
11-29-2020, 03:43 PM | #5 |
Ok, I wasn't trying to imply anything. Just doing a quick search on Summit's site, it appears as though they are both the same, meaning you can use the balancer you have. Here, take a look;
https://www.summitracing.com/parts/a...et?prefilter=1 |
11-29-2020, 04:55 PM | #6 |
Use the balancer that belongs with the engine
11-29-2020, 10:57 PM | #7 | |
