02-27-2021, 02:05 PM | #1 |
Removing overspray on a reproduction bezel
Looking for what solvent to use to remove some overspray from a reproduction bezel - some paint got on the "chrome" and I want to try and remove it without removing the chrome as well. Any experience with this or know if acetone will be the best bet?
02-27-2021, 02:19 PM | #2 |
Re: Removing overspray on a reproduction bezel
Is the chrome metal, or plastic???
When tackling a job like this, start out with the least aggressive cleaner, possible, like window cleaner, see what happens., Leave things like paint thinner to the very end, if needed. |
02-27-2021, 02:33 PM | #3 |
I'm pretty sure the entire bezel is plastic, that's a good call - I'll work my way up and try it out on and old bezel first and see what happens.
02-27-2021, 02:39 PM | #4 |
I'd recommend trying a clay bar. If it truly is overspray, it should pull it right off. I used one to remove overspray on a van I painted in my tiny garage. Nothing would remove the overspray (even a finger nail wouldn't make it budge), but a good application, per the instructions, and it all came off without touching the paint finish underneath.
Caveat, I'm not sure what the clay bar and wax would do to a plastic chrome finish but I can't imagine it would harm it... I would avoid chemical thinners, as they will likely react with the plastic chemistry. |
02-27-2021, 06:46 PM | #5 |
Spray bomb use mineral spirits , Automotive paint , it's not coming off without ruining the chrome plastic finish
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
02-27-2021, 08:50 PM | #6 |
All about them K’s
Goo gone, will pull spray bomb paint.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
