03-22-2021, 08:18 PM | #1 |
292/ Sm465 one piece drive shaft
Hello all, does anyone have a 292/ sm465 combo running a 1 piece driveshaft? I have a 71 shortbed with this combo going in and would rather a 1 piece if at all possible. Any info would be appreciated. Thanks in advance
03-22-2021, 09:23 PM | #2 |
Re: 292/ Sm465 one piece drive shaft
Yeah. I have a '68 C/10 Stepside w/ 292 L6/SM 465 and one-piece propshaft. All Factory [Fremont CA]. 12-Bolt, 3.73 rear. Posi conversion later.
03-22-2021, 09:34 PM | #3 |
You wouldn’t happen to have a pic of that set up would you? Or any recommendations on who to have build a driveshaft for it?
03-22-2021, 11:16 PM | #4 |
Tomorrow, I can try to crawl under and shoot one.
You could Google the subject internally, by checking 67-72chevytrucksdotcom , instead of Web, in the box on the upper margins.
03-23-2021, 09:16 AM | #5 |
I have a 69 SB, came from factory with a 250/350 turbo and I piece driveshaft. It now has a 292, 200-4R and the same I piece drive shaft with no alterations, with the exception of moving the trans support back about 5 inches, all factory drilled holes.
03-23-2021, 10:21 PM | #6 |
It was raining cats and dogs today.
