Old 09-23-2015, 09:23 AM   #1
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
60-62 Frame Horns
Common problem with them cracking and breaking.
I had hoped to replace them with the 63-66 style, but it's not just about the bolt spacing, the 60-62 bumper contour is different than the 63-66.
I know I could find someone who has a nicer set they could cut off an old frame, but I'd like to see if we could come up with another solution. Has anyone fabricated their own new horns?
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 09-23-2015, 11:28 AM   #2
LostMy65
LostMy65's Avatar
Re: 60-62 Frame Horns
I actually made it this far before I realized the shape of the bumpers are different. I knew the bolt spacing was different, but I didn't realize the shape of the bumpers on 63-66 were different from the 60-62.
Old 09-23-2015, 11:33 AM   #3
oem4me
You've gone that far, why not just find a 63-66 bumper to fit the new horns? Or am I missing something?
Old 09-23-2015, 01:45 PM   #4
LostMy65
LostMy65's Avatar
They're not welded yet. Just hanging there for mock up.
Yes, I've considered getting a 63-66 Chrome Bumper.
I've got one more thing I'm going to try.
I would rather not spend $180.
Old 09-23-2015, 02:02 PM   #5
60-66
60-66's Avatar
Isn't the 63-66 frame taller here ? Might interfere with the grille surround . The notches in the surround for 63-66 are taller or deeper than 60-62.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 09-23-2015, 02:08 PM   #6
LostMy65
LostMy65's Avatar
yes, my grill support happens to be from a 65. my 65 is on a 62 frame.
Old 09-23-2015, 04:09 PM   #7
LostMy65
LostMy65's Avatar
I'll chalk it up to another lesson learned.
No big deal. I went ahead and repaired the 62 horns.
I'm comfortable with my welding skills.
I'll just weld them back on.
Old 09-23-2015, 10:47 PM   #8
61ChevyPanel
Active Member
61ChevyPanel's Avatar
My front frame horns are shot too so if anyone has '60-'62 horns or another solution, please reply.
61ChevyPanel is offline   Reply With Quote
Old 03-05-2016, 11:55 AM   #9
LostMy65
LostMy65's Avatar
I cut mine off. Bolted the broken pieces to the bumper. Tack welded the pieces together. Then welded the repaired horns back on.
Old 03-05-2016, 03:40 PM   #10
Tazimafied
I would weld in some gussets to keep it from happening again.
Tazimafied is offline   Reply With Quote
Old 04-05-2018, 07:02 PM   #11
LostMy65
LostMy65's Avatar
Saving ron's post for future reference:
Originally Posted by padresag View Post
here is the difference in the profile black line is 62. red is 66
ron
Old 04-22-2018, 01:02 PM   #12
Thiessen1960
I am in the same predicament. I currently have a set of frame horns from a 63-66. If I welded those on to my 60 Chevy would I just have to use the 63 to 66 bumper?
Thiessen1960 is offline   Reply With Quote
Old 10-08-2018, 11:57 PM   #13
LostMy65
LostMy65's Avatar
Yes
Old 11-08-2018, 04:59 PM   #14
LostMy65
LostMy65's Avatar
Yes, I just want to do few more alignment checks before I reinforce them.
Old 06-21-2021, 05:37 PM   #15
LostMy65
LostMy65's Avatar
It's almost like there should be a reinforcement piece that could be fabricated to bolt to the existing frame. That way even those without the ability to weld could just bolt it up.
