Old 01-10-2015, 01:56 AM   #1
mcgoo26
mcgoo26's Avatar
Gas Tank Relocation-Thoughts?
So, I have a 72 C10 that I am looking to restore to its original beauty and was curious what everyone's thoughts were on relocating the gas tank from the cab to where the spare tire would be (for example). I want to update everything but keep things looking original for the most part. Backwards thinking I guess. I was just curious about what everyone has done or has seen. I have thought about replacing the tank and keeping it in the original location in the cab and have also thought of relocating the tank to the rear while keeping a mock filler neck in the factory location for the stock appearance and having a hidden filler neck for the relocated tank elsewhere (flush with the base of the bed or something). Thoughts?
mcgoo26 is offline   Reply With Quote
Old 01-10-2015, 02:39 AM   #2
swamp rat
swamp rat's Avatar
Re: Gas Tank Relocation-Thoughts?
Try the advanced search function, there are a bazillion threads on this, blazer tanks, Boyd fab tanks, falcon tanks, Mustang tanks, Poly replacement tanks. Not to mention filler locations, in the bed floor mount, in the stake pocket, in the side of the bed flip door from a doner vehicle, and last but not least the behind the rear marker light and rear tail light fillers.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-10-2015, 10:59 AM   #3
Eddie H.
Eddie H.'s Avatar
My last fuel tank conversion was using a poly plastic blazer tank in the spare tire location. If I were to do it again, I would use a custom fabricated steel or aluminum tank. The poly tank is ok, but it has a tendency to warp, and it has no internal baffles, and the fuel gauge bounces around like crazy as the fuel sloshes around inside the tank.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 01-10-2015, 11:11 AM   #4
cdowns
cdowns's Avatar
a giant waste of time and effort
Old 01-10-2015, 11:13 AM   #5
leddzepp
Moderator
leddzepp's Avatar
I did it on one truck, won't do it again.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 01-10-2015, 12:15 PM   #6
mcgoo26
mcgoo26's Avatar
Thanks guys for your input. Appreciate it.
Old 01-10-2015, 01:48 PM   #7
dirtyjim
dirtyjim's Avatar
in your opinion maybe, in thousands of others, including mine, it is not.
last weekend it would have need nice to tilt the seat forward and put my gun cases there instead of in the bed but I couldn't because some idiot at gm put the stupid gas tank there instead of putting it on the frame under the bed as is should be.
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies
2004 2500HD utility bed aka Brutus
dirtyjim is offline   Reply With Quote
Old 01-10-2015, 02:06 PM   #8
tyler_lay
87 but you get the ideaName:  tank.jpg
tyler_lay is offline   Reply With Quote
Old 01-10-2015, 02:21 PM   #9
mechanicalman
x2
mechanicalman is offline   Reply With Quote
Old 01-10-2015, 02:26 PM   #10
R.L.
R.L.'s Avatar
Yelp and your guitar, it's also the perfect place for luggage when traveling, I would do it but I'd like to keep the gas filler in the stock location. I have a step side and routing the plumbing would be a pain, also would create traps in the line. A rear mounted filler behind the license plate would be what I'd do, if I didn't have a dealer bumper.
R.L. is offline   Reply With Quote
Old 01-10-2015, 03:11 PM   #11
dirtyjim
dirtyjim's Avatar
when I finally get around to moving mine I'm planning on keeping the filler neck in the stock location and using 2" exhaust pipe to route it to the tank. I'm sure it will slow filling but I have a land rover discovery too and they are the slowest filling vehicle in existence so I'm not to worried about it.
Old 01-10-2015, 03:20 PM   #12
mechanicalman
Edited by self. LOL
Old 01-10-2015, 03:32 PM   #13
tinsoldier
tinsoldier's Avatar
If you are planning to go fuel injection and needed to fuel pump, then yes...But for stock carb and weekend driving. I don't really understand why the hassles. I am doing a 5.3 LS swap and I am still keeping my stock fuel tank.
tinsoldier is offline   Reply With Quote
Old 01-10-2015, 03:55 PM   #14
dirtyjim
dirtyjim's Avatar
I am about to go fuel injected and I actually use my truck, besides the stock tank has rust inside and needs to be replaced anyway.
I drive my truck to work at least twice a week and just got back from taking it on a hunting trip. some of the things I carry in my truck I would prefer to have stored out of sight behind the seat.
if the stock tank works for you, awesome. for many of us it doesn't
Old 01-10-2015, 07:25 PM   #15
boraxman
Keepin an eye out
boraxman's Avatar
Cant say I agree/
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 03-17-2016, 07:01 PM   #16
Jdevans05
https://www.instagram.com/p/BDEYRyJsbuI/
Maybe this will help some people.
My 72 c10 sb step side, tank out of a 66 mustang setup for EFI. SUMMITsending unit, tanks inc pick up tube with any in tank pump that works for your application. I used Aeromotive.
Jdevans05 is offline   Reply With Quote
Old 03-17-2016, 07:38 PM   #17
57larry
I have a 69 Camaro gas tank in the rear, works fine. gas tank in cab takes up leg room but I'm ok with both
57larry is offline   Reply With Quote
Old 03-17-2016, 07:40 PM   #18
davepl
davepl's Avatar
Let me perhaps refine what people are saying.
As a safety measure, it's probably a waste of time and effort. By the time the tank is deformed, so are you.
As a convenience measure to gain space in an already small cab, that I can see.
So maybe we're all saying the same thing but no one is listening to the other. It is the Internet, after all.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 03-17-2016, 08:07 PM   #19
leddzepp
Moderator
leddzepp's Avatar
You do not gain any leg room removing the gas tank. The top of the seat back still hits the back of the cab regardless of whether or not the tank is there. Unless you angle the seatback 90 degrees the seat won't scoot back any further.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 03-17-2016, 08:32 PM   #20
gvw5400
gvw5400's Avatar
(+1) After looking at mine.
All the best, Dirk
gvw5400 is offline   Reply With Quote
Old 03-17-2016, 10:09 PM   #21
Thanos
Thanos's Avatar
Doing that myself, I never cared for the tank behind the seat. We are fabricating a 30 gallon aluminum fuel tank to fit inside the class V hitch and run new fuel lines.We are going to have it set up for carb and drop in pump for the later 8.1.
Removed the filler neck and both side doors so we can stream line the body and place the filler hose under a latch in the bed.Have pictures soon.
Thanos is offline   Reply With Quote
Old 03-18-2016, 06:27 AM   #22
The stock tank worked for "everyone", till people who only know newer trucks with tilt forward seats, are used to driving cars, or extended cab trucks starting driving them. Those of us who have driven them all along have done so because we appreciate the superior engineering put into these trucks. A classic truck you can still daily drive nearly 50 years later. Trucks have always been tight in the cab. Truck guys always accepted that, or they install caps or tonneau covers
Old 03-19-2016, 02:58 AM   #23
chevy72blu
chevy72blu's Avatar
Very happy with my boyd's tank, which I only swapped to during the LS conversion. The tank in the cab didnt bother me other than the occasional smell. It also kept me from smoking in the truck which I'm happy about now, having quit about a year ago.
Having the added weight over the rear axle seems to help smooth out the ride and it likely hooks up better (if I was still trying to go fast in it).
Not having a spare tire sucks, though. It hasnt burned me yet but I know one day it will
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 03-19-2016, 03:40 AM   #24
BigMike
BigMike's Avatar
I agree it's a waste of time... to those who people feel that way. But I feel differently and love my Boyd's tank as well.
Do you gain leg room, no not really. You can store quite a bit of stuff back there, because there is really no where else to put it. For me the big thing was room for stereo equipment, amp, subs, etc...
But that's the beauty of this site, and truck guys in general, there is no right or wrong answer when it comes to tank location (okay maybe there is, but I won't get into that now). What works for some may not work for others & vise versa. It follows the same arguments as lowering/lifting or leaving stock. Customize or restore. We all have our own ideas of whats cool to us.
BigMike is offline   Reply With Quote
Old 03-19-2016, 06:08 AM   #25
I think it wouldn't be restored back to it's original beauty.
