Old 09-25-2021, 04:10 PM   #1
kglowacky
rear end swap
now that I have been driving my LS1 swap with 460E. I am considering swapping out my 373 gear for something lower like a 308. I am hoping to improve gas mileage. Currently this truck will get up and run but the gas miles is bad. Interested in knowing how to go about getting one that bolts right in. Is there many different styles/configurations of how they bolt in or is a chev a chev? Will a Suburban bolt right in?
If anyone in the Houston area has a 308 and would want a 373 let me know.
kglowacky is offline   Reply With Quote
Old 09-25-2021, 04:48 PM   #2
LS short box
Re: rear end swap
Before I would swap gears I would check the tune on a chassis dyno. Maybe you already have. The good thing about the 4L60E is the low first gear.
Old 09-25-2021, 05:20 PM   #3
MySons68C20
MySons68C20's Avatar
Re: rear end swap
What is your rpm at 70 mph 2000-2200?? I would think those 3.73's would have you in the sweet spot.
MySons68C20 is offline   Reply With Quote
Old 09-25-2021, 05:23 PM   #4
Warrens69GMC
Warrens69GMC's Avatar
Re: rear end swap
Your tune, your tire height, weight, rim size, stock height or lowered all play into MPG
Old 09-25-2021, 07:09 PM   #5
b454rat
Re: rear end swap
Not an LS swap, but my old Tahoe had 3.42s, with roughly stock size tires. Pretty much stock, but it had decent acceleration and top speed. Top speed was mainly limited to the stock motor and ECM. 70 was lil over 2k rpm.
Old 09-25-2021, 10:21 PM   #6
SCOTI
SCOTI's Avatar
Re: rear end swap
Like said.... Tire height plays a lot into gear ratio needs. Efficiency doesn't always mean the mildest gearing possible. What size tires?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-26-2021, 10:03 AM   #7
kglowacky
Re: rear end swap
here's what I know as I am not up to speed with all the details as all I did was buy the motor and trans out of a 2001 Camaro and install it, Then sent the pcm to cal. for them to fix the harness. The only thing I know is I did tell them the raer end was a 308 when in fact it is a 370. I never sent it back for them to re set it. I didn't think it would matter that much. The truck is all stock except for a 2 inch drop in front(spindles) and 4 inch in back(shackles and mounts). Tires are factory steel wheels and 235/75/R15. don't know rpms I dont have a tach
Old 09-26-2021, 01:11 PM   #8
MySons68C20
Re: rear end swap
I would run it as is....if the speedo is off you can correct it later afaik.
I installed 3.42 in my 68 and wish I had the 3.73 instead.
The 700r4 4th gear is not really usable below 50 mph imho.
Old 09-26-2021, 01:11 PM   #9
SCOTI
SCOTI's Avatar
Re: rear end swap
Your tire size w/a .70 OD gear should yield 2100 rpm @ 70mph. Thats where you need to be. Anything lower will drop highway rpm's but they're in range of the 'small block' sweet spot.
Simply lowering rpm's beyond the sweet spot doesn't gaurantee better mpg's. The efficiency of mass going down the road will have an impact (these trucks are kind of a brick). Vehicle specific tuning is a must for your quest.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-26-2021, 02:31 PM   #10
kglowacky
Re: rear end swap
thanks. So are you saying the fact I have the wrong info in my pcm for my rear end radio does or does not make a difference?
Old 09-26-2021, 03:40 PM   #11
SCOTI
SCOTI's Avatar
Re: rear end swap
Maybe not night & day difference but it can make a difference. Tuning can go a long way for steady rate highway cruise mpg efficiency.
Another thing.... I had an '02 TransAm. Took it on a trip & was trying to squeek out the best mpg possible. I was trying to keep the rpms around 2-2200/65mph thinking it would help. Turns out, the efficiency for the motor (amount of fuel consumed) was the same up to 25-2600. I got better mpgs @ 80mph (same fuel consumption but more mph). I ran the numbers on every tank of fuel for the trip there & back for better consistency on the numbers. Def didn't expect that.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-26-2021, 04:19 PM   #12
kglowacky
Re: rear end swap
what was your highway and around town mpg?
Old 09-26-2021, 07:01 PM   #13
jjzepplin
jjzepplin's Avatar
Re: rear end swap
Kinda sounds like you need a vehicle specific tune. It seems you may have a simple generic "get it running" tune. My truck has a 1999 5.7 with a T56 and 3.73 posi. Guys that have a similar setup say it will be an absolute blast. I fit were me, I would put that moolah in a tune. It would be easier on the knuckles and possibly better results. If you change the rear gears, you will still need a tune.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 09-26-2021, 08:48 PM   #14
SCOTI
SCOTI's Avatar
Re: rear end swap
3800# f-body w/LS6, 4l60e, 3.23's, & 275/40-17's (25.6") yielded 16mpg in city; 20 on the local hiways.
For my trip mentioned above, it was 20mpg avg on the first 2 tanks. Once I increased speed & covered more ground/hour, we were seeing ~23/24mpg.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-28-2021, 11:36 PM   #15
tdangle
tdangle's Avatar
Re: rear end swap
If they set it up for a 3.08 gear your speedo is probably way off and not showing true mileage.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 09-29-2021, 04:40 PM   #16
kglowacky
Re: rear end swap
I am running a cable manual speedo gear in the trans that is set for a 373. I am not using the ecm for the speedo. during the build I realized I had a 373 gear so I ordered the correct speedo gear the problem was I had already gotten back my ECM with the 308 setting completed.
