04-10-2021, 11:17 AM | #1 |
Behind the seat speaker box and questions
Ok, I am currently working on a behind the seat speaker box in place of the fuel tank. I have the speaker mounting panel roughed out and temporarily mounted. My questions are:
1) What is the best way to run the amp and speakers wires to the radio. 2) What size/manufacturer bass speakers are being used that fit 3) What should I watch out for laying this all out Thanks in advance
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a million pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" 2012 Jeep JKU "Crush" 1976 Chevy short bed with a 327 and 3 on the tree (Sold it to buy the Blazer) 1971 Chevy Blazer (Sold it) |
04-12-2021, 08:53 AM | #2 |
Re: Behind the seat speaker box and questions
Got the speaker box finished and ready to go. Now I'm working out how to run the wiring to it and what speakers and amp to use.
I do know the subwoofer will need to be a shallow one.
04-12-2021, 09:15 AM | #3 |
Almost Satisfied
I am running a 10" JL Audio shallow sub centered and it sounds great. I have 6x9's in the rear corners and kick panel speakers in the front.
I ran the amp hot wire from the battery into the cab via the cab vent and then down under the kick plate sill to the back. The wires from the radio come down the passenger side of the trans tunnel to the rear. Hope this helps.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
04-12-2021, 09:31 AM | #4 |
Mr. Cheyenne
Man, this is the main reason why I was to relocate the Tank to under the bed - I am sooo jealous seeing these setups!
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
04-12-2021, 10:38 AM | #5 |
Almost Satisfied
Peanut...did you use a high density plywood? If that is basic plywood it will not be good for a subwoofer.
04-12-2021, 09:15 PM | #6 |
Stepside, its 3/4" plywood and based on its weight its high density. I got it from my son in-law when he was cleaning out his garage. My plan is to put a single sub in the middle and 6"x9" 's on the outside by the corner but not in the corner. Hopefully the sound will be directed toward the front. For my front speakers I bought a replacement that is two speakers but mounts in the old dash speaker hole.
As for the wiring you basically did it the way I was thinking of doing it. I relocated my battery to the passenger frame rail just under the bed front bed panel. That will make the amp power lead very easy to run. I was thinking about running the radio wires along the trans tunnel but wasn't sure it that was the best route or not. Have you had any issues with your wires along the trans tunnel? Stepside, what type amp are you running a 2 or 4 channel? Also did you build your own sub box or buy it?
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a million pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" 2012 Jeep JKU "Crush" 1976 Chevy short bed with a 327 and 3 on the tree (Sold it to buy the Blazer) 1971 Chevy Blazer (Sold it) Last edited by Peanut74; 04-12-2021 at 09:25 PM. Reason: missing some question |
04-12-2021, 10:41 PM | #7 |
Active Member
Stepside very slick look...that came out great!
What did you use for your covering? |
04-13-2021, 03:58 AM | #8 |
MDF is typically the wood of choice in speaker boxes as it is dense. As far as air space you should look to manufacturers recommendations or use a subwoofer box calculator. Using the Theil Small measurements you can calculate the results from the enclosure. One thing to note it is important that the box is totally sealed any air leakage to the front side will cancel output from the sub.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
04-13-2021, 10:42 AM | #9 | ||
Almost Satisfied
04-13-2021, 09:26 PM | #10 |
My friend gave me some sub's and a 2 channel amp. I'm really on the fence as to whether or not I want to use it. I am thinking that the 4 channel would work better and be easier to wire up.
Can't use the sub's unless I cutout the back of the cab. That is why I was asking about your sub woofer which by the way should work great. I WAS going to buy some MDF until I seen the price of a sheet of it. It is crazy how much it and plywood have went up recently.
04-15-2021, 09:55 PM | #11 |
I went ahead and drew up my box. Maybe it will save the next guy or gal some time in making their speaker box.
Stepside, Thinking about making a sound box like yours and inserting it in what I have. It would give me more leeway on depth and height. Just a thought right now.
07-03-2021, 10:30 AM | #12 |
Active Member
stepside- would you happen to have a drawing with dimensions of your speaker box set up?
Thanks Larry |
07-04-2021, 10:03 AM | #13 |
Almost Satisfied
Larry,
I’m sorry I don’t have a drawing of it. I started with the box for the sub itself using the manufactures calculator for how much air it needed. I then built the side “wings” and attached them to the sub box. I used cardboard to make templates of the 6x9 pieces and played around with them until I got the fit I wanted.
05-05-2022, 01:35 PM | #14 |
Well I mounted my speaker box in the truck. I got the speakers from a friend that was moving. The sub was a Christmas gift so my goal of a cheap but decent sound system was achieved. The amp will be mounted under the center jump seat. I'll finish tucking in the top once I know the material is relaxed. Bottom potion will be covered by the floor carpet. One small step closer to the finish line!!!
05-05-2022, 03:01 PM | #15 |
Almost Satisfied
Hey Hey! There you go. Looks good. If you end up putting a headliner in the truck put a little dynamat on the roof it will help with the sound. Great job
05-10-2022, 01:44 AM | #16 |
1971Stepside, Your seats clear the subwoofer? No issues getting the seat as far back as possible? Looks great!
Steve ___________________________________ http://67-72chevytrucks.com/vboard/s...d.php?t=618848 |
05-10-2022, 09:11 AM | #17 | |
Almost Satisfied
05-10-2022, 10:11 AM | #18 |
I'm going to have to upgrade my AM radio and dash speaker ?
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
05-12-2022, 02:38 PM | #19 | |
You set the standard there, I will post when I get to that point in a few months...my cab is still on the dolly and in primer. |
05-12-2022, 02:44 PM | #20 | |
05-14-2022, 12:10 PM | #21 |
Thanks everyone. Took me awhile to respond as life was getting in the way.
I did have one issue I had to figure out. Tested everything before I bolted it and everything was fine. Bolted it in and no sound. Stereo was working but was in protection mode. Took me a couple days but I finally figured it out. My switch wire was touching thr aluminum on my sound dealer and causing the issue. Taped up the end and everything is fine. I will be mounting the amp under the jump seat.
05-14-2022, 06:10 PM | #22 |
Hey Peanut, are those smaller speakers sharing an enclosure with the subwoofer or do you have a dividers inside to separate the air space from the subwoofer. Your smaller speakers can’t be in the same box as the sub without dividers or pressure from the subwoofer will destroy the smaller speakers.
Posted via Mobile Device |
05-14-2022, 11:44 PM | #23 |
There are dividers in the box. So hopefully they will last. Got the speakers for free so if they do vlow I'm just out my time.
