Old 01-30-2017, 06:56 PM   #1
eighteenninetytwo
Pictures of stock height with 32" tires?
Is anyone running stock height suspension with 32" tires OR has a 1" block lift at the rear only with 32" tires. Any pictures that you could post?
I'm wondering :
a) What the stance looks like - I think the 1" lift would eliminate the rear squat that the blazer has and the slightly larger tires woudl make it look a wee bit more solid.
b) Whether I'd need to trim the fenders at all (don't want to do that).
eighteenninetytwo is offline   Reply With Quote
Old 01-30-2017, 08:09 PM   #2
texastruckjunky
texastruckjunky's Avatar
Re: Pictures of stock height with 32" tires?
I ran 33's on stock suspension on my suburban. when it had 8" rallys it cleared once I put the 12" rims I had to clearance the rear of the front fender.
Life is to short to drive anything else
texastruckjunky is offline   Reply With Quote
Old 01-30-2017, 08:40 PM   #3
eighteenninetytwo
Pretty certain I have 8 inch x 15 so that should be good . Some photos wouldn't go amiss though folks
Old 01-31-2017, 10:38 AM   #4
Ski-me
Ski-me's Avatar
I did 32 x 11.5 BFG's and they were just fine at stock height. Adding a 1" block in the rear also worked perfect for me to take the sagging look out.
You should be just fine.
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
Old 01-31-2017, 01:25 PM   #5
SilverMiner
SilverMiner's Avatar
I ran 32x11.50-15 Cooper STT's on stock 8x15 ralley's with my 1980 Suburban for nearly three years on the high-mileage stock suspension with no trouble at all (see picture). The fronts did occasionally rub the running boards in certain situations, but it was pretty mild.
1980 K10 Suburban Silverado, original 350 w/Qjet swapped to 406sb, TH350C swapped to TH400/205
SilverMiner is offline   Reply With Quote
Old 01-31-2017, 04:04 PM   #6
eighteenninetytwo
Ski - me - any pics??
Silver Miner - how gnarly were the "certain situations"? this is going to be a mall crawler with occasional beach / rocky trail and mud 4x4 use.
Old 01-31-2017, 04:15 PM   #7
SilverMiner
It only occurred in crossed up situations, such as when trying to climb diagonally out of very deep ruts in a logging road and the steering turned to full lock. The running boards are the problem, and without them intruding into the fender area I doubt I'd have ever had a tire touch the original fenders. I too have run 33's on a stock suspension (but not this suburban) with the exact same results - a little bit of rubbing in crossed-up situations that could easily be addressed with modest fender trimming or narrower tires such as a 255-85-16. Some rigs can run 33's with no drama, and others can't. I've become convinced over time that the primary difference is due more to worn out and collapsed body mounts than worn out springs.
Old 01-31-2017, 04:35 PM   #8
SilverMiner
Here is a photo of my old 78 Jimmy running 255-85-16's (approx. 33") on stock suspension, complete with droopy butt.
Old 02-01-2017, 07:28 PM   #9
eighteenninetytwo
Thanks all for the info, but keep pictures coming if anyone has them. Sounds like I should be able to fit large tires with minimal issue to existing wheels when the current ones get a bit more worn down. I'll add 1 inch lift blocks at the same time and we'll see how it turns out.
Old 02-01-2017, 09:57 PM   #10
Bigred74k20
Bigred74k20's Avatar
I would run OffRoad Designs 1" Zero rate for the rear.
http://offroaddesign.com/catalog/Zero%20Rates.htm
1974 Chevrolet K5 Blazer
350/Th400/205 Dana 60/14 Bolt
36x12-16 S.S TSL Radials
6"Front 7.5"Rear F/R ORD bushings/front shackles
Sky shackle flip, Crossover, rear disc brake conversion
ORD steering box brace, Tom woods CV rear driveshaft
Bigred74k20 is offline   Reply With Quote
Old 02-03-2017, 01:51 PM   #11
Ski-me
Ski-me's Avatar
It was 15 years ago if I can recall.....so hard to find pics with 32's on it.
Here is my old suburban that I put 1" blocks on the rears....couldn't tell you the tire size but I think they were 16" rims?!?
- Jeff
Old 02-03-2017, 02:07 PM   #12
Ski-me
Ski-me's Avatar
I did a bit more looking....this guy claims to have 32" tires.
Also, you and I discussed this awhile back in another thread. Here are a few more pics that might help you.
http://67-72chevytrucks.com/vboard/s...d.php?t=605354
- Jeff
Old 02-03-2017, 02:10 PM   #13
Ski-me
Ski-me's Avatar
another 32 with no lift
- Jeff
Old 02-03-2017, 02:25 PM   #14
eighteenninetytwo
You have a good memory - I'd totally forgotten that thread.
That last one looks about perfect in terms of stance.
Old 02-03-2017, 08:58 PM   #15
68Timber
I know the pieces fit
68Timber's Avatar
32's look great on a stock suspension but they're hard to find. At least they used to be.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 02-05-2017, 08:21 PM   #16
mickeykreg
mickeykreg's Avatar
My '77; stock sacked out springs on 32x11.50x15 BFG KM2's
'80 SRW C35 - 355/700R4/4:11/2.5-3/DD
'77 Cheyenne K5 - Roller cam 355/NV4500/205/4:88's/35's/DD
rust repair on the '77
http://67-72chevytrucks.com/vboard/s...d.php?t=740291
mickeykreg is offline   Reply With Quote
Old 11-02-2018, 10:53 PM   #17
bL.A.zer90045
Thread revival....anyone else with stock suspension and 32’s please post pics.
bL.A.zer90045 is offline   Reply With Quote
Old 05-28-2022, 04:22 PM   #18
chubz
i just got 31s maybe i should have gotten 32s (i still have stock suspension)
chubz is offline   Reply With Quote
Old 06-06-2022, 02:02 PM   #19
James Lamb
My 1989 Suburban v1500 had 235/75/15 tires when I got it -stock size. There was so much space inside the wheel well you could stick your head in above the tire and rotate without hitting anything. I moved up to 31" tires for a free 1 +" lift, have had no problems at all.
1989 Suburban 1500 4 x 4
1989 BMW 325i
1945 Willys MB Jeep
1959 Triumph TR3A
James Lamb is offline   Reply With Quote
