06-13-2022, 02:02 PM | #1 |
Where does the wave washer go for the parking brake lever?
I've seen a few references where the wave washer is installed two different ways. Which is right? Thanks
A. behind E-clip on face of brake shoe (first image) B. between parking brake lever and inside of brake shoe (second image)
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
06-13-2022, 03:41 PM | #2 |
Re: Where does the wave washer go for the parking brake lever?
I prefer the second installation method. This maximizes the surface contact between the washer and the steel parts, which minimizes wear on the washer. The first method would tend to wear the washer on the inner half of it's surface. Either way will work fine and the difference in wear has got to be minimal.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
06-14-2022, 11:34 AM | #3 | |
06-14-2022, 12:10 PM | #4 |
I was a tech for 30yrs it was always between the lever and the brake shoe. If there was a washer under the e-clip it was a flat one and that was rare. The idea of the wave in the washer is to act like a spring and push the lever away slightly from the shoe so it moves freely.
Harley 1969 Chevy C-10 Long Bed, 350cid, 700R4 |
