Old 03-20-2018, 06:12 PM   #1
First c10
First c10's Avatar
TU/TD Column Shifter & Wiring
Hey All,
I thought I would share my Tap up / Tap Down GM Column shifter project for a 6L80E transmission.
I want to thank all that participated in my questions regarding shifter styles, wiring diagrams, and links to information.
First off I ordered a column shifter from a 2008 truck GM # 22834629. It was 30$ on ebay.
Here is a amazon link but too expensive (but you get the idea) TU/TD GM Shifter
I figured 30 bucks was worth a try as I did not like the toggle switch floating around the cab or trying to drive and switch gears like that.
I will be posting pictures and links as I can.
Picture is of a short Chrome stock tilt column shifter next to the newer shifter
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 03-20-2018, 06:32 PM   #2
First c10
First c10's Avatar
Re: TU/TD Column Shifter & Wiring
Before I did anything I needed to find out how to get the switch portion to work. The stock wiring uses just 2 wires. Well that made it a challenge as I knew I needed 3 wires 12v in and 2 outputs for TU/TD.
GO GO!!!
Old 03-20-2018, 06:39 PM   #3
First c10
First c10's Avatar
This is the switch’s circuit board with the stock resistors.
GO GO!!!
Old 03-20-2018, 06:41 PM   #4
First c10
First c10's Avatar
I used my small soldering iron and removed the stock resistors.
GO GO!!!
Old 03-20-2018, 06:51 PM   #5
First c10
First c10's Avatar
After I removed the resistors. I drew up a schematic on exactly how the switch worked. Then I soldered a bridge on the circuitboard to allow the switch to work as needed. I did have to add a third wire To the circuitboard.
GO GO!!!
Old 03-20-2018, 07:10 PM   #6
First c10
First c10's Avatar
Since I could not find how to utilize the tow/haul button. I decided to just use one of the white wires for the switch. The wires are inside a hard plastic stealth inside the shifter. Possibly I could have just added another fine wire but I don’t have plans to use the tow haul button I figured it would be easy to use.
GO GO!!!
Old 03-20-2018, 07:20 PM   #7
First c10
First c10's Avatar
The first picture is the shifter back together.
Second picture is how to wire the resisters.
Third is a look at the covering of the wires and how it exits the shifter.
GO GO!!!
Old 03-20-2018, 07:48 PM   #8
First c10
First c10's Avatar
So with the testing of the switch and it working correctly.
I focused on the other end of the shifter and how I was going to make it work with the old column.
As you an see in the pictures I was able to until I read the existing hole just have to drill out a little. I don’t remember the size but I think it was 7/32”.
I didn’t put the curve in it as the shape of the shifter would have hit the steering wheel while trying to put it in gear.
GO GO!!!
Old 03-20-2018, 07:50 PM   #9
First c10
First c10's Avatar
First attempt didn’t work to well
GO GO!!!
Old 03-20-2018, 07:54 PM   #10
First c10
First c10's Avatar
Second time was a lot better. I had to buy a mill bit and use a mill style vice. Not ideal but worked out
GO GO!!!
Old 03-20-2018, 08:10 PM   #11
First c10
First c10's Avatar
Ok so I got the TIG welder out and started to weld and cool weld and cool.
Tough to keep the heat out of the shifter and not melt the wiring inside. But I took my time and it turned out well.
Last picture is it cleaned up with a disc sander and painted.
GO GO!!!
Old 03-20-2018, 08:18 PM   #12
First c10
First c10's Avatar
On to the test fit.
Got in the column nice. I did make a small thin Teflon shim to take up a little gap. The shin was like .005 think. It took out the little bit of slop.
The boot you see is a column shift grommet for a 56 Chevy Bel Air.
It fit on the plastic groove on the shifter.
GO GO!!!
Old 03-20-2018, 10:40 PM   #13
dayj1
Very nice! Great work!
dayj1 is offline   Reply With Quote
Old 03-20-2018, 10:45 PM   #14
First c10
First c10's Avatar
Thank you!
I do want to reference 87Skier as he helped me with the wiring end of it
Here is a link to his thread. I do not think I can do it any justice
87Skier's thread Post #18
I will post pictures of how I wired it!
GO GO!!!
Old 03-20-2018, 10:56 PM   #15
First c10
First c10's Avatar
The linked thread of 87skier has the links to the resisters I used.
I bought 5 each as they were very cheap.
In the pictures below you an see the resisters in a loop.
I just cut to length and solder everything together like in the schematic shown under the resisters on the note pad.
The next picture I put them online and hear shrunk them together and put a couple of small mollex type connectors.
The pigtail on the shifter is long enough to go through the rubber column grommets and under dash about 2 inches. There is where I connected to the resister pigtail via the connectors. Then 1 wire to the trans and the other to switched power.
GO GO!!!
Old 03-20-2018, 11:04 PM   #16
First c10
First c10's Avatar
Here is the first test run before I fine tuned the shifts. It was hard to check things out and video tape at the same time.
https://youtu.be/Zoy-VQZU_qQ
https://youtu.be/qg8ciNAMja8
GO GO!!!
Old 07-15-2022, 11:45 AM   #17
jadedbird
jadedbird's Avatar
You should sell these. I'm not ever good with circuitry but this is exactly what I'm looking for
jadedbird is offline   Reply With Quote
Old 07-16-2022, 08:40 PM   #18
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
im missing something here....
there's no need to mod the switch unless the resistors are wrong? correct? what did i miss?
the signal, out from switch, is all you need... and its already there, pin 3. Pin 4 is 12v in to the tap switch section of the switch. other 2 wires is simple momentary for tow/haul.
power goes in, goes through all 3 resistors and out to trans at X.X volts
push up or down goes through either resistor and get a different X.X volt signal for tap up or down .... no need to open it up and complicate it...
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 07-17-2022, 01:43 AM   #19
First c10
First c10's Avatar
Hey Clint.
There is only 2 wires on the original switch shifter arm as it originally communicated with the BCM. To use tu/td you need a 12+ into the switch and a resisted wire for the up and the down independently. You also need to set TU/TD enabled and set to “wired” in the tune.
Not complicated if you just want a momentary switch on the dash or something. But the shifter will not just work without modify the shifter switch.
GO GO!!!
Old 07-17-2022, 11:44 AM   #20
87chevy.com
i see now.... lol, i wasn't thinking.. your right the switch needs to be modified to function like the corvette switch does ...
clint
Old 07-19-2022, 12:33 AM   #21
First c10
First c10's Avatar
clint
Ok cool I was thinking I did all that work for nothing lol.
GO GO!!!
Old 08-11-2022, 04:33 PM   #22
6600DURAMAX
6600DURAMAX's Avatar
Running a 6L80e would like to do same - I'll DM you
thanks
1972 K5 Build - plans - LS3-6L80e-One Tons.....
1971 CREWMAX Build.....at body shop for couple more years
6600DURAMAX is offline   Reply With Quote
Old 08-14-2022, 09:36 AM   #23
Joyridin
Originally Posted by First c10 View Post
Hey Clint.
Did you need to flash the TCM to get this to work? I was under the assumption that for a truck transmission, you had to have the TCM flashed to a Corvette tune in order for this to work, or there is a box that a few people were selling to bypass the tuning.
Joyridin is offline   Reply With Quote
Old 08-15-2022, 12:36 AM   #24
First c10
First c10's Avatar
It does take someone with hptuners to be able to set the tu/td setting to “wired”
FYI. This info is for an e38 ECM. Not sure on other types.
I believe the box you are talking about is basically what I built. Mines Just not in a box.
Scott
GO GO!!!
