Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 01-03-2004, 03:45 AM   #1
BladeX
Question Emissions. 86' GMC, what am i missing?
Ok i figure its getting old me posting about my crappy emissions.
Im just missing a couple things.
I got Air Pump...Air Pump Belt and the hose that comes off the air pump at the end of that is a Tee connector.
I picked up a a air pump check valve and i got 2 air pipes 1 for each side.
what else am i missing?
The air check valve has one end that has threads in it and the other end looks like ya use a hose clamp to keep it on. So i think im missing whats between the tee and the air manifolds.
Anyone got a checklist of emissions. And dont say order a LMC catalog cause i already did :p
BladeX is offline   Reply With Quote
Old 01-03-2004, 02:26 PM   #2
Ratpowerd67
alot of those rubber hose runs back into your fuel canister next to the driver fender....rat
Ratpowerd67 is offline   Reply With Quote
Old 01-03-2004, 02:28 PM   #3
Ratpowerd67
hey i got an 87 454 out back, ill give you a pic if you want, they should be very close to the same setup....rat
Old 01-03-2004, 03:33 PM   #4
BladeX
alright.
i know im missing a hose or 2 but im not sure what they are called.
Old 01-03-2004, 04:19 PM   #5
phantom dually
Project92 SWB stepside
phantom dually's Avatar
Do your manifold have the heat riser tubes??
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 01-03-2004, 05:29 PM   #6
1FaastC10
1FaastC10's Avatar
what engine are we dealing with here? i've got all the emissions stuff that i yanked off of my 305.
1FaastC10 is offline   Reply With Quote
Old 01-03-2004, 05:30 PM   #7
BladeX
Its the 305 (H)
i dont even know what heat riser tubes are...hehe
--My Manifolds-=
Old 01-03-2004, 08:27 PM   #8
Ratpowerd67
do you have the thermostat housing with the plastic thing with all the small hoses?
Old 01-03-2004, 09:05 PM   #9
BladeX
i think so. if its the saucer lookin thing with like 5 hoses coming off it then yes
and yes im a n00b. lol
I got the pump all instaed and the thing blows air. i just dont know what i need to connect the rubber house that has a plastic 3 way tee on the end of it to the Air pipes that are on the exhaust manifolds. Plus i have a air pump check valve not sure where that goes.
Old 01-05-2004, 02:38 AM   #10
crackajacka
Stylin
crackajacka's Avatar
might pick up a shop manual for your truck
Ive been traveling for some time, with my fishin pole and my bottle of shyne.
Most Girls like finished products and just dont understand what a good addiction does for you
http://www.paulwall.us/
crackajacka is offline   Reply With Quote
