12-05-2022, 05:29 PM | #1 |
Firewall question...
So question for you guys, this is the inner firewall right behind the radio area on a 72 Blazer, does this look correct or is there a piece missing etc.?
TIA |
12-05-2022, 10:09 PM | #2 |
Re: Firewall question...
Some progress is better then no progress |
12-06-2022, 03:58 AM | #3 |
Looks like something is fastened by glue/caulk or other means to provide a support for radio or something else. Maybe see a bolt hole still there for the stock speaker/rear radio support in the pic. Some Blazers had no speaker hole in dash. Radio speaker was mounted under heater, A/C controls. Cannot say which design is more common. Would bet under dash is more common.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 12-06-2022 at 04:04 AM. |
12-06-2022, 01:04 PM | #4 |
Yeah, weird looks like an inner panel is missing?
12-06-2022, 02:23 PM | #5 | |
12-06-2022, 02:52 PM | #6 |
I do believe the rear radio support bracket does get mounted to the missing firewall piece for both speaker locations, I would think it would be the same for trucks as well?
No cowl rust issues that I can tell, just a little surface patina that would be on the inside of any enclosed part of a Blazer. If I run across another 67-72 that's being parted out I will take a closer look and see if I can remove that piece. |
12-06-2022, 08:08 PM | #7 |
Hmm, A previous owner did a TBI swap and put the computer on top of the radio, I wonder if they flattened that section to make room? Always fun trying to figure out what a PO did.
