Old 02-01-2023, 06:33 PM   #1
Accelo
Accelo's Avatar
Adding a FAST 102. What do I do for an aircleaner?
My current setup is for a 4" ducting on my air-cleaner. The 102mm is converts 4.015"? I am assuming it is an internal diameter with something like a 4.250 OD. What ideas does anyone have for plumbing this 102mm throttle body to an air-cleaner? The aftermarket has stepped up for the Camaro guys, with a special aircleaner, but I am finding nothing for the truck market.
Accelo is offline   Reply With Quote
Old 02-01-2023, 07:17 PM   #2
mongocanfly
mongocanfly's Avatar
Re: Adding a FAST 102. What do I do for an aircleaner?
I havnt looked..but check spectre.. they have lots of stuff to build your own setup
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 02-01-2023, 07:21 PM   #3
Joyridin
On my 102, I was able to use the 4" silicon adapters. My set-up is a bit different, but I used a Airaid 4" universal tube and mounted an air cleaner behind the battery (between battery and fender). Then on the bottom of the fender, I cut a hole and covered it with a screen to keep out the crap. This allows it to have a fresh air inlet. Seems to work well.
Joyridin is offline   Reply With Quote
Old 02-02-2023, 01:51 PM   #4
Accelo
Accelo's Avatar
The parts will be here today. Guess I will see if I can stretch the existing 4" over the new TB.
I have a Spectra on the existing LS1 motor. Seems the aftermarket would have something that was the correct diameter, haven't found anything so far.
Thanks.
Old 02-02-2023, 06:03 PM   #5
LS short box
Another source I have used for intake stuff is Intakehose.com.
Old 02-04-2023, 02:32 AM   #6
Accelo
Accelo's Avatar
I measured the OD is just over 4.200"
I also remembered I used a OEM Silverado intake sleeve to adapt the 4" tubing to the much smaller stock LS1 throttle body. To recap, the stock TB is smaller than 4" and the Fast TB is almost two tenths larger. Will be fun but I will get it. Thanks for the tip, I will look into the Intakehose.com. I have gotten some great links from Chevytruck's members.
I did find a straight reducer the size I needed.
The 4-1/4" end fits on 4.15" through 4.25" MAFs and throttle bodies, including the FAST 102. Also many lids.
However, my intake needs to make a 90 right out of the TB. I have some more checking to determine if this will possible work.
Cheers
Old 02-04-2023, 03:41 AM   #7
mongocanfly
On my C30 I used a spectre rubber 90 off the maf and throttle..the aluminum 4in tube I got off ebay..
All the rubber parts and filter on mine are from spectre..not sure on part numbers...been awhile
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 02-04-2023, 05:59 PM   #8
LS short box
Pic of my Camaro's intake. It was 4".
One thing I do on my LS intakes is make a bracket that fastens to the bottom of the intake tube and then bolts to a tapped hole in the cylinder head. This supports the intake and moves as the engine moves.
