Old 06-05-2023, 03:58 PM   #1
RustyRetro
Help with frame id
Can anyone please help id this frame number 72J165955
6 lug coil spring suspension front and rear.
Drum brakes front and rear.
RustyRetro is offline   Reply With Quote
Old 06-05-2023, 04:46 PM   #2
RustyRetro
Re: Help with frame id
Frame pics
Old 06-05-2023, 09:00 PM   #3
kwmech
67-70 frame
Old 06-05-2023, 09:49 PM   #4
pjmoreland
pjmoreland's Avatar
The holes in the core support mounting brackets look large to me, so maybe it can be narrowed down to 69-70. If the rear end is the wider variety, then it would be 70.
pjmoreland is offline   Reply With Quote
Old 06-06-2023, 09:06 PM   #5
57taskforce
All about them K’s
57taskforce's Avatar
The answer is in the partial vin stamp pictured… That frame is a ‘72 built in Janesville, number 65,955 to roll down the line in the model year, you can look at the build date project to determine approximate build month/day. Someone swapped the rear axle and front suspension at some point, likely to put its 5 lug stuff under an earlier truck.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
57taskforce is online now   Reply With Quote
Old 06-07-2023, 01:42 AM   #6
RustyRetro
Thanks for your help
