07-04-2023, 07:11 PM | #1 |
‘79 K20 Camper Special U-joints
Replacing my rear driveshaft with a better one with no slip yoke wear, swapping the u joints first. I always have trouble looking up parts for this truck because of the weird combination of parts. 10 bolt front, NP203/TH400 with a 14FF rear axle. The Rockauto Autozone, whatever references are almost always wrong. I pulled the old ones off, likely the originals. The transfer case end says Spicer P621. I believe the new Spicer # is 5-760X. Its not greasable, I wouldn’t mind having one that is. The axle end u joint is larger, caps 1-3/8” approximately. One side says “Spicer Can” with numbers F3-5-69 and a big X in the middle. The other side says A525. None of these numbers are helpful when trying to look it up. I’m hoping the 14FF used a standard u joint and somebody here knows the part number.
07-04-2023, 10:18 PM | #2 |
Re: ‘79 K20 Camper Special U-joints
It most likely has 1310 U-joints with a 1350 at the rear axle.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
07-05-2023, 12:31 AM | #3 |
Take your cup dia. and overall width to the chart.
https://neapcoaftermarket.com/wp-con...og-9901018.pdf G numbers are non greasable.
1955 GMC 250 8 Flatbed 1971 C30 157" 350 4spd 10' Flatbed 81 GMC K30 CnC 9' Flatbed 454 T400 89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958 71 LT1 Convertible, 72 Coupe 69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2 |
07-05-2023, 10:59 AM | #4 |
That’s a great chart, and Al guessed right. Thanks both for your help.
07-06-2023, 01:25 AM | #5 |
Should have 5-760x on the rear shaft 1350 series (both joints)
07-06-2023, 08:03 AM | #6 |
I actually moved my slip yoke to behind the transfer case and used a conversion U joint at the rear axle. Now the slip yoke has a much calmer life than it did bouncing around and twisting with the rear axle.
