07-12-2023, 11:57 AM | #1 |
Windshield sealer
I had a new windshield installed a few weeks ago. The gasket was pretty new, but not brand new (Maybe a year old). It leaks between the windshield and the gasket, not the gasket and the body.
Anybody know of a silicone or some other sealer I can buy to seal it up? I used tire sealer last time and it worked well. I thought there might be something different that might work better. Thanks! |
07-12-2023, 04:47 PM | #2 | |
Re: Windshield sealer
07-12-2023, 08:43 PM | #3 |
I agree, I'd just take it out and replace the gasket. Does your truck have the stainless trim in the gasket?
Do you know what brand of windshield they put in it? There is also a chance the windshield isn't shaped exactly as the OEM. Opinions may differ but I like the Plinkington windshields with the tint at the top, and Precision gaskets. I have a trick I use for the stainless trim if needed
07-13-2023, 07:11 AM | #4 | |
07-13-2023, 07:14 AM | #5 | |
07-14-2023, 01:43 AM | #6 |
From what I understand all the new gaskets are still made for stock thickness glass. Unfortunately, from what I have seen the new replacment glass is thinner than stock so leaks develop. Maybe try a butyl or urethane sealer. The butyl is what was recommended originally where the gasket seals to body at the corners. Reason I used my stock glass even though not perfect.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
07-14-2023, 07:54 AM | #7 | |
I will try the butyl. Somebody had a post with some 3M sealer, but they must have removed it. I have the email that was sent when they replied, so I will try that sealer. |
07-14-2023, 01:16 PM | #8 |
I just had an idea. Have you verified the second lip, on the back edge of the windshield gasket has been pulled up and over the lip in the cab?
https://youtu.be/SOU_0HpS7To About 15:45 in the video he talks about it. Maybe the lip just isn't seated properly in those lower corners?
07-14-2023, 01:43 PM | #9 |
Do NOT use silicone - use the butyl. Silicone will fail in automotive glass applications, and then the butyl has a hard time sticking to it.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
07-14-2023, 02:04 PM | #10 | |
UPDATE - I just looked. The seal is where it is supposed t be. Last edited by Joyridin; 07-14-2023 at 02:16 PM. |
07-14-2023, 02:06 PM | #11 | |
He must have deleted his pot, but i still have the email when he replied on the post. Will this work? |
07-14-2023, 03:13 PM | #12 |
Yes, it will work. I prefer a flow grade (liquid) sealer, but for a single use it's crazy expensive, since the pump alone costs around $70.
07-14-2023, 03:32 PM | #13 |
We used an old pump type oiler for the liquid buytl in the body shop 30 years ago never had a special tool
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
07-14-2023, 03:38 PM | #14 |
CRL7708 comes in a cartridge for a caulking gun
https://www.amazon.com/C-R-Laurence-...19160594&psc=1
07-14-2023, 05:11 PM | #15 |
Yah truckster, I deleted it when I read more thoroughly. The 3M product is generally what you put between the body and the rubber. I read the CRL770 and that sounds promising, since it never dries....
07-15-2023, 07:13 AM | #16 | |
08-01-2023, 12:30 PM | #17 | |
Thanks for all the replies! |
08-01-2023, 12:38 PM | #18 |
I'm glad it worked. Since it never hardens, it should last the lifetime of your windshield.
08-03-2023, 10:04 PM | #19 |
3m bedding compound is what you want to use.
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
08-04-2023, 12:54 PM | #20 |
I like 3M products. They always work great. The problem is they offer 100 different products with descriptions that are so close, you are not even sure of the difference.
I used the stuff mentioned above and it seems to work great. |
