Old 09-30-2014, 04:18 PM   #1
UTSA
UTSA's Avatar
Upper Radiator mount (where?)
Hello: I am looking for the bracket that holds the radiator on the top. I already have the U-shaped mounts from the bottom with the pads but I can't seem to find the one from the top ANYWHERE.
Specs:
1965 C10 with a new Champion 2row radiator.
I found a picture of what it should look like (from TR65 I think). I have seen them around in this forum but I can't find where to buy them. Junk yard?
1965 C10 350 combo
UTSA is offline   Reply With Quote
Old 09-30-2014, 06:00 PM   #2
Lugnutz65
Lugnutz65's Avatar
Re: Upper Radiator mount (where?)
You might need to custom fabricate your if the top of the radiator has a different thickness than the original Harrison radiator.
The original top support has 2 U shaped brackets with rubber inserts. These are spot welded to a flat plate with the proper bends. You could make one up easily enough if you have a metal brake and a welder.
True, buying a salvage part would be easier.
The pic below are for reference and should be correct for a 1960-1966 C10 with a short-wide V8 radiator and the last photo is for a tall-narrow L6 radiator.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 10-01-2014, 12:59 AM   #3
Captainfab
60-66 Nut
There are 2 different upper radiator hold downs as well as the lower saddles for the V8 radiator. There the ones for the 2 and 3 row core radiators and a wider one for the 4 row core radiator.
Old 10-01-2014, 07:15 AM   #4
1966c10shrtbd
1966c10shrtbd's Avatar
Try this place yet?
http://4-5-6chevytrucks.com/contact-us.html
1966c10shrtbd is offline   Reply With Quote
Old 10-01-2014, 08:10 AM   #5
Clyde65
Clyde65's Avatar
I have an extra top part, I also have a champion and mine fit well with some trimming of the rubber or you can use a thinner piece of rubber( this is what I did).
If you want it, Ill place a for sale in the parts section.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-01-2014, 07:57 PM   #6
'65 chevy lover
I have a top mount. If interested, give me a holler.
Specs:
'65 chevy lover is offline   Reply With Quote
Old 10-01-2014, 09:21 PM   #7
Budman56
Budman56's Avatar
is this what your looking for? if so send me a pm
MY 65 C20 BUILD
http://67-72chevytrucks.com/vboard/s...d.php?t=483346
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
Budman56 is offline   Reply With Quote
Old 10-14-2014, 11:06 AM   #8
UTSA
UTSA's Avatar
thanks for the input guys but I decided to go the route of sheet metal from home depot to bend it up.
1965 C10 350 combo
Old 10-15-2014, 10:08 PM   #9
'65 chevy lover
Sounds like a much cheaper idea! Please post some pics of your finished product. I'd love to see it.
Old 08-22-2023, 03:36 PM   #10
RoyL
RoyL's Avatar
old thread, I'm looking for the top bracket for a V8, mine is AWOL.
1965 Suburban
Waiting on Time and Money
RoyL is offline   Reply With Quote
Old 08-22-2023, 11:12 PM   #11
cwcarpenter98
cwcarpenter98's Avatar
They are reproduced now, but if you want an original, please post a new thread in the 60-66 parts board
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 08-23-2023, 02:58 PM   #12
RoyL
RoyL's Avatar
Thanks! I saw some originals on eBay but didn't realize the were reproduced now. I see a big difference in price from LMC ($14.95) and CJpony parts $32.99
1965 Suburban
Old 08-23-2023, 05:43 PM   #13
cwcarpenter98
Happy to help! I found an original for mine before they were being reproduced, so I have no experience on if there's a difference in quality or if it's just a difference in who's reselling it
Christian Carpenter
1965, champion, mount, radiator
