12-01-2023, 01:16 PM | #1 |
Junior Member
After market steel wheels for dog dish caps
Looking for some clarification on wheels allowing the use of dog dish caps on my K10.
Summit Racing lists a Wheels Vintiques 62 which is basically the same as a Coker wheel; OEPR1586L414. Both are 15 x 8 and have a 4.5” back space. Does anyone know if these will clear the calipers or even the tie rod on the front and drum on the back or would they require a spacer and longer studs? Any comments on fitment or issues with would be greatly appreciated. |
12-01-2023, 07:54 PM | #2 |
Re: After market steel wheels for dog dish caps
There is a search function just to the left of your user name above. Here is a 37 second search I just did. Hope this is helpful in your "search" for rims....
http://67-72chevytrucks.com/vboard/s...d.php?t=748224
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks... |
12-02-2023, 09:55 PM | #3 |
Moderator
The above link posted are for 16x7 Ford wheels, which are for a K20 (8 lug). He needs 6 lug wheels.
You best bet is a set of 15x8 CUCV wheels, which came on military Blazers from 1984-86 or 87. They have 3.75” backspacing and fit perfectly. My experience (and some others as well from what I’ve read) is that the aftermarket wheels have too much backspacing and hit the tie rods. I have not heard of any issues with caliper clearance.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
12-02-2023, 10:29 PM | #4 |
Junior Member
Thanks, leddzepp, you're absolutely correct, I need 6 lug, not 8.
And for what it’s worth, I did a lot of searching of all of the forums before I posted my thread. |
12-05-2023, 04:58 AM | #5 | |
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
12-05-2023, 09:31 AM | #6 |
I like these wheels but they are too expensive. I still might buy some someday.
https://www.etrailer.com/Trailer-Tir...r/AM20758.html
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
