Old 08-24-2013, 09:39 AM   #1
twouvakind
twouvakind's Avatar
Windsield Wiper Delay
Ready to ship! Still just $56.95 shipped to the continental US.
Originally, I started this project as a windshield wiper delay unit specifically for 67-72 Chevy Trucks. It has now evolved into a multi year adaptable unit for Chevrolet cars and trucks with electric wiper motors. Fully compatible with GMC as well. This device gets wired into your existing circuitry with no cutting, splicing or modification of your wiring harness and it can be taken out before you sell your project and put into your next one! Normal wiper/wash(if equipped)operation is not affected as this unit provides the necessary pulse of ground to activate your wipers at a desired interval between 3 and 30 seconds. Two speed wipers require a short, properly terminated jumper(included if you need it) No more reaching for the wiper knob every few seconds to clear the windshield, this unit takes care of it for you with its remotely located control. The control potentiometer contains an intergral on/off switch. The control can be installed into a 5/16" hole. Mounting can be up to three feet from the control box, your imagination is the limit. The module box weighs just a couple of ounces, how you fasten it under your dash is up to you(quality elec. tape, zip ties). As long as your wiper switch utilizes Packard 56 style connectors, then this should work for you. I use the correct connectors with correct crimps as shown. All crimps are now soldered. Completely assembled and ready to install.
Video's:
Pics:
Member feedback on their installs:
"The workmanship & detail looks exc. I can't wait to do an install. thanks
again"
"Yes. works great. thanks again. Hope you sell many of them on the board. They are definately worth the money. Finally, someone has come up with a intermittent wiper that is easily installed and works flawlessly on our trucks"
"BTW your wiper delay works great! I love it."
"Finally hooked mine up. It works great!! Thank you. I wouldn't dream of cutting my new harness. Your set up is plug and play!!!!"
twouvakind is offline   Reply With Quote
