12-26-2023, 10:13 PM | #1 |
Best seam sealer for rocker replacement?
Would anyone recommend a specific seam sealer that works well with rocker panel replacement? I was surprised how much they globbed on at the factory, it was hard to find all the spot welds.
12-27-2023, 02:07 PM | #2 |
Re: Best seam sealer for rocker replacement?
I have used this - https://www.amazon.com/gp/product/B005RNFBMC
But honestly, if you check with your local paint supplier, I'm sure they could recommend something. That's a ridiculous amount the factory used. I was thinking, that is not a super critical joint to seal, it's mostly cosmetic. It will drain at the bottom of the rocker if water got in, but I guess it is best not to have water between the metal layers if possible. |
12-27-2023, 02:28 PM | #3 |
I posted this already, but thought it was funny. Front cab corner stalactites
1970 C10 Custom longbed 350/350 |
12-29-2023, 03:55 AM | #4 |
You stated best seam sealer, not least costly. I used this on my rockers and kick panel seams.
https://www.amazon.com/gp/product/B0...0?ie=UTF8&th=1 This was used in the drip rail https://www.amazon.com/gp/product/B0...0?ie=UTF8&th=1 Unfortunately, the specific 3M caulking gun is needed to dispense the product. I had access to one so it did not incur any extra cost. Both products were easy to use and worked well.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
12-29-2023, 08:01 AM | #5 |
I used the cream colored SEM seal sealer on my Blazer.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
