02-05-2024, 02:39 PM | #1 |
New to me 1963
Hi, I usually hang out in the 67-72 forum because I have a 69. But now I'm getting lined up to buy this 63 that I like quite a bit. What am I getting into here? My plan is to get it running, preferably with the engine and transmission it has, and leave the body as is. The windshield is cracked on the passenger side so I'll probably want to replace that. It was last registered in the 90s so I think I will need to find a title company to get it titled. The title company I used a few years ago on my 69 was a one-person operation and the owner of the title company died, so I need to find somebody new in Texas.
02-05-2024, 02:44 PM | #2 |
Re: New to me 1963
This is what I'm looking at for the VIN. I'm a little worried about those rivets, what do you think? The plate does not have those messed up serial numbers, that is just my obscuring for the Internet post.
02-05-2024, 02:46 PM | #3 |
Re: New to me 1963
It appears to decode to 1963 Chevy 1/2 ton 2-wheel-drive short bed made in St. Louis.
02-05-2024, 03:02 PM | #4 |
Re: New to me 1963
Another pic.
In 1963 was there a SPID? I didn't see a sticker of codes in the glove box lid. |
02-05-2024, 03:07 PM | #5 |
Re: New to me 1963
That's going to be a cool truck!
1987 V20 farm-hand rescue 1998 C2500 lot-rot rescue |
02-05-2024, 05:21 PM | #6 |
Active Member
Re: New to me 1963
Thats a keeper for sure
02-05-2024, 06:45 PM | #7 |
Re: New to me 1963
Thanks. Do you folks know what the 3 knobs on the dash left of the steering column do? And the thing to the right of the ignition switch that looks like it’s broken?
02-05-2024, 07:01 PM | #8 |
Active Member
Re: New to me 1963
Head lights, whippers choke and last but not least cigarette lighter.
02-05-2024, 09:08 PM | #9 |
Re: New to me 1963
Those aren't rivets. Factory spot welds. No SPID before 1966. GVWR plate on driver's kick panel will have the paint and trim codes.
02-06-2024, 12:35 AM | #10 |
Re: New to me 1963
Nice find! If the paint code is 505, that's the same color as my 63 was from the factory. Those are the same spot welds on the VIN tag that I have on my 63, so no need to worry there. Rivets came around in later years.
Looks like this one was ordered without a radio or a cigarette lighter! I could be wrong about the no radio though. Looks kinda like an antenna hole on the passenger cowl extension panel
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
02-06-2024, 01:28 AM | #11 |
Re: New to me 1963
I was wondering about that thing in the cigarette lighter hole and couldn't imagine what it might be, so maybe it is a delete plug. There is bondo on a few places of the truck, popping up and cracking. One of the places is on that cowl panel where it looks like an antenna hole may have been. I don't have this truck at my house yet, but when I get it here I will have to really look it over thoroughly and learn about it. So far I've only given it a brief exam. Thanks for the info, and if you have any more observations I would love to hear it. I would like to learn as much as I can about it, and I know almost nothing.
02-06-2024, 07:00 AM | #12 |
Re: New to me 1963
That truck seems to have a lot of potential. I look forward to seeing your updates and plan for it.
02-06-2024, 10:29 AM | #13 |
Re: New to me 1963
It is nice to see another 63 pop up. I just started my build and have a thread on the project page. Here is a link to my first YouTube talking about my truck and my build.
https://www.youtube.com/watch?v=1LZX_eKe0I4 The one you are looking at looks in really good shape. Couple things I noticed is your grille looks straight and you have both bezels. It is a one year only grille (one of the things I like about 63s) and are expensive if you need one cause the only ones available are original. No one is reproducing them. The cab on the inside looks great. Doesn't appear to have rust above the windshield which is great. Mine has some there that I know I will have to repair. Hoping not too much though. My 63 came from TX, is a St. Louis truck, and has the radio delete with the cover still on it. I think they are a little hard to find as well. Rob |
02-06-2024, 10:40 AM | #14 |
Re: New to me 1963
Nice find, my first truck was a '64 that started out very similar.
Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
02-06-2024, 10:51 AM | #15 |
Re: New to me 1963
That's cool. Good luck with it.
1965 C-10 1/2 ton shortbed part time daily driver 1980 C-10 1/2 ton shortbed project |
Tags |
1963 |
