Old 02-28-2024, 08:25 AM   #1
chrismoore701
chrismoore701's Avatar
Sounds like tire rubbing, but its not
Working on my 79. Sounds like the driver rear tire is rubbing something. Pulled the tire and drum off, no marks. Fired up and put in gear, put a stethoscope on the outer bearing, sounds smooth. Put it all over the diff, sounds pretty smooth.
I installed a posi unit, but the noise sounds like its coming from the tire area.
Thoughts?
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 02-28-2024, 08:59 AM   #2
Dead Parrot
Re: Sounds like tire rubbing, but its not
Park brake not fully released.
Collapsed rear brake hose keeping rear brakes partially engaged.
Rear shoes adjusted too tight.
Check drums for heat after testing.
Loose exhaust parts rattling. Other loose parts rattling.
Dead Parrot is offline   Reply With Quote
Old 02-28-2024, 09:58 AM   #3
chrismoore701
it is
Brand new hoses
Maybe
will do
Everything tight
Chris
Old 03-09-2024, 10:47 PM   #4
jerry moss
Born Psycho
jerry moss's Avatar
Smile Re: Sounds like tire rubbing, but its not
are the drums warped and hitting the backing plate ?
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 03-11-2024, 07:22 AM   #5
chrismoore701
no signs of anything rubbing anywhere on the rear end
Chris
Old 03-11-2024, 10:12 PM   #6
Dead Parrot
Assuming it is up on stands, pull the tires, snug the drums with reversed lug nuts and repeat the test. If the noise is gone, suspect out of balance/out of round rear tire(s) or poorly fitting wheels. If the noise stays, pretty well eliminates tires/wheels as the problem.
