Old 02-01-2004, 08:28 PM   #1
bad71gmc
1991 Suburban Transfer case question
I have a 1991 Suburban and was wondering what type of fluid the transfer case uses.
It look like it is ATF fluid, Is that right??
bad71gmc is offline   Reply With Quote
Old 02-01-2004, 10:37 PM   #2
Grim Reaper
ATF
91 ran a NP241 I beileve and there is a SYE available for it.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
Old 02-14-2004, 11:03 AM   #3
bad71gmc
Grim Reaper,
What exactly is a SYE that you were refering to??
Old 02-18-2004, 05:16 PM   #4
red450ih
red450ih's Avatar
Alot of rebuilders recomend using 5W30 full synthetic engine oil in the Tcase. It came with Dextron III from GM.
Keith
GMC
red450ih is offline   Reply With Quote
Old 02-19-2004, 01:07 PM   #5
Grim Reaper
Originally posted by bad71gmc
Grim Reaper,
Slip Yoke Eliminator.
Most hard core 4x4 ers want fixed yokes so that it you pretzle a drive shaft the fluid doesn come out. Also slip yokes only have some much travel. With a fixed yoked you can get a long spline drive shaft that wil alow for up to 24 inches of change. Also with a fixed yoke you can run a large CV joint to dealwith any angle issues from lifts.
Grim-Reaper
