02-10-2005, 06:04 PM | #1 |
T400 with NP205 questions?
Who can verify the lengths of a few setups for me. I would like distance from front of bell housing to center of yoke on rear output shaft of transfercase on a T400 and NP205 setup? Is there a difference in length depending on which model adapter is used? (there is the newer round adapter and figure 8 older version).
Also need the same on a T350 and NP205 setup (version I will switch away from)? and 700R4 with T350 adapter and NP205 transfercase? I hope to pick one and keep the stock mounting location on transfercase cross member which allows me to keep my drivelines too and this will hopefully move motor new BB 2-2.5" forward in engine compartment. I want to lay it all out before I buy a used setup to rebuild or order a Bowtie Overdrive 700R4 and find out lots of stuff moves or doesn't fit perfect. thanks for advise and help.
Bob |
02-11-2005, 10:24 AM | #2 |
I am also interested in this. TTT
1968 GMC 305 V6 3/4 4x4 Stepside 06 Corvette Daily Driver Dallas TX |
02-11-2005, 01:28 PM | #3 |
The t350/205 stock combo is the shortest, IIRC a 700 is 1.625" longer than a t350 from bellhousing to rear.
There are 3 different lengths of t400 output shafts used in 4wd's. Several different 205 inputs,ie 32 spline short and long, 27 spline t350 type, and a coarse spline used on 4spds, most of which are not interchangable. Lot's of good info on the ORD site. http://www.offroaddesign.com/catalog/doubler.htm Moving the engine forward is a good way to do the swap. Just watch oil pan clearance to front axle, shouldnt be a problem with a small lift. |
02-11-2005, 05:20 PM | #4 |
length might help
I think added length from T400 and 205 might help with moving engine forward to clear firewall. As far as I have read on offraod design page (and their pics) and others the input shaft on 205 that came behind T400 was the short female 32 spine version. I was hope to figure out if teh round and figure 8 adapter was same length. Also would like to know the length of the adpater kit AA sells to use 2 wheel drive T400 and my stock tranfercase with the 27 spline male input shaft.
The ORD website says they sell a conversion kit to modify my 205 to take the T400 adapter for $200. There is also some machine work to do to the 205 case. Then I need the T400 adapter and a good T400 to rebuild. What are the different T400 trannys I will find?
Bob |
02-11-2005, 06:04 PM | #5 |
Broke
Unfortunately I don't have my truck right now to give you measurements because it's getting painted, but wanted to say that I'm running a th400 and np205 with a big block in my 4x4. Basically what I did is connect all three together and dropped the transfer case in the original holes; this gave me plenty of firewall clearance with the BB, with no other mods like body lift. All I had to do was move the motor mounts forward and drill new holes. ORD is who I used for the th400/np205 conversion. Hope this helps a little?
72CheyenneSuper1ton4x4BigBlock |
02-11-2005, 06:20 PM | #6 |
nice pics
A few questions.
Did you test fit your brake booster and alternator brackets? Was ORD the suppler on trans or just conversion parts? Did you use a TH350 transfercase to start with? I assume that is a TH400 adapter, is it the newer round verison or older figure 8 version? Do you remember how far the engine moved forward? Very nice setup and great help. thank you.
Bob |
