Newbi looking for advice.
I'm new to this board and I'm looking for advice on a project that I'm doing research for. My goal is to build a mild custom '67-'72 1/2 or 3/4 ton long bed. The truck will be used as a daily driver and tow vehicle. We will be towing a trailer of approx. 6000lbs across the country so I need reliability and torque for those mountains that are between us (Calif.) and everywhere else. Good fuel economy is important also.
My plan is to build a 383 small block stroker with vortec heads backed by a 700r4 driving a 3.73 or 4.10 rear end. I want to run EFI but I can't decide between TBI, TPI or aftermarket like the Edelbrock multi-point TBI system. The reason that I'm going SBC is because I already have a good 4-bolt 350 core to build on. Well there you go, kinda long but I'm wide open to any and all advice, criticisms or thoughts. |
Still drivin' a Rat Rod
Welcome to the boards.
I think if i was to build a truck to use as a tow rig,it would at least be a 3/4 ton.
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
Catchy title goes here..
![]() Join Date: Mar 2002
welcome to the board
He's got mean nasty FANGS!
![]() Join Date: Dec 1999
Welcome to the boards!
I'd go with a 3/4ton for reliability while towing that much that often, the 700r4 im not sure if I would use tho since you cant really tow with it in overdrive anyway.... 4l80 (which is $$$$) or a good 5spd would be my choice...
2004 K2500 Burb 1999 C3500 1985 Cutlass Supreme 1969 C-10 1967 C-10 Panel josh@67-72chevytrucks.com |
Designated A-hole!
Welcome from South Mississippi!
What she said.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
