Chevy's Rock!
![]() Join Date: Apr 2004
'77 K10 won't start
I have been having some intermittent problems with my '77 K10 starting
and now it won't start at all. Thank god, because it was getting frustrating trying to troubleshoot the intermittent problem! I have confirmed that it is a "no spark" condition and here is what I have done in the past week or so: New Rotor New Module Different Cap Different Coil Ignition switch (replaced about 6 months ago) I checked voltage at the "battery" connection, with the wire off, and found 12 volts with the ignition on and 9.5 volts while cranking. Is that normal? What else should I check?
John '59 NAPCO Pickup '70 K10 Pickup 350 '72 C20 Suburban 350 (MIA) '57 Chieftain 455 '68 Firebird Convertible - 400 '68 Catalina Convertible - 400 '85 Vette |
Re: '77 K10 won't start
Hey john I'm new to the site and own a 75 k10 which I'm fixing up.I did acomplete tune up on my truck and runs good.It seems like you have changed everything but the wires.My truck was running rough so i checked the wires and they were'nt plugged in all the way.Hopfully it's an easy fix for you.Also check your battery connection I had problems there too.
#3 | |
Chevy's Rock!
Welcome to the site, it's awesome! I did ohm out the wires and they all checked out ok as it wasn't too long ago that I replaced them. Thye all seem to be seated on the plugs and teh distributor cap. Once the truck does start, it purrs like a kitten. Thanks,
John '59 NAPCO Pickup '70 K10 Pickup 350 '72 C20 Suburban 350 (MIA) '57 Chieftain 455 '68 Firebird Convertible - 400 '68 Catalina Convertible - 400 '85 Vette Last edited by '72 Chevy Suburban; 11-03-2005 at 09:04 PM. |
I'm back with 2nd truck!
When you installed the module, rotor etc. did you place the dielectric grease on there as well? If not there's your trouble. You can overheat it really fast and ruin it.
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
#5 | |
Chevy's Rock!
Is there anything else that will fry a module? Thanks,
I wouldn't hurt to replace it with the one you have that is working and test the other one. Another thing that would hurt is that if the battery was hooked up wrong. Jody's dad bought a Bronco II for $250 since it wouldn't run etc. We hauled it home and after changing the stuff you already did and a few other minor issues (unrelated issues to the battery being installed backwards and trying to start) we had it going. We had the same problem though with about the same voltage you have to the HEI but nada after that. Also you might check the coil while looking into it.
