Brake Proportioning Valve problems.
I have replaced all the brake parts and after gravity bleeding it all I started it up and the first push on the brakes turned on the great light we all like to see. I checked the reset button and it was not poped out so I tried the bleeder on top of the Prop valve and alot of fluid came out but now I get nothing out of any of the wheels. Whats going on with this thing. It is a 70 with disk brakes and I have no idea if it is the right valve.
Any input would be great. Kevin LFD Inc. |
Son of a gun
Re: Brake Proportioning Valve problems.
Did you bench bleed the MC?
Bill BEATERS ARE NEATER |
Resident Absorber
I had the same problem before. with a buddy around (to close all the bleeders) crack open all the bleeders, then slam the brake pedal to the floor fast and hard. while holding the pedal down, have the other guy close all the bleeders. pump it a few times and bleed normally. sounds stupid but it works
The best offense is a better DEFENSE! |
Resident Absorber
PS, my above post is taking into account you DID bench bleed the master. don't do the above if you didn't, cause it will ruin the seals in the master...
I did bench bleed the master, gravity bleed and can bleed all four corners and had a good pedal. I then fired it up and hit the brakes and the light came on. I checked the pop out button and it was not poped so I had my wife pump and hold the pedal while I cracked the bleeder on top of the pictured Prop. valve. It bleed out like a normal bleeder does but then that was it for any fluid out of any corner. The pedal will not pump back up or anything
![]() Does it look to be the correct Prop valve for a disk/ drum set up or is this the drum/drum Prop valve? It was on the truck when I got it and so were the front disk so I have no info on what they were off of or what parts were left un touched. Kevin LFD Inc. Last edited by Rokcrln; 05-19-2007 at 11:52 PM. |
See if this will help:
http://www.classicperform.com/TechBo...t.htm#testprop
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
This is a picture of the correct por. valve. It would appear that you have the correct disk/drum por.valve. Is the booster ok.
esll. ![]()
Tomorrow is for doing today's stuff. ![]() ************************************* This truck has just the right amount of energy for me! ![]() Author: Warren Lake .... (member) Last edited by EAST SIDE LOW LIFE; 05-20-2007 at 01:01 AM. |
67-72 Addict!
Kevin, I had the same issue recently with a new disc brake conversion on my 70' truck. I was worried because the light came on after the install. I drove down my street nice and easy and "tapped" the brakes a few times and heard a "pop" which was the valve recentering itself and the light went out
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
Well I got so fed up with this last night that I puled off the booster and put on another one I had and did the same with the master. I pulled the psi switch out of the Valve and re-centered it but it keeps flipping and shutting off the rear brakes. I even tried holding the valve inplace while bleeding and still nothing. I tried holding in the pin thingy while doing it but nope nothing still. When I hold the valve centered I get fluid out o the rear but as soon as I try it with out holding the valve it flips
![]() The worst part is I know what I am doing but I can't figure it out. I even went as far as finding my old chassies and brake books from school (20yrs ago) and re-read them for what I was missing and still nothing. So now what ? Kevin LFD Inc. |
Resident Absorber
"slamming" the pedal to the floor equalizes pressure in the front/rear and will center the valve. try it.
I am a Referee of life.
Have you replaced the rear brake hose?I'm just throwing a guess out there but poor flow thru that hose "may" make the prop valve act up.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
#13 | |
The only part of this system that is original are the front hard lines. Every ruber line and hard line have been replaced as well as all bolt on brake parts. Kevin LFD Inc. |
![]() Join Date: Aug 2003
Check the routing of your 2 lines going from m/c to prop.valve. They usually run different on a 1/2 ton vs. a 3/4 ton. I think you have them routed like a 3/4 ton.
#15 |
Sorry,I was wrong . I had them mixed up. I went to look at one and you have them right.
#16 |
One thing that is funny is I always thought that the small rear bowhl of the MC was for the front disk brakes since they ride on the rotor and need little fluid movement. On mine the small rear bowl is routed to the rear drums. Is this right?
Kevin LFD Inc. |
#17 |
Resident Absorber
I think your correct, this is true for most vehicles. heres a pic of of mine, I dont know if it will help considering Uncle's post.... mine is a 3/4 ton going to be a 1/2. ??
#18 |
Sleep-Deprived
The front bowl is for the front brakes for front disc brakes - consider the size of the pistons in the front calipers. As the pads and rotors wear, it will take a tremendous amount of fluid to displace the front pistons with their large bores compared to the relatively small pistons in the rear wheel cylinders.
1971 K/10 Long Fleetside 350/350 - 6" Lift 1969 C/10 SWB 292 - Sold It Last edited by 69_hafton; 05-21-2007 at 02:18 PM. |
#19 |
its all about the +6 inches
not only that, butthe disks use fluid to hold the adjustment, the rears use mechanical adjusters.
The large res is always for the disks, and the small is for the drums. |
#20 |
All Fixed!! ![]() Well I had enough so I went to the auto shop accross the street from my house to pick their brains. No luck! I had already tried every thing they said to do and even more. But they gave me the number of a power brake shop in Sacramento. I called and spoke with Sandy and told him everything I had tried and he was impressed with the extent I went to to find the problem. He then said if I had replaced the front rubber lines that I still have air in them. I said I fent I had got it all out but I was willing to try anything. So he then explained that the master cyclinder can not push enough volume of fluid to get the volume of air out of the front lines. He said to wire the front lines down to the frame so that they were lower than the bleeder's. So I did that and I also jacked up the A arms as far as I could to help out. I then put a bottle bleeder ion the raised up bleeder and pumped the pedal about 4 times untill the bottle was full and repeated for the other side. With my fingers crossed I pulled the screw driver out of the PSI port (used it to hold the valve from flipping while bleeding) and pushed lightly on the brake pedal and it stayed in place. So I then jumped on the pedal a few times and it stayed in place so I put the PSI switch back in and started it up and jumped on the brakes again and I have the best feeling pedal I have ever had in a vehical. The rear end is up on stands with the tires off but lugs holding on the drums so I put it in gear and hhit the brakes and guess what, they stopped ![]() Well thanks to all who tried to help and now I have learned a new little (very simple) trick. Kevin LFD Inc. |
#21 |
I have been following this as I have been fighting this exact same problem and have pretty much mirrored all the steps you have gone through to resolve the problem, with the same results you have had. I replaced the left front hose about the same time I replaced the master cylinder and booster so I think I know now why I can't get the light to stay out or the LF wheel to bleed. I can't wait to try your new trick, I bet it will work for me too.
Good work Kevin! Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
#22 |
Designated A-hole!
This needs to go to FAQ when everyone has seen it. Please remind me to move it.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
