07-02-2008, 11:12 PM | #1 |
Unknown wire in engine bulkhead connector ???
Heres a pic of the engine connector on our 1971 C20. Has 350/350 no AC.
Redoing harness for HEI, electric choke, and tach. Middle top wire - green - hard to see in pic is temp sender. Top left light brown wire goes to brake prop valve Big yellow wire goes to inline fuse and then to HEI (I replaced resitor wire) Bottom left dark bown wire is the unknown wire, it goes into the wire channel and then is terminated with a plastic male end and hidden inside the plastic wire run. I checked the fuse box side and it is connected and dissappers into the large bundlel of wires going up under the dash. So in must or could have a purpose. Middle botttom purple wire goes to the starter. Bottom right blue wire I added for tach connecton (was unused) (added matching connector to fuse block also) Does anyone know what that brown wire in the left botttom corner is for ?? I could remove it to clean up the harness a bit, but it is connected on the other side, kind of hate to remove it if it is good for some thing, even if not used now - could that be a factory tach wire ? - truck does not have factory tach. Thanks for your help.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 Last edited by Green Machine; 07-02-2008 at 11:14 PM. |
07-03-2008, 07:07 AM | #2 |
still buypickupparts
Re: Unknown wire in engine bulkhead connector ???
playing with mine myself, if I'm following you correctly the brown wire as you say, could it be Brn/WT brown with white stripe if so this is as in my bulk head also. it to me appears to be for "TSC" traction control solinoid. but i am sure someone else will respond besides me. mine did not go out to the engine bay but it is in the wire harness into the cab, either going to the starter switch or the plug that goes into the instument cluster
Its Gonna be a Great Day, I woke up this Morning. 72 SWB Fleetside freshly painted. putting a 94 LT1 with 700R4 tranny lowered 4 in the front 6 in the back 81 chevy half ton 350 89 Silverado 4x4 going ta church truck |
07-03-2008, 09:02 AM | #3 |
Great timing - I am looking to rebuild my engine harness as well - and can check when I get home...
What terminals did you use to add a wire to the plastic harness? Does a local place carry them or did you find them online? What substance is used to 'weather-proof' the connection on there? Last edited by lks dcvn; 07-03-2008 at 09:03 AM. |
07-03-2008, 09:08 AM | #4 |
TRACTION CONTROL SOLENOID???
there is however a transmission spark control an early form of lame emissions control devise that was normally disconnected within 5minutes of delivery of the trucks when they were new off the dealers floor
07-03-2008, 10:18 AM | #5 |
I get the terminals from NAPA , just have to have a guy that knows what you are talking about. Neat trick on removal from the harness side terminal is to cut at the top of the slot with a wire cutter, the "leg" falls off and you don't have to try to squeeze it to get it out.
I use "liquid electrical tape to seal everything back up. And I always solder anything new that I put in for extra assurance that the connection is good. Now - what is that wire for ????????????
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 Last edited by Green Machine; 07-03-2008 at 10:19 AM. |
07-03-2008, 03:32 PM | #6 |
Could it be for a generator dummy light?
------------------------------- '66 GMC Custom Fenderside LWB '90 IROC - L98 '97 1200C Sportster |
07-04-2008, 12:26 AM | #7 |
Is the wire Black with Brown? If so it should be going to the junction block that goes to the battery. This wire feeds into your Battery gauge in the dash. You do have gauges right? Does the Battery gauge ever move?
07-04-2008, 12:33 AM | #8 |
If its 16 guage plain brown it looks to me from the wiring diagrahm it should go to voltage regulator. See this thread, Post number #19.
http://67-72chevytrucks.com/vboard/s...d.php?t=185856 |
07-04-2008, 12:42 AM | #9 |
Scratch the last two things I said! I went out and looked at my truck. And I too have the same wire that is run in the cowl wire channel and terminated with a male wire connector that goes to nothing? I will ask GMC Paul. I bet he know!
07-05-2008, 12:54 AM | #10 |
The puzzle continues - nice to know there are more trucks with this "option".
But what does it do ?
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
07-06-2008, 07:44 PM | #11 |
I know it is not the transmission spark control. The TSC wire does not go through that bulk head. That wire is added separately.
I know, not much help. Sorry.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
07-07-2008, 09:00 PM | #12 |
We may have a winner here.
JimKshortstep4X4 wrote in another thread: "I don't have a picture but if you have the correct harness there should be a red wire and brown wire to be used for hooking up the tach. The red wire goes to the "Unfused ignition" terminal on the fuse panel. The brown wire goes to the terminal on the HEI marked "tach". The tach gets its ground from the case so once you have the two wires hooked up, you should be good to go." Could it be an unused factory tach wire?
07-09-2008, 05:57 PM | #13 |
could it be one of the wires you bypass when you hook up an internal reg, alternaor and remove the external regulator?
1967custom |
07-10-2008, 03:21 PM | #14 |
I've checked into this wire it's brown with a white tracer and isn't shown on any diagrams I've seen on here. Ive been redoing my harnesses and traced every wire on the truck.. that wire is connected to the back side fused blade of the radio fuse holder and is key power only. It does not come up behind the dash for anything, it just goes through the firewall connector and into the harness in the gutter above the engine. My guess would be a power antenna where it runs off the radio fuse. I left it there for exactly that reason.. figured I'd find one and install it someday.
07-10-2008, 03:50 PM | #15 |
It's on this diagram:
http://67-72chevytrucks.com/vboard/s...d.php?t=290757 It runs from the accessory position of the keyswitch to the bulkhead connector and appears to connect to the brown wire at the connector (that's why it's only on one side). My guess is it supplys power to the other side of the generator light to keep the bulb turned off when the key is in the accessory position. Or something like that anyway.
07-10-2008, 05:14 PM | #16 |
that diagram is the older trucks that brown/white tracer is the one for the generator dummy light on the dash, it gives the light a ground when you turn the key to the on position before you start.. same as the brake oil press and temp dummy lights (tan/green and blue at the key connector on the 70's). The brown/ white tracer he's talking about is only at the firewall connector but doesn't travel up the harness to the dash.
07-11-2008, 03:26 PM | #17 |
The wire in question is DEFINATELY for the TCS ( Transmission Control Spark ) solenoid that attached at the carb, the brown wire in question runs from the engine junction block connector to a female wire connector that then splits the wire into 2- 20g brown w/white stripe wires that then ran the rest of the way to the TCS solenoid at the carb.
The easiest method of eliminating this solenoid was unplug at connector you found and remove solenoid & its other harness's which are all separate of any wiring looms. GMCPaul |
07-11-2008, 11:28 PM | #18 |
Hmm. Thing must have changed from 70 to 71. My TSC wire is red and comes through the firewall separately. Learn something new every day.
07-15-2008, 11:31 AM | #19 | |
GMCPaul |
07-12-2008, 04:13 AM | #20 |
ERASER5 the solenoid attached to the carb that has a single PINK wire feeding it is a idle control solenoid not a TCS solenoid, the TCS solenoid has 3 wires that feed connect onto it at carb and 3 vaccuum connections on it. I have the original GM wiring diagrams that are far more comphrensive than the service manual or assembly manual wiring diagrams that break down each separate RPO option and there respective wiring.
GMCPaul |
07-13-2008, 11:41 AM | #21 | |
Sierra Grande Club
Anyone have this? s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
07-13-2008, 10:34 PM | #22 |
Not to be argumentative but, mine was a TSC system. Maybe it was dealer installed? See Pics
I even gave some of the parts to another member. I still have the relay, the transmission switch and the vacuum switch. No idle control was on my truck. The former red wire feed for the TSC is now the electric choke feed.
11-15-2014, 01:49 PM | #23 |
Old thread here but helpful in what I'm trying to track down.
It seems that my 72 Blazer (4 speed manual, 4x4, HEI, elec. choke) was wired for this as the pictures show. 4 wires coming out of the firewall (thick red, black, blue, brown/wt stripe), all going across to the passenger side. The red wire went nowhere..was just dangling loose behind the motor. The blue and brown/wt stripe wire went into a connecter and was joined with a green/wt stripe wire that was connected behind the block on the passenger side but went no where. The black wire went behind the engine and is connected to the top of the transmission, right by the 2 wires which I believe are for the back up lights. Everything seems to be running fine and I'd like to just remove these wires to clean things up, but 2 of them are actually connected. The black wire to the top of the transmission, and then the brown/wt stripe wire about 6 inches where it comes out of the firewall has a connection to a black wire, that runs back into the firewall. Now-since this brown/wt stripe wire wasn't connected to anything but that connecter on the passenger side, perhaps I can remove this? Hopefully my pictures below help.. |
03-12-2024, 07:41 PM | #24 |
I realize this is an old thread. But wondering where thet "unknown" brown wire gets its power from? I see that it gets power when the key is turned on but not sure if it is fused or not, mostly wondering as I would like to use it for my electric choke...
1971 C10 long bed, fleet side. 200R4 Auto, leaf spring rear. power steering. |
03-12-2024, 11:12 PM | #25 |
Looking at the 72 service manual wiring diagrams, which are a little hard to read but available here: https://67-72chevytrucks.com/vboard/...d.php?t=558016
It looks to me like in the cab that position on the connector next to the purple wire is a brown wire that goes to the radio fuse. So, with key on, remove the radio fuse (carefully) to verify the brown/white wire in the engine compartment that comes out of the connector next to the purple wire loses power. I think it would work fine for an electric choke. If it blows the 3A fuse, insert a 5A fuse. I don't think it blow at 3A will because I have powered my electric choke off the radio position and it worked fine, but I didn't have the AM radio blasting either. Too-long-didn't-read info below. Really it's more than you want to know. My advice is don't read it. Stop reading. Are you still reading? You are getting really sleepy... Instructions for reading the wiring diagram, from the manual (all upper case courtesy of Chevy): THIS DOCUMENT INCORPORATES A NEW MAPPING CONCEPT TO REPLACE LINES REPRESENTING WIRES. IT READS IDENTICAL TO MOST ROAD MAPS IN THAT NUMERIC STATIONS ARE ASSIGNED HORIZONTALLY AND ALPHABETIC STATIONS ARE ASSIGNED VERTICALLY. THEREFORE ANY COMBINATION OF NUMERIC AND ALPHABETIC CHARACTERS DESIGNATES A PRECISE LOCATION. TO ILLUSTRATE THE USE OF THIS CONCEPT LET'S USE THE HORN CIRCUIT. LOCATED IN THE UPPER LEFT HAND CORNER. AS AN EXAMPLE. THE NUMBER 29 CONTAINED IN THE RECTANGLE [29] REPRESENTS THE CIRCUIT NUMBER. IMMEDIATELY TO THE RIGHT APPEARS 12DG. THE NUMBER 12 SPECIFIES THE GAUGE OF THE WIRE AND DG IS THE ABBREVIATION FOR THE WIRE COLOR. DARK GREEN. SHOWN IN PARENTHESIS IS (24C). THIS IS THE ADDRESS IDENTIFYING THE LOCATION OF THE OTHER END OF THE WIRE. TO FIND THIS LOCATION. SIMPLY SCAN THE BOTTOM OF THE SHEET TO THE NUMBER 24 AND THEN SCAN VERTICALLY TO THE APPROXIMATE LOCATION OF C. THE CIRCUIT 29 SHOULD POP INTO VIEW.* TO FOLLOW THE CIRCUIT IN REVERSE, SIMPLY REVERSE THE PROCEDURE. FOLLOW THE LEAD IN WIRE OUT OF THE RECTANGLE [23] AT THE END OF THIS WIRE APPEARS (4S) 12DG AGAIN, THE NUMBER 12 REPRESENTS WIRE GAUGE AND DG THE WIRE COLOR. DARK GREEN. (4S) IS THE ADDRESS. TO FIND THIS LOCATION. SCAN THE BOTTOM OF THE SHEET TO STATION 4 AND SCAN VERTICALLY TO THE APPROXIMATE LOCATION OF S THE CIRCUIT 29 SHOULD BE IMMEDIATELY APPARENT. * it's like magic! Try it, you'll just love it. part of engine compartment part of in-cab wiring To view in better resolution download the 72 service manual or have a look at a paper copy which are available for cheap from any of the catalog vendors or ebay/amazon. Fuse panel info: https://67-72chevytrucks.com/vboard/...d.php?t=741245 |
