07-06-2008, 04:24 PM | #1 |
Keep Your Nose Clean
???Drum Brake Assembly???
Greetings folks. I was wondering if someone can post a diagram the rear drum brake assembly for a 72 with a GM 12 bolt rear end. Thanks Mister E
OR if there is a link with step by step...hey even better |
07-06-2008, 06:24 PM | #2 |
member #16
Re: ???Drum Brake Assembly???
Heres a pic if it will help.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
07-06-2008, 06:50 PM | #3 |
11-25-2023, 01:32 PM | #4 |
Thank You, Thank You, Thank You!
Trying to put it back together after a few weeks. YUP took both side off, Had to. Recovered my Dad's 63 that had been sitting in the same spot since 91 a few weeks ago. He had to replace the rear end back in the day. Had to pull the rear drums and brakes just to get it to roll up on the trailer. PB-Blaster, Heat and sledge hammer plus 4 hours equaled 1 read drum off. The right rear only took 2.5 hours. The fronts rolled somewhat. Some parts just crumbled, and a few I must have dropped and lost.
Take Care, Dave |
07-06-2008, 06:51 PM | #5 |
man that pic looks all to familar!!! i just re done my brakes this weekend, that e-brake cable is a pain, and if yr mech challenged as i am leave the other side alone until ya get the opposite side complete. i wore a path in the cement walking around lol, good luck and use jack stands for yr saftey
1969 rs 1966fastback 1969swbc/10 2006gt 1972swb4x4 |
07-23-2009, 02:03 PM | #6 | |
Tot Roddin'
EDIT... I missed this... this one was brought back from the dead.
Mr E, can you take a picture of the brackets you have there. I recently did this same install this past weekend (1st time I might add) but failed to get a shot from the bottom side of the brake system. If you can post a picture of the brackets I think we could walk you through it in a snap. As far as adding the e-brake after the drums are together, I think you are our of luck, unless you have extra small hands.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 07-23-2009 at 02:15 PM. |
07-06-2008, 06:53 PM | #7 |
see the shiny arm on the rear of his pic? right behinde the adjuster? thats where your e brake cable attaches not to the shiny arm but the arm right behinde it
1969 rs 1966fastback 1969swbc/10 2006gt 1972swb4x4 Last edited by va_tlc; 07-06-2008 at 06:54 PM. |
07-06-2008, 06:58 PM | #8 |
Can the ebrake cable be installed "later on"? I'm considering ordering one of those stainless ones from Inline.
07-06-2008, 08:17 PM | #9 |
umm i dont think so, well i guess you would have to take your brakes back off when your ready to install yr new ones, but that will be a snap after you do this once it wont take long, are you gonna go ahead and replace your wheel cylinders while your at it, there only like 10 bucks each.
07-23-2009, 01:08 PM | #10 |
The shoes are on backwards. The short lined shoe is the primary and goes to the front.
08-28-2011, 08:34 PM | #11 |
07-23-2009, 02:22 PM | #12 |
Here is the best drum brake assembly information on the planet...LOL
http://www.pbase.com/nufsed/drumbrake You can click on pics to make them bigger! I followed those instructions and I had not done a drum brake job in over 20 years....here's mine finished!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288 Last edited by Rack Man; 07-23-2009 at 02:28 PM. |
09-25-2017, 11:51 AM | #13 | |
Question: There's two different style springs for the nail heads, which one goes where? One is tapered in slightly, and is such a small difference that I wonder if it event matters? |
04-11-2011, 03:29 PM | #14 |
Thats the best link ever! thank you from all of those whom use it from this site!
08-28-2011, 07:11 PM | #15 |
Special brake drum thank you
I am about to build the rear brakes on a 67 gmc c2500 3/4 ton. The rear brakes, nor emergency brake cables etc... do not exist on the truck so this thread has been very helpful. Thank you so much for posting the link to the "Brake Drum Assembly How to" it is for a 6 bolt hub but the setup is the same as the 8 bolt floating hub from what I can tell. |
08-28-2011, 11:04 PM | #16 |
~Rest In Peace~
heres one
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
07-31-2013, 08:33 PM | #17 |
Can anyone get a photo of a 3/4 ton axle please. I can't seem to figure out why I mixed up the two brake struts and now I cant remember where they go besides at the top in between the brake shoes and under the wheel cylinders.
RoughKuntry 73 GMC 25 HUNDRED :Sold 79 GMC High Sierra 4x4 (Ma-Duece) :Sold 99 Chevrolet LS 4.8l/5 Speed Manual 4x4 :Selling 88 Chevrolet Burban 2500 4x4 :Buying |
04-30-2014, 12:09 AM | #18 |
Yep short linned shoe to the front
I BELIEVE IN JOHN 3:16 |
04-30-2014, 08:14 AM | #19 |
the truck is facing right in the photo. This is a picture of the right side of the truck. See the emergency brake cable?
I screwed it up first because I was working on the drivers side and didn't think about the fact this pic could have been of the passenger side. |
07-13-2014, 05:29 PM | #20 |
But Found Her 25yrs Later!
Does anyone know if all truck 12-bolts use the same shoes and such?
For example; does 63-72 all interchange or does the 73+ 12-bolt also interchange with the earlier 12-bolts?
10-01-2015, 10:09 AM | #21 | |
http://Www.67-72chevytrucks.com/vboa...d.php?t=114315
07-14-2014, 04:13 AM | #22 |
Thank You guys. yall were alot of help
10-01-2015, 11:32 AM | #23 |
I,am 99% sure all 12 bolt truck shoes are the same but I do know there are 2 different shoes and drums, 1 is h/d brakes other is std brakes.
10-01-2015, 06:23 PM | #24 |
Wow! A post that refuses to die. Been brought back from the dead five times.
Willie Swamp Angel Truckers '72 C10 Highlander People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. |
12-25-2015, 01:08 PM | #25 |
Lostmy65, also researching 12 bolt drum brake options, thinking of changing my 65 rear brakes to the newer 12 bolt heavy duty "JB 5" brake package. Just starting to see if it will work. Looks like the backing plates are different from earlier ones, offset to the center of truck to account for the wider brakes shoes. As notes here before by Keith Seymore, this is one of GM's really good brake systems, used as a design goal for trucks.
Any information/can it be done, on retrofitting rear JB 5 brakes to the early 12 bolt 2" brake shoe axles? Note: using '79 Dana 44 front axle, with the JB 5 brakes. I am planning to use the complete JB 5 brake system on '64 K10 build. Keeping all the original '64 parts so they could be retorfit later. Les |
