Easy Does It
What headers have you used?
Im thinking of getting a set of Hedman headers #69260. Im not sure what is the best for these trucks? short or long? or maybe someone knows of something else out there thats a good buy and fit? thanks
![]() Join Date: Sep 2006
Re: What headers have you used?
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
Wheelin' and Dealin'
my 400 small block has long tubes on it its tight in there but i just like them better im not sure what they are but they are hedmans i know that just not the type
1965 Chevy c-10 fleetside long bed with 06 gto LS2/T56 inside ![]() Porterbuilt Extreme front and rear 12bolt w/ eaton tru-trac 4:11 gears ![]() ![]() my build thread: ![]() http://67-72chevytrucks.com/vboard/s...=1#post2601700 |
60-66 Nut
The Hedman 69260's are made to fit this era of trucks so there really aren't any fitment issues. These headers are a bit less of a 'tuned' header than the ones for a later model truck such as the '73-'87's. The most common issue with using the later model headers is the clutch bellcrank or z-bar as some call it. If you are running an automatic this is a moot point. Using the later model headers with a manual trans often times requires modifying the bellcrank to clear the header tubes. Board member 64magoo used a set of Hookers on his truck that didn't require modifying. It's a close fit but it works...you can see his HERE
![]() Join Date: Mar 2008
I'm using the hooker headers too. I'm not sure if it's possible to install them without removing dipstick tube...but, a heads up to you; I snapped mine flush with the block on the original 283. This prompted me to pull the motor...and pulling the motor prompted installing a crate 350
![]() it all turned out nice. I went to the hardware store and built an adjustable pedal-to-zbar linkage with a couple heim joints and threaded rod. Original linkage was worn severely. Overall, I shortened the effective length of this link by about 1"...the clearance is fairly tight, and shortening this link seemed to help. ...you can follow my journey through link in my sig ![]() ![]()
Matt '65 LWB Fleetside '63 SWB Fleetside Last edited by ValveTubeHead; 07-29-2008 at 01:00 AM. |
#6 | |
thats a beautiful engine setup. looks real nice!!! i want mine to look like that.
Respect: 1. A feeling of appreciative, often deferential regard; esteem. 2. The state of being regarded with honor or esteem. 3. Willingness to show consideration or appreciation. When you fail to show consideration to others values you are showing disrespect. |
Some hooker supercomps I'm runnin right now. Great at stock height, but not sure what I'm gonna do now that I'm gonna lay frame.
got the exhuast shop to do mine that worked out cheaper for me in NZ
![]() Join Date: Aug 2005
I noticed a couple of BBC's. This thread might be useful for someone here. The framerail/engine clearances are the same (firewall is a bit off) from 60-66 to 67-72 for 2wd trucks. I ended up going with the Patriot Clipsters as can be seen on the 3rd page.
Easy Does It
Hey thanks for the response! I was thinking also of those hooker headers that were posted ,one of you said they had issues with the oil dipstick and plug wires, I have a new set of wires with the straight ends-I also was wondering if there were a big diffrence in performance between short vs long headers -or just using manifolds- there are some pretty cool tru-ram manifolds in the speedway catologe- what do you think? thanks
#11 | |
Dipstick tube was my downfall...the stuck bit in the block was essentially fused to it after 44+yrs; access to that area is pathetic while in vehicle... follow the link in my sig to "2008-0209 header fiasco" folder followed immediately by "2008-0216 engine pull" and look for the chewed nubbin stuck in the block ![]()
Matt '65 LWB Fleetside '63 SWB Fleetside Last edited by ValveTubeHead; 07-30-2008 at 02:16 AM. |
TexasBowhunter
VTH,
That motor is sweet! I just bought a set of ceramic Flowtechs. I have a 77 frame, so my set-up may not be helpful for yall.
Build in progress for son's first truck. |
I used some flowtech's on my small block. They fit real well. Also I used corvette spark plug wires so they went behind and under the exaust so you could not see them.. HEI even..
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 Last edited by Chevy Fleetside; 07-30-2008 at 11:08 AM. |
1962 C-10
I'm running the Heddmans on my '62. Fit great... I like the idea of the corvette wires, Fleetside! Looks cool. What brand are they? Do you have a part number? Thanks... Here's a pic of my 327..
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
#15 | |
#16 |
Easy Does It
Hey anthony ,those ceramic headers you got from summit are they model # sum-G9006-9? those are the ones I found on the website. you say they fit well? I have a 63' and the guy at summit said they were for a 66' but these have the same frames so I don't see why it would be an issue.Have you had any problems with them? thanks
#17 |
That be the ones. They aren't hitting anything now that I put the right motor mount perches in. If you want to lay frame, these aren't the headers for you since they hang below the frame. Some people have good luck with Chevelle headers if this is a problem for you.
I haven't driven my truck on the road yet, so I can't comment yet on how well they hold up. The flanges could be thicker, but they aren't exactly thin either. This is with my temporary Thrush glass packs and you can see how they hang down at an angle instead of being parallel to the ground, but I figure an exhaust shop can fix this easily enough when I take it in. I don't have any support hangers on the mufflers yet and they are sagging. This makes it look even worse than it really is. ![]()
------------------------------- '66 GMC Custom Fenderside LWB '90 IROC - L98 '97 1200C Sportster |
#18 |
1962 C-10
Cool! Thanks... I'll do that...
#19 |
Get some of those bolt on wire holder tabs so you can bolt them to the block to keep the wires away from the Headers.
#20 |
#21 |
Council of the Elders
Or... Get some Taylor SpiroPro cut-to-fit wires and make your own set... that way you know they will be right.
66 C-10 Stepside 350 Tuned Port Injection Tremec TKO-600 Truck Pictures: http://community.webshots.com/user/billydonn Truck Video: http://good-times.webshots.com/video...ost=good-times |
#22 |
There are two bolt holes in the block right between the middle spark plugs. They are 5/16 I believe. That is where you can bolt up something to hold the wires away from the headers. That is all I was getting at.
#23 |
Fleetside: Sorry if there's confusion. In my post I just meant you don't have to get a specific Corvette wire set. I wasn't disagreeing with you or anything. It is correct that you need some clips to hold the wires running under the headers away from them and closer the block. Holes for that may be 1/4 x 20, I'm not sure.
#24 |
Easy Does It
I used the summit brand ceramic headers and so far so good- they sound great. thanks for the help!
#25 |
I have these Summit branded Flowtech headers. They fit pretty decently and they're ceramic coated for under $200. Summit wires too:
