Old 11-22-2008, 01:24 AM   #1
voodoo44
sbc vortec heads 062 casting vs. 906 casting
I am looking to buy some vortec heads and was wondering if there is that much of a difference between the prefered 062 castings and the 96 castings.
voodoo44 is offline   Reply With Quote
Old 11-22-2008, 02:51 AM   #2
Captainfab
60-66 Nut
Re: sbc vortec heads 062 casting vs. 906 casting
It was originally written in Chevy High Performance magazine that the 906 castings had a restrictive hardened exhaust seat, but that was latter corrected. The heads I've seen personally, I couldn't see any difference between the two castings.
Old 11-22-2008, 09:45 AM   #3
voodoo44
Thanks....Anybody else have any views on this?
Old 11-22-2008, 11:19 AM   #4
shortbed70
shortbed70's Avatar
Both are good castings the 906 actually flow a little better I believe but its minimul at best. Both these heads are used on dirt crate motors and the 906 are put on the limited latemodel motors and the 062 are on the modifieds ones rated at 400 and the other 350 hp. Either way I think you'll be fine.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 11-22-2008, 01:38 PM   #5
fchava
fchava's Avatar
here is what was posted the the gm performance web site for Sallee: Read the red at the bottom:Small block Vortec heads, the head with huge performance gains that everyone is talking about.
This production Vortec iron cylinder head was first used on the 1996 pickup truck RPO L31 with fuel injection. The intake and exhaust port are very similar to Corvette 350 LT1 heads. America’s favorite high performance cast iron small block cylinder head offers big power and bigger value. The Vortec cylinder head's fast burn combustion chamber and high velocity ports combine to produce big horsepower out of the box. The Vortec head can be mildly ported for additional performance and can be milled up to .040” for increased compression ratio. This head includes 1.94” intake valves and 1.50” exhaust valves, springs and retainers, and pressed-in 3/8” studs. This head with compatible valves flows more air than bow tie head P/N 10134392, but the casting may not be as durable. It is a 20 to 40 horsepower bolt on increase over earlier cast iron small block heads. The water passages are the same as the original 1955 small block design. The eight-holt intake bolt pattern is totally different than the early model V8 12-bolt design. The Vortec head REQUIRES a Vortec style intake manifold due to its improved manifold mounting flange and gasket design and raised intake ports. It is not recommended that the heads be modified to accept early design intake manifolds (They will never match up right.). Use new manifold P/N 12366573, 12496820, 12496821, 12496822, or any others that we have listed below for correct matching to the Vortec head. Vortec heads fit all small block engines produced 1955 to present, excluding LT1/LT4 reverse coolant flow engines and current LS1 style “GEN 3” engines.
Technical Note: The valves seats in these heads can be machined to 2.02” intake and 1.60” exhaust. The rocker arm studs can be pinned or drilled and tapped 3/8”. These heads require the use of self-aligning rocker arms. (Casting P/N 10239906 or 12558062) (65 ft./lbs. head bolt torque)
Please Note: The casting number myth debunked:
The myth is that there is a difference in the head performance produced by these two castings.
This myth was started by some Magazines that didn't do their homework before publishing their articles.
This is the truth the whole truth and nothing but the truth. So sayith the Grand Wizard GM and his Apprentice Wizard GILBERT CHEVROLET.
10239906 casting has one large single hump.
12558062 casting has 3 small humps.
If either of these two castings have not been altered by GM and the part number changed from 12558060 or altered by someone else (previous owner, etc.), the heads produced by either casting will be identical except for the external cosmetic difference. Both castings are used to make the 12558060 Vortec heads which are the true unaltered Vortec heads.
Heads from both castings come out of their cast IDENTICAL except for the minor cosmetic external differences!!!!!!!!
fchava is offline   Reply With Quote
Old 11-22-2008, 10:06 PM   #6
voodoo44
Cool....Thanks for the info guys...but don't tell to many people the 906's go cheaper on ebay....lol.
