11-30-2008, 08:50 AM | #1 |
1961 crewcab
Where is my 60-66 Chevy or GMC vin number?
I see this question come up alot, so I thought I would do a post with pics on where to find your 60-66 chev/gmc vehicle identification number.
First up is the 60 t0 63 chev and gmc. The vin is located on the LH drivers door pillar. |
11-30-2008, 08:53 AM | #2 |
1961 crewcab
Re: Where is my 60-66 Chevy or GMC vin number?
Next up is the 64-6
The vin is located on the LH driver door roof rail. *** 64 gmc vins are located on the "b" pillar in the lh driver door frame*** Last edited by jonzcustomshop; 03-28-2009 at 06:32 PM. Reason: added info, and pic of 64 vin location |
11-30-2008, 08:57 AM | #3 |
1961 crewcab
On all 7 years you can also find the vin number on the left hand frame rail in front of the A arm.
There is also one stamped on the top of the LH frame rail under the cab, these shots are from my 65 1/2 ton long box. Notice how they only stamp the year, assembly plant, and the sequential serial # on the frame rail. the under cab shot is from a 66 frame I have, I have hi-lited where the vin is stamped, it is about 12 inches in front of the left hand rear cab mount on top of the frame rail ***** quoted from lil red 66!***** "The GMC trucks of the same years, did not have the VIN or any portion of the VIN stamped on the frame, in any place." Last edited by jonzcustomshop; 01-16-2010 at 06:19 AM. |
03-14-2011, 02:43 PM | #4 |
[QUOTE=jonzcustomshop;3000012]On all 7 years you can also find the vin number on the left hand frame rail in front of the A arm.
There is also one stamped on the top of the LH frame rail under the cab, these shots are from my 65 1/2 ton long box. Notice how they only stamp the year, assembly plant, and the sequential serial # on the frame rail How they stamp vin on -65 GMC frame rail. There s no assembly plant... Is there only year and sequential serial # on the frame rail? Any example pics? |
11-30-2008, 09:01 AM | #5 |
1961 crewcab
Here are some vin number decoders:
For Chevrolet) http://www.americanclassic.com/paint.htm For GMC) http://www.6066gmcguy.org/VinNumber.htm |
08-25-2011, 02:26 AM | #6 | |
Hollister, CA.
My VIN comes up with a 0 for the plant ?? 3C1540143136 SO: 3 = 1963 C = 2WD 15 = LWB 4 = Pickup 0 = ?? 143136 = Serial I was doughting my self, and went back out to the garage and checked the pillar again !!
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
08-25-2011, 11:49 AM | #7 | |
08-25-2011, 12:01 PM | #8 |
Thankyou jon for your time that you spent on this thread.
I will call you this weekend,maybe we can get together monday or tuesday morning. Kent. |
08-25-2011, 12:18 PM | #9 |
Chiefrocka this is out of the 1962 data book.
03-16-2016, 12:13 AM | #10 |
Just picked up my first C10 ('64 Chevy) and am checking the VIN out. Mine is 4C144H143128
Looking at this chart, I am not seeing "H" designation for the assembly plant as is in my VIN? |
03-16-2016, 01:21 AM | #11 |
03-16-2016, 07:59 AM | #12 |
03-16-2016, 09:21 AM | #13 |
Canadian VIN Plate located on the left hand front door jam
03-16-2016, 04:19 PM | #14 |
1961 crewcab
my 64 owners guide shows "H" as Fremont.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
03-16-2016, 07:01 PM | #15 |
11-30-2008, 09:05 AM | #16 |
1961 crewcab
Here is a decoder for Canadian 60-66 chev and gmc trucks:
This did not copy and paste like I wanted. You can also use this link: http://www.oeltd.net/doc/6066gmc/VINs/gmc-canada.htm pics of the chev and gmc vin tags are at the bottom of this page. 1960 - 1966 Canadian Chevrolet & GMC VIN Chevrolet Truck (1) The first digit indicates the model year (2) The second digit indicates the body style (3) The third & fourth digits indicate the series (4) The fifth & sixth digits indicate the model (5) The seventh digit indicates whether 4, 6 or 8 cylinder (6) The remaining numbers indicate the particular truck (7) The last letter indicates the GVW class GMC Truck (1) The first digit indicates the model year (2) The second digit indicates the body style (3) The third digit indicates GMC Truck (4) The fourth & fifth digits indicate the series (5) The sixth & seventh digits indicate the model (6) The eighth digit indicates whether 4, 6 or 8 cylinder (7) The remaining numbers indicate the particular truck (8) The last letter indicates the GVW class Body Style C - Conventional Cab P - Step Van / Package Delivery L - Short Cab / Low Cab Forward K - Four Wheel Drive G - Van (lightweight) GVW Class A - 6,000 & less B - 6,001 to 10,000 C - 10,001 to 14,000 D - 14,001 to 16,000 E - 16,001 to 19,500 F - 19,501 to 26,000 G - 26,001 to 33,000 H - 33,001 & over Model / Series Data 1960 - 1961 Chevrolet GMC Body Wheelbase GVW C1402 C91402 Flat Face Cowl 115 inches 5200 GVW C1403 C91403 Cab & Chassis C1404 C91404 Stepside Pickup C1405 C91405 Panel C1434 C91434 Fleetside Pickup C1503 C91503 Cab & Chassis 127 inches 5000 GVW C1504 C91504 Stepside Pickup C1534 C91534 Fleetside Pickup C2502 C92502 Flat Face Cowl 127 inches 7500 GVW C2503 C92503 Cab & Chassis C2504 C92504 Stepside Pickup C2534 C92534 Fleetside Pickup 1962 Chevrolet GMC Body Wheelbase GVW C1402 C91402 Flat Face Cowl 115 inches 5200 GVW C1403 C91403 Cab & Chassis C1404 C91404 Stepside Pickup C1405 C91405 Panel C1434 C91434 Fleetside Pickup C1503 C91503 Cab & Chassis 127 inches 5200 GVW C1504 C91504 Stepside Pickup C1534 C91534 Fleetside Pickup P1342 P91342 Forward Control Chassis 102 inches 5400 GVW P1345 P91345 Step Van Panel C2502 C92502 Flat Face Cowl 127 inches 7500 GVW C2503 C92503 Cab & Chassis C2504 C92504 Stepside Pickup C2534 C92534 Fleetside Pickup P2342 P92342 Forward Control Chassis 104 inches 10000 GVW P2345 P92345 Step Van Panel P2542 P92542 Forward Control Chassis 125 inches P2545 P92545 Step Van Panel P2642 P92642 Forward Control Chassis 137 inches P2645 P92645 Step Van Panel C3602 C93602 Flat Face Cowl 133 inches 10000 GVW C3603 C93603 Cab & Chassis C3604 C93604 Stepside Pickup C3605 C93605 Panel C4102 C94102 Flat Face Cowl 133 inches 14000 GVW C4103 C94103 Cab & Chassis C4302 C94302 Flat Face Cowl 157 inches C4303 C94303 Cab & Chassis 1963 Chevrolet GMC Body Wheelbase GVW C1402 C91402 Flat Face Cowl 115 inches 5000 GVW C1403 C91403 Cab & Chassis C1404 C91404 Stepside Pickup C1405 C91405 Panel C1434 C91434 Fleetside Pickup K1403 K91403 Cab & Chassis 115 inches 5600 GVW K1404 K91404 Stepside Pickup K1405 K91405 Panel K1434 K91434 Fleetside Pickup C1503 C91503 Cab & Chassis 127 inches 5000 GVW C1504 C91504 Stepside Pickup C1534 C91534 Fleetside Pickup K1503 K91503 Cab & Chassis 127 inches 5600 GVW K1504 K91504 Stepside Pickup K1534 K91534 Fleetside Pickup P1342 P91342 Forward Control Chassis 102 inches 5400 GVW P1345 P91345 Step Van Panel C2502 C92502 Flat Face Cowl 127 inches 7500 GVW C2503 C92503 Cab & Chassis C2504 C92504 Stepside Pickup C2534 C92534 Fleetside Pickup K2503 K92503 Cab & Chassis 127 inches 7600 GVW K2504 K92504 Stepside Pickup K2534 K92534 Fleetside Pickup P2342 P92342 Forward Control Chassis 104 inches 8500 GVW P2345 P92345 Step Van Panel P2542 P92542 Forward Control Chassis 125 inches P2545 P92545 Step Van Panel P2642 P92642 Forward Control Chassis 137 inches P2645 P92645 Step Van Panel C3602 C93602 Flat Face Cowl 133 inches 10000 GVW C3603 C93603 Cab & Chassis C3604 C93604 Stepside Pickup 7800 GVW C3605 C93605 Panel C3803 C93803 Cab & Chassis 157 inches 10000 GVW 1964 Chevrolet GMC Body Wheelbase GVW G1205 G91205 Panel Body 90 inches 4850 GVW C1402 C91402 Flat Face Cowl 115 inches 5000 GVW C1403 C91403 Cab & Chassis C1404 C91404 Stepside Pickup C1405 C91405 Panel C1434 C91434 Fleetside Pickup K1403 K91403 Cab & Chassis 115 inches 5600 GVW K1404 K91404 Stepside Pickup K1405 K91405 Panel K1434 K91434 Fleetside Pickup C1503 C91503 Cab & Chassis 127 inches 5000 GVW C1504 C91504 Stepside Pickup C1534 C91534 Fleetside Pickup K1503 K91503 Cab & Chassis 127 inches 5600 GVW K1504 K91504 Stepside Pickup K1534 K91534 Fleetside Pickup P1342 P91342 Forward Control Chassis 102 inches 5400 GVW P1345 P91345 Step Van Panel C2502 C92502 Flat Face Cowl 127 inches 7500 GVW C2503 C92503 Cab & Chassis C2504 C92504 Stepside Pickup C2534 C92534 Fleetside Pickup K2503 K92503 Cab & Chassis 127 inches 7600 GVW K2504 K92504 Stepside Pickup K2534 K92534 Fleetside Pickup P2342 P92342 Forward Control Chassis 104 inches 7000 GVW P2345 P92345 Step Van Panel P2535 P92585 Forward Control Panel Body 125 inches P2542 P92542 Forward Control Chassis P2545 P92545 Step Van Panel P2635 P92685 Forward Control Panel Body 137 inches P2642 P92642 Forward Control Chassis P2645 P92645 Step Van Panel C3602 C93602 Flat Face Cowl 133 inches 10000 GVW C3603 C93603 Cab & Chassis C3604 C93604 Stepside Pickup C3605 C93605 Panel C3803 C93803 Cab & Chassis 157 inches 1965 Chevrolet GMC Body Wheelbase GVW G1205 G91275 Panel 90 inches 5000 GVW G1206 G91276/td> Suburban (Std.) G1226 g91286 Suburban (Custom) C1402 C91402 Flat Face Cowl 115 inches 5000 GVW C1403 C91403 Cab & Chassis C1404 C91404 Stepside Pickup C1405 C91405 Panel C1406 C91406 Suburban (Panel Doors) C1412 C91412 W/S Cowl C1416 C91416 Suburban (End Gate) C1434 C91434 Fleetside Pickup K1403 K91403 Cab & Chassis 115 inches 5600 GVW K1404 K91404 Stepside Pickup K1405 K91405 Panel K1406 K91406 Suburban (Panel Doors) K1416 K91416 Suburban (End Gate) K1434 K91434 Fleetside Pickup C1503 C91503 Cab & Chassis 127 inches 5000 GVW C1504 C91504 Stepside Pickup C1534 C91534 Fleetside Pickup K1503 K91503 Cab & Chassis 127 inches 5600 GVW K1504 K91504 Stepside Pickup K1534 K91534 Fleetside Pickup P1342 P91372 Forward Control Chassis 102 inches 5400 GVW P1345 P91375 Step Van Panel C2502 C92502 Flat Face Cowl 127 inches 7500 GVW C2503 C92503 Cab & Chassis C2504 C92504 Stepside Pickup C2512 C92512 W/S Cowl C2534 C92534 Fleetside Pickup K2503 K92503 Cab & Chassis 127 inches 7600 GVW K2504 K92504 Stepside Pickup K2534 K92534 Fleetside Pickup P2342 P92372 Forward Control Chassis 104 inches 7000 GVW P2345 P92375 Step Van Panel P2535 P92585 Step Van Panel (Sq. Front) 125 inches P2542 P92572 Forward Control Chassis P2545 P92575 Step Van Panel P2635 P92685 Step Van Panel (Sq. Front) 137 inches P2642 P92672 Forward Control Chassis P2645 P92675 Step Van Panel 1966 Chevrolet GMC Body Wheelbase GVW G1205 G91275 Panel 90 inches 5000 GVW G1206 G91276 Suburban (Std.) G1226 G91286 Suburban (Custom) C1402 C91402 Flat Face Cowl 115 inches 5000 GVW C1403 C91403 Cab & Chassis C1404 C91404 Stepside Pickup C1405 C91405 Panel C1406 C91406 Suburban (Panel Doors) C1416 C91416 Suburban (End Gate) C1434 C91434 Fleetside Pickup C1503 C91503 Cab & Chassis 127 inches C1504 C91504 Stepside Pickup C1434 C91434 Fleetside Pickup K1403 K91403 Cab & Chassis 115 inches 5600 GVW K1404 K91404 Stepside Pickup K1405 K91405 Panel K1406 K91406 Suburban (Panel Doors) K1416 K91416 Suburban (End Gate) K1434 K91434 Fleetside Pickup C1503 C91503 Cab & Chassis 127 inches C1504 C91504 Stepside Pickup C1434 C91434 Fleetside Pickup P1342 P91372 Forward Control Chassis 102 inches 5400 GVW P1345 P91375 Step Van Panel (Sq. Front) C2502 C92502 Flat Face Cowl 127 inches 7500 GVW C2503 C92503 Cab & Chassis C2504 C92504 Stepside Pickup C2534 C92534 Fleetside Pickup K2503 K92503 Cab & Chassis 127 inches 7600 GVW K2504 K92504 Stepside Pickup K2534 K92534 Fleetside Pickup P2342 P92372 Forward Control Chassis 104 inches 7000 GVW P2345 P92375 Step Van Panel P2535 P92585 Step Van Panel (Sq. Front) 125 inches P2542 P92572 Forward Control Chassis P2545 P92575 Step Van Panel P2635 P92685 Step Van Panel (Sq. Front) 137 inches P2642 P92672 Forward Control Chassis P2645 P92675 Step Van Panel C3602 C93602 Flat Face Cowl 133 inches 10000 GVW C3603 C93603 Cab & Chassis C3604 C93604 Stepside Pickup C3605 C93605 Panel C3803 C93803 Cab & Chassis 157 inches Engines Available 1960-62 235 -6 Cyl. (std.) 283 - 8 Cyl (opt.) 1963 230 - 6 Cyl (std.) 292 - 6 Cyl (opt.) 283 - 8 Cyl (opt.) 153 - 4 Cyl (P1342/P91342) 1964 153 - 4 Cyl (Std. G1205/G91205 & P1342/P91342) 194 - 6 Cyl (Opt. G1205/G91205) 230 - 6 Cyl (Std.) 292 - 6 Cyl (Opt.) 283 - 8 Cyl (Opt.) 1965 153 - 4 Cyl (Std. G1205/G91275;G1206/G91276;G1226/G91286;P1342/P91372;P1345/P91375) 230 - 6 Cyl (Opt. G1205/G91275;G1206/G91276;G1226/G91286;P1342/P91372;P1345/P91375) 230 - 6 Cyl (Std.) 292 - 6 Cyl (Opt.) 283 - 8 Cyl (Opt.) 1966 194 - 6 Cyl (Std. G1205/G91275;G1206/G91276;G1226/G91286;P1342/P91372;P1335/P91385) 230 - 6 Cyl (Opt. G1205/G91275;G1206/G91276;G1226/G91286;P1342/P91372;P1335/P91385) 250 - 6 Cyl (Std.) 292 - 6 Cyl (Opt.) 283 - 8 Cyl (Opt.) 327 - 8 Cyl (Opt.) Option engines were not available on all models Page last updated: 12/19/2003 00:00:00 Last edited by jonzcustomshop; 11-30-2008 at 09:30 AM. Reason: added info and pics |
03-15-2014, 01:52 AM | #17 |
Im having problems decoding my vin here it is if anyone can help 2C2530125048 I know it's a 62 3/4 ton fleetside long bed with a 235 straight 6 ,3 peed manual tranny I suspect the bed to be a 66 , it has holes for back up lights , any ideas where it was made and what type of bed it had and if it's a c 10 or c20 , any ideas ?
11-30-2008, 09:26 AM | #18 |
1961 crewcab
According to the 6066gmcguy the panel and suburban vins are located on the Lh drivers door pillar, roof pillar, rear driver door pillar, or on the footwell by the GVW tag.
I have seen all 3 of the door pillar vin placements, but did not take pics. If you have some pics to add please do. |
11-30-2008, 10:02 AM | #19 |
thanks for the info, i was gonna ask this.
The price of cool aint cheap. |
11-30-2008, 12:37 PM | #20 |
Junior Member
Great Post! Keep up the good work.
11-30-2008, 01:02 PM | #21 |
excellent thread!
CHEVY ONLY |
11-30-2008, 01:40 PM | #22 |
Great Job!
Maybe one of the mods should sticky this.
12-01-2008, 09:41 PM | #23 |
Hollister, CA.
Very nice write up !!!
I waved my wand, and have made it STICK !!!
11-30-2008, 01:38 PM | #24 |
jonzcustomshop:
Thanks for your tireless contribution to this subject. Perhaps this will become a sticky. In any case, you have covered the subject very well and I appreciate your efforts. PS...you must have had a house full of company over the holidays and decided to "hole-up" on the computer to pass the time. Thanks again for your contribution. |
12-02-2008, 10:57 AM | #25 |
1962 C-10
Excellent post! Nice work, jon.
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
