01-30-2009, 10:02 AM | #1 |
"Where were you in '62?"
8.8 Rear End that will mount up to a 1962 Chevy Pickup
Guys,
I have a Ford 8.8 Rear End that will mount up to a 1962 Chevy Pickup. She will bolt straight on! I used this on my truck before I changed to the 9 inch Ford Rear that I have now. Nodular iron. The rear end is in good condition and has new brakes. The gear ratio was 3.08:1 Good road gear. Tight! No play in it. This came out of a police interceptor car. $100.00 green stamps! Includes everything you see in picture! Also will throw in the matching drive shaft in with it also. Buy her, slap her on, roast'em slap off! Well with a 3.08:1 you want be able to roast'em, but you will save gas! Thanks,
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 09-02-2014 at 03:47 PM. |
02-03-2009, 11:47 PM | #2 |
Re: 8.8 Rear End that will mount up to a 1962 Chevy Pickup
posi?
CHEVY ONLY |
02-04-2009, 05:44 PM | #3 |
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
02-04-2009, 04:00 AM | #4 |
I was miffed at 8.8, but now I see it is a blue oval, so I know why I didn't recognize the title. Sounds like a great deal, but I am afraid if I mix breeds my bowties will boycott me. Good luck with the sale.
02-04-2009, 06:15 PM | #5 | |
My Original rear end was wore out and this was a perfect fit for the time. Well I quess I can say I have a mix-breed! A mutt! But you know..... She's my mutt; and by gosh I love that ole truck! Ha Ha. She only has a Ford Mustang IFS, and a Ford Rear End. But....... Don't you just love seeing those Ford Trucks with Chevy Engines in them!!!!!! It's like they know better!!
02-04-2009, 07:16 PM | #6 |
hmmm.....thought all cop cars were posi....
CHEVY ONLY |
02-04-2009, 08:56 PM | #7 |
I asked my father and he thinks it was a 1985 Ford LTD Crown Victoria.
Mid 80's.... Some were posi, and some were not. Some had disk brakes, and some had drums. My rear end has Drum Brakes. Some had bigger brakes as well. Not an expert, but just have alot of Ford Buddies! Sorry, I still show my CHEVY PRIDE! Mustangs were also different. Depending on Ford/Chevy/Dodge http://en.wikipedia.org/wiki/Ford_Cr...ce_Interceptor http://en.wikipedia.org/wiki/Ford_LTD_Crown_Victoria
02-05-2009, 02:02 AM | #8 |
Good stuff...thanks for sharing.
02-05-2009, 07:02 AM | #9 |
History
Ford began using the 8.8" axle in Rangers circa 1986 on "incomplete vehicles" aka "chassis cabs", but the 8.8" axles only became common in Rangers with the introduction of the 4.0L V6 in mid-1990. It began appearing in Explorers (and Mazda's Navajo twin) in 1991. It has also been used in 4.0L Aerostars (2wd ONLY, the 4.0 AWD Aerostars, strangely, are equipped with the 7.5" axle), From mid'84-up F-150 (Except for 5.4liter "Lightnings and Some 4x4 Supercabs which are equipped with the heavier-duty 9.75" rear axle) '84-1/2 on Full-size Broncos, and E-150 Econoline vans. The 8.8 is also used in other Ford products such as Mustangs, Thunderbirds ("solid axle" '87-88 with 2.3 turbo engine and 5.0 "Sport" models), Crown Victorias and their equivelent Mercury and Lincoln products. However, because of their different suspensions, they make undesirable choices for swapping into a Ranger (unless you're looking to also swap to a four-link rear suspension for airbags and such). An IRS version also appeared in the '89-97 Thunderbird, Mercury Cougar, (Though there is also a 7.5" IRS in some V6 cars), the Lincoln Mark VIII and finally a very similar IRS suspension was adapted for the Mustang Cobra. A wide range of gear ratios is available, from 3.08's up to 5.13's. An equally wide array of differentials is also available from open carriers to limited slips to lockers and spools. 8.8" axles can have either 28-spline or 31-spline axles. All car applications use 28-spline axles, all truck applications use 31-spline axles. axle shafts EXCEPT Rangers, which use 28-spline axles, however even Exceptions have Exceptions, FX4 Rangers 99-current with 4.10 or 4.56 axle ratios are built with 31-spline axles. Gear sets are interchangeable between axles, regardless of the spline count. Differentials, however, are not.
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 08-07-2012 at 02:55 PM. |
02-07-2009, 09:33 PM | #10 |
I measured the rear today 54 1/2.
I had 15X10 Cragers and Hides on them when I had her on my truck before the 9 was shoe horned.
06-05-2009, 05:57 PM | #11 |
ttt
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 08-01-2009 at 02:07 PM. |
08-01-2009, 02:00 PM | #12 |
TTT
This post had a few spider webs on it....... So I bumped her back up. Anyone????????? Fish ain't bit'in Well maybe somebody is in need of a good rear end....... She is just waiting the be snatched up.....
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 08-07-2012 at 02:54 PM. |
08-14-2009, 07:58 PM | #13 |
chevy bolt pattern or ford?
08-14-2009, 09:16 PM | #14 |
She's all Ford 5 lug Bud.
02-12-2010, 08:14 PM | #15 |
TTT.
Any interests?
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 08-07-2012 at 02:56 PM. |
03-06-2010, 04:04 AM | #16 |
Damn, wish you weren't so far away!
1963 Big Back window short fleet |
03-06-2010, 09:19 AM | #17 |
See...
That's the thing. I have alot of good stuff to sell, but it cost to much to ship. Which you could not ship this, but you get what I mean. Just tears me slap up. Oh well....
03-06-2010, 01:36 PM | #18 |
What all are you selling? May be worth the drive!
03-06-2010, 10:17 PM | #19 |
Just a few stuff Ha Ha:
STEVE’S AUTO STREET ROD SHOP 142 Manville Dr Kings Mountain, NC 28086 (704) 734-0269 http://67-72chevytrucks.com/vboard/s...d.php?t=351000 steves_auto_street_rod_shop@hotmail.com 60-66 chevy under seat jack holders http://67-72chevytrucks.com/vboard/s...d.php?t=349419 "1962 Chevy C-10 Stepside Stock Gas Tank" http://67-72chevytrucks.com/vboard/s...d.php?t=355704 1960-1964 rebuilt 1/2 ton 3 speed transmission http://67-72chevytrucks.com/vboard/s...d.php?t=349416 1960-1962 Chevy C-10 Spare Tire Holder http://67-72chevytrucks.com/vboard/s...d.php?t=349422 1962 Chevy C-10 1/2 Ton Rear Brake Drums with Shoes http://67-72chevytrucks.com/vboard/s...d.php?t=349423 (2) KELLY CHARGER steel belted radial tires P295/50R15 mounted on 15X10 Cragar S/S Super Sport Wheels For Sale http://67-72chevytrucks.com/vboard/s...d.php?t=371197 (2) Michelin Sport XGT P245/60VR14 Tires mounted on 14x8 Rocket Racing 5 Spoke Spinner Wheels http://67-72chevytrucks.com/vboard/s...d.php?t=371199 '69-70 Chevy C-10 LS9 350 Engine Parts http://67-72chevytrucks.com/vboard/s...d.php?t=358698 1980--84 chevy 305 heads, cast # 14014416 http://67-72chevytrucks.com/vboard/s...34#post3843934 "1973 Chevrolet Nova", DOORS/BUMPERS/QUARTER GLASS/GRILLE/ETC http://z3.invisionfree.com/Shadyside...showtopic=9099 1973 Chevy Nova additional Parts For Sale, L & R Quater Glass W/ Regulators, Doors http://z3.invisionfree.com/Shadyside...showtopic=9551 Ford Stuff: 351 WINDSOR "Police Interceptor" HEADS HEAD CASTING #: D9OE-AB 1.840 INT 1.500 http://z3.invisionfree.com/Shadyside...showtopic=9421 FORD 351 WINDSOR "Police Interceptor" ENGINE BLOCK CASTING #: D9AE-6015-ED-18 http://z3.invisionfree.com/Shadyside...showtopic=8583 1976 MUSTANG II MISC PARTS TAKE A GANDER INSIDE http://z3.invisionfree.com/Shadyside...showtopic=9433 1976 MUSTANG II MISC PARTS TAKE A GANDER INSIDE http://z3.invisionfree.com/Shadyside...showtopic=9433 1976 FORD MUSTANG II V6 4 SPEED TRANSMISSION http://z3.invisionfree.com/Shadyside...showtopic=9098 1964 FORD FALCON FUTURA COMPLETE STAINLESS TRIM http://z3.invisionfree.com/Shadyside...showtopic=9097 Ford 8.8 Rear End Differential That will mount up to a '62 Chevy Pickup http://z3.invisionfree.com/Shadyside...showtopic=9420 1975 Ford F-100 Pickup Truck Parts L & R Door Hinges, Door, Bumpers Etc. http://z3.invisionfree.com/Shadyside...showtopic=9552 7 hours 35 mins http://maps.google.com/maps?f=d&sour...09&ie=UTF8&z=7
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 03-06-2010 at 10:40 PM. |
03-07-2010, 01:18 AM | #20 |
I would love to have the rear axle and those cragars just don't want to drive seven hours. Wanna come up and have a beer?
03-12-2010, 09:21 PM | #21 |
Hey 1Bad, how can I adapt my 6 lug Ralley rims to your Ford 5 lug axle? Is there an adaptor made? I'd love to put a 3.08 in my '63
ABOZ |
03-12-2010, 09:50 PM | #22 | |
There are several company's that sell the adapters out there bud. Here is one: http://adaptitusa.com/5x135to6x135wheeladapter.aspx http://www.ezaccessory.com/Articles.asp?ID=136 Thanks,
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 03-13-2010 at 10:12 AM. Reason: I love to edit. |
03-13-2010, 10:41 AM | #23 |
Don't forget Bud,
I have those Cragers still for Sale. I used to have them on that rear end. 12" Section 15"X10" 10 1/2 Tread 3 3/4 Back Spacing 4 1/2" & 4 3/4" & 5" Bolt Center http://67-72chevytrucks.com/vboard/s...d.php?t=371197
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 03-13-2010 at 10:46 AM. Reason: http://public.bay.livefilestore.com/y1pQljgne9PismXw6uoDNMLfzGABpYVAGOWY1jeiFmLzS3Wt29BCtW0kteRYMtjHdijjXVkH-_SNdvLz3c0tPXrnA |
05-19-2010, 03:09 PM | #24 |
07-19-2012, 03:22 PM | #25 |
I need somthing like that rear end, don't know where you are , can you tell me that and I am new to the sight. I just became a member and it's dirtyfingers. I can be called at 2608296987 I will try to figur out how to get through the sight to contact people. Thanks
