'92 4.3 Hot start problems
I have been having intermitment start problems, it only seems to be when it is hot, I have a new Accel distributor, checked everything I can think of the only thing elese it could be is the computer. I have a friend that has a parts '92 w/ 4.3 I am going to try his computer if it is the same. How many different computers were there for the 4.3.
Thanks for your help, Bruce |
BAD BOW-Silverado XST
Re: '92 4.3 Hot start problems
Is it a starter problem? Is the timing set to zero? Clean the TBI really good with a cleaner. Run some seafoam through the fuel tank.
New starter, cranks over fine, noid light hooked to injectors does not light then let set for a about an hour it will start.
Timing is set right. TBI is clean. New fuel pump and filter, tank clean. |
Well it is not the computer, it would not start this morning and I changed the computer and it still did not start. Let it set for over a half hour and it started. I am getting sick of not having a dependable truck. Any help would be greatly appreciated.
Thanks Bruce |
Trucks N Tranzams
It sounds like a loose or intermitant connection somewhere. If it has a firewall connection block, I'd start there.
![]() '68 Chevy LB 383 TH400/GV/373 posi '56 Chevy 4WD SWB '64 Chevy short stepside '79 Trans Am 455/TH2004R/12blt/4whldisc 95 Kia (Wifes car) 2002 S-10 extended cab pickup "God punishes small sins immediately" Last edited by Arad68; 05-21-2009 at 10:53 PM. |
