09-28-2009, 08:28 PM | #1 |
'69 K10 Rebuild
After several phone calls to an ad on Craigslist, I thought I had finally found a good deal on a '69 K10 that was meant to be a daily driver. After a two and a half hour drive with a truck and trailer (thankfully.....I was told I could drive it home) this is what I saw.....
09-28-2009, 08:32 PM | #2 |
Re: '69 K10 Rebuild
Here's an interior shot and a motor shot too. Long story short, the motor was junk. Both doors were beyond repair. The cab floor was eaten up with rust as well as both sides inner & outer rockers gone.
09-28-2009, 08:38 PM | #3 |
Re: '69 K10 Rebuild
Got it back to the shop to access the repairs......
09-30-2009, 08:43 AM | #4 |
Re: '69 K10 Rebuild
Got the front end tore off, more rust than anticipated. Motor has to be pulled too.
09-30-2009, 08:47 AM | #5 |
Re: '69 K10 Rebuild
Motor pulled. Startring to repair the firewall. Over the last 40 years there have been multiple holes made in the firewall that will need to be fixed. Welded up the original hole for the wiring harness, as I will be installing a new painless harness. The complete area where the blower motor mounts was gone. After cutting and welding in a new peice, it was spread with bondo as well.
09-30-2009, 08:50 AM | #6 |
Re: '69 K10 Rebuild
Starting to rip into the interior here. Both side floor pans were rusted pretty bad. As well as the rockers.
09-30-2009, 11:48 AM | #7 |
Re: '69 K10 Rebuild
Damn, your not messing around.....thats a lot of progress in a short time!....
Looking good, keep it up!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288 |
09-30-2009, 12:33 PM | #8 |
Re: '69 K10 Rebuild
The actuall build started awhile back. I'm just now getting the pics on here, but thanks Rack Man!
09-30-2009, 10:54 PM | #9 |
Re: '69 K10 Rebuild
Keep up the great work! I am not sure you can get that seat in without taking the tank out. You may be pushed up against the steering wheel.....I think. I would be interested in what you find out!
10-02-2009, 12:12 PM | #10 |
SWB 4x4 Collector
Re: '69 K10 Rebuild
Making some good progress. IT was definitely a project for sure. It appears to have a later frame 73+ frame from the looks of it. Keep up the progress. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
10-04-2009, 07:14 PM | #11 |
Re: '69 K10 Rebuild
Good eye Trevor! At some point in time someone has placed the body on a newer frame. It has a corprate 12 rear, and a corprate 10 front, so the best that we can figure is it is towards the closer side of the 73 - 87 frame. Thanks for the encouragment!! And yes.....it is definently a project. Oh well, someday it will be a daily!!!!!
12-19-2009, 10:27 AM | #12 |
Re: '69 K10 Rebuild
Your progress is giving me motivation. For what it is worth, I've decided to move my tank outside the cab. There a lot of aluminum tank suppliers available and many will make a custom tank for you if you're interested. Try Boyd welding - he can hook you up with a good deal.
