10-24-2009, 07:41 AM | #1 |
Project: Agent Orange
Finally got down to one project, took a few years but I'm here now.
Build overview: To create a dependable, capable wheeler that will drive comfortably down the highway at 70+ mph. * This build is possible only by the donations of several different blazers & trucks * Parts of the project: Chassis came from my very first blazer that I tore into back in 03. Tub came from Texas where it had been rolled when it was only three years old, which equaled zero rust but major body damage. Firewall, windshield frame, pass quarter & outter rocker were all toast, so I needed a donor and found this to use. Which led to this, it's first 'storage event'. Next time it saw the light of day & work. |
10-24-2009, 07:42 AM | #2 |
Re: Project: Agent Orange
This got accomplished.
Put up for sale the 1st time. The deal fell through thankfully and work commenced. Factory floor seam & windshield frame work. Last edited by vtblazer; 10-24-2009 at 07:52 AM. |
10-24-2009, 07:42 AM | #3 |
The tedious blazer windshield frame graft to the truck firewall.
First time it looked almost whole, yet worlds away from being complete. Last edited by vtblazer; 10-24-2009 at 08:00 AM. |
10-24-2009, 07:43 AM | #4 |
Another winter's storage.
Found a good used set of 37" GoodYear MTR radials. Found a set 1-ton axles out of an '86 CUCV. Had the H2's from another truck. Digging it out yet again. Last edited by vtblazer; 10-24-2009 at 08:30 AM. |
10-24-2009, 07:43 AM | #5 |
Additional ingredients will include:
355 crate motor with a Tuned Port Injection set up from an '86 Vette & serp belt assembly. 700r 4-spd auto transmission coupled to a 241 transfer case. (poor mans doubler that nets a 79:1 crawl ratio) 1-ton axles with 4:56 gears - Front will have an ARB, rear is locked via Detroit 37" GoodYear MTR's on H2's (maybe 40's if the budget allows) Full cage & after-market suspension seats, yet to decide on the brand. Brought it back to the home shop where it will stay & be completed. Began the task of making it whole. Test fit the doors, do or die time right here. Passengers inner kick panel had some real issues. Last edited by vtblazer; 10-24-2009 at 12:24 PM. |
10-24-2009, 07:44 AM | #6 |
POR'd all the flash rust I could find, wiper area in the cowl, under the dash and around the transmission tunnel too.
On to primer and showing you some of the connection points. Looks just like every other tub now... Okay, I think that gets everything basically updated to the last couple post's on the other two threads I had going...whew. Last edited by vtblazer; 10-24-2009 at 12:53 PM. |
10-24-2009, 09:12 AM | #7 |
Subscribed. Love seeing your work! Still doing research on my end.
10-24-2009, 09:26 AM | #8 |
Wow, that's how to start a thread! Awesome work VT! I'm on board!
10-24-2009, 12:13 PM | #9 |
Nice job are you going to need the speaker and cover that is hanging under the dash I need one if want to sell it.
1972 GMC Jimmy 1/2 4X4 4wheel camper 1970 GMC Jimmy 1/2 4X4 350 1969 Chevy Blazer 1/2 4X4 307 1967 chevy LWB 3/4 396 |
10-24-2009, 01:16 PM | #10 |
New stuff, new since the old threads.
Swapped over the axles. The brown tub had 4" front springs in the front & 4" lift blocks with stock springs in the rear. Left the springs, pulled the blocks. Thing's will level out once I transfer over the DIY shackle flip. Some serious asshang goin' on right now though... How it sat once we pulled to top off. The rebuilt front Dana 60 axle with an ARB cover. Tire size comparision prior to the swap. Stripping out the old frame that was under the '69 tub. Major changes need to happen here. |
10-24-2009, 01:45 PM | #11 |
Dr. Frankenstein would be proud of your creation, nice work...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
10-24-2009, 02:17 PM | #12 |
Nice job on the tub rebuild! I also have a nearly rust rust free tub that was rolled decades ago. I picked up a blazer firewall clip with intentions of doing the same thing you did. We'll see if I live long enough to get all of my projects done. LOL!
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
10-24-2009, 02:27 PM | #13 |
Agent Orange. Love it. You gonna drive it or trailer it to Blazer Bash?
10-24-2009, 03:49 PM | #14 |
*****in! I like the "quick progress" threads where I can see years of work in 5 minutes! A complete reversal of my stuff, where I can see 5 minutes worth of work in years!
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
10-24-2009, 03:55 PM | #15 |
WOW! No rust! Not sure that I'll ever see a Blazer/Jimmy up close that doesn't have rust on it.
How difficult was it to get the firewall/floorpan/torque box all back together? How did you go about welding them? Did you have to drop the torque box some to weld the firewall and floor together? How'd you do it?? I'm not gonna be able to sleep til I know how you did it! |
10-24-2009, 04:29 PM | #16 | |
The floor seam is more like a lap joint as seen in the last two pics. Last edited by vtblazer; 10-24-2009 at 04:31 PM. |
10-24-2009, 04:34 PM | #17 |
Where did you weld them together? Like the factory spot welds?
10-24-2009, 04:45 PM | #18 |
That as well as the physical floor seam.
Up the firewall brace too and don't forget, it's also welded at the 'a' pillars. |
10-24-2009, 04:19 PM | #19 |
10-24-2009, 05:48 PM | #20 |
GEARHEAD
I thought you were going to swap this body onto the gray chassis. What's happening with that now?
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
10-24-2009, 06:39 PM | #21 |
The '69 tub was sold as a tub & only the tub, chassis is going back to the guy I got it from who's discovered he needs one now, all the rest of the parts I've gleaned onto over the years for my own personnel build will be installed into this one.
10-25-2009, 08:05 AM | #22 |
Lizard Skin spray in liner offers both sound & heat control, plus it's paintable.
This is the next step, masking has started... This is the gun that comes with the jobber kit. This is my new carpet. |
10-25-2009, 09:36 AM | #23 |
need reviews on that stuff... where did you buy from as well?
10-25-2009, 10:18 AM | #24 |
Can't wait to retire!!
Wow...looks great!
How's the back feeling?
2009 4x4 Chevy Crew Cab 6.0 1989 4x4 Siverado (270,000 miles) 1972 4x4 Blazer 2007 Chevy Cutaway 1 ton 1970 Corvette (sons project) RIP - CLR 10/11/09 |
10-25-2009, 11:44 AM | #25 |
When I spray it, you'll hear all about it I'm sure, good/bad or indifferent.
Bought it on-line, directly from Lizard Skin. Sounds good as of now, no harmful chemicals & it cleans up with water. Better, the Advil is helping some... Got a little worried this morning though, I was barely able to reach down & lift the toilet seat to go wee when I got up. Last edited by vtblazer; 10-25-2009 at 11:45 AM. |
