Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 06-24-2010, 02:14 AM   #1
67chevy1series
67chevy1series's Avatar
how to get your motor ready for paint
i dont have a presure washer so that out of the question so any opinions will be needed
67chevy1series is offline   Reply With Quote
Old 06-24-2010, 08:53 AM   #2
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: how to get your motor ready for paint
Simple green will help blast away the grit and grime... other have used oven cleaner but I would only recommend if the motor is out of the truck.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 06-24-2010, 02:31 PM   #3
67chevy1series
well my plan is to get like 5 different cleaners then use all five one right after the other so i need three more
Old 06-25-2010, 01:36 AM   #4
67chevy1series
thanks man i used that stuff today and it was really good i got one side completly ready for paint and almost the other side as well
Old 06-25-2010, 09:11 AM   #5
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
you can't do one side at a time..IT NEEDS TO BE STUPID CLEAN or your wasting your time and $$$...
I sprayed mine with Castrol Super clean let it set for a bit while you poke away at the bad spot with a putty knife and a wire brush...wear gloves (I work construction so my paws are pretty tough ..but not that tough) I did it 2 or 3 times like that it will get it very clean...then let it dry....the next day wire brush as much as you can then hit it with a can of oven cleaner and let it sit for an hour the acid will remove whats left and rinse with soap and lots of water...let it dry inspect it for anything you missed.....what works well is a quick coat of primer it makes everything show up...attack it again with every othe tool just be sure they are grease free before you go pokeing your clean block... just be sure to give it a good coat of primer if you don't like how it looks then you not going to like it with paint.......
I have the news pan painted and ready to put on when I hoist it into the truck...the paint is wrinkle black with silver wheel paint on the covers (chrome Caddy vavle covers are expencive)I also have added yellow accel plug wires.....the pics do not do it justice
Hottrucks is offline   Reply With Quote
Old 06-25-2010, 06:14 PM   #6
67chevy1series
thanks well yesterday i thought i would go get some of that simple green and i sprayed and scrubbed picked it clean then today i got some rustoleum chevrolet orange red paint and some grey 500 degree sprated it then got the exhaust manifolds and painted them dark metallic grey and now its done as soon as i buy the front brake lines ill bolt up the tranns and torq con. to the engine and ill start it up for the first time
