![]() 1988 - 1998 Chevy and GMC Heavy Duty Headlight Harness. What the harness does is this; The way all 1988 - 1998 GM trucks headlights are designed is to draw power for your headlights from the headlight switch in the dash using small 16 - 18 Gauge wire for power. Which results in a lot of lost voltage, and also the danger of melting wires or your headlight switch with upgraded headlights such as HID's. Now what the HD Harness does is this:, by using 3 relays (1 for the high beam, 1 for the low beams, and 1 for the 4-High feature) it draws power directly from the battery and uses 14 Gauge wire to power the headlights from the relay and gives your headlights 13.8 volts +. Which will result in having brighter, and safer headlights! The harness' are 100% "plug n' play", there is no cutting of the original factory wiring what-so-ever. Also, if you have HID's and have issues with "flickering" this will clear up that issue. These harness' also have 4-High relay built in, so the low beams stay on with the high beams, which also increases your night time visibility! These are not a low end cheap harness like the so called "Relay Harness'" that various Internet retailers sell. These are complete NEW high quality true Heavy Duty Headlight Harness', that replaces your factory Headlight harness (but the factory headlight harness can remain on the vehicle). ALL of the connections are cleanly soldered and heat shrunk to provide the best connection possible. The HD Harness comes with complete directions on how to install the HD Harness kit. If you have any questions feel free to contact us! The Harness' are $95.99 shipped to anywhere in the lower 48 states. Payment: PayPal or Postal Money order Condition: NEW ![]() MADE IN THE USA
Re: 88-98 Chevy & GMC Heavy Duty Headlight Harness
I have one of these harness that I purchased through another forum. It has been doing great and trouble free for over two months I believe. Install was super easy also.
Just a free bump and a great guy to purchase from. The harness is built really well and has much better quality than others I have seen. Plus its "Made in USA!"
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded ![]() '03 burb. Family cruiser http://upstategmtrucks.com/ |
#3 | |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
So if I bought one of these from you would I still need the harness that makes my low beams stay on with the high beams?
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#5 | |
No sir, these HD Headlight harness's come with the 4-High feature (low beams stay on with high beams) built in. So the harness is 100% Plug n Play! |
Do you have a harness that will work on a 2005 GMC Jimmy? I'm ready to order from you so let me know asap.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 Last edited by Already Gone; 11-14-2011 at 04:36 PM. |
Any Black Friday sale's on these?
Thanks Baron, I received my harness the other day and it looks great, very professional. I will be installing it in the New Year.
Bump! Happy Holidays guys!
sent a pm.
First one for the new year Nick |
any way to add in foglights like the tahoe limited harness's?? might be interested in one if you can do that
#15 |
Yes sir, we can add a relay to power your fog lights. As well as build in the option of having the foglights stay on when your high beams are on also! If you have any other questions please feel free to ask!
#16 |
Hi Baron, Happy New Year. I bought one of your harnesses ( I haven't installed it yet ) and do plan to add fog lights to my Burb. My question is can I add what is needed for the fog lights to the harness you sold me ( before I install it ) or would I have to get a whole new harness?
#17 | |
Thanks! |
#18 |
I am interested in this but am deployed right now so I don't have much time on the Internet. Can you email me at @comcast.net?
2001 Silverado z71 ECSS Cammed, Stalled, headers, BB tuned 1988 Scottsdale 2500 ECLB 4x4- the never starting project 1998 Firebird Formula- stock and slow for now 1987 Iroc LB9/auto/G92- rusty 600 dollar future beater 1991 5.0 Fox Body- 200 dollar running driving project |
#19 |
GM Parts Guy
I noticed in the picture the connectors seem to be for the composite headlights. Do you have a harness that works with the quad headlights?
1975 Chevrolet C-10 Custom Deluxe (DD/WIP) 1989 Chevrolet C1500 reg cab stepside (Winter Truck) 1977 Harley Davidson XLH 1000 (Summer Cruiser) |
#20 |
Yes you are correct, this harness is for the composite style headlights. If you are wanting a harness for the 88-89 style quad sealed beam headlight set up, we could most likely build a harness to suit your needs!
#21 |
GM Parts Guy
Do you have a price for it off the top of your head?
#22 |
I would have to check the availability of the headlight connectors for the dual sealed beam style headlights, but it would most likely be roughly about the same as the 88-98 Harness for the composite headlights!
#23 |
How much brighter will this harness make the headlights? I live out in the country & I can barely see anything with my dim lights on, I usually just drive with my brights on but even then its kind of hard to see, my lenses are a little bit yellow but not to bad.
1972 Chevy Blazer 1997 GMC Sierra 2009 Chevy Tahoe |
#24 | |
The HD Harness does truly make a big difference in light output. Due to the way that the OEM Headlight Circuit is set up, the headlights draw there power from the headlight switch; through ~16awg wire. This results in a fairly large voltage drop by the time that the power reaches the headlights. With this harness installed, it takes care of that problem. The harness supplies your headlights with direct voltage through 12AWG wire, and takes all of the load off of your headlight switch. Which results in brighter headlights, giving you more light output being that they are getting the full 13.8V+ and allowing the headlights to run at 100% intensity. Even on stock headlight bulbs, this harness WILL make them noticeably brighter. This harness along with a decent upgraded headlight bulb, will make for a WORLD of difference and truly make you feel like you are driving a different truck at night! If you have any other questions, please feel free to ask! Thanks for your time, Baron |
#25 | |
(007) aka Houdini
![]() Join Date: Mar 2010
Live life one day at a time! |
Tags |
4-hi, hd harness, headlights, hid, relay |
