12-04-2011, 06:37 PM | #1 |
Drum Brake shoes and hardware setup pictures
I have a 1970 c10 truck with manual drum brakes and my brake shoes and hardware are not put on right. I need four pictures of each brake drum that are put on right. If somebody could send me pictures that would be great.
12-04-2011, 06:43 PM | #2 |
What?
Re: Drum Brake shoes and hardware setup pictures
Chris 1968 K20 Suburban 1972 K10 LWB PU |
12-04-2011, 06:48 PM | #3 |
Thank you! Do you have any pictures for the front drums?
12-04-2011, 08:04 PM | #4 |
What?
Front drums go the same way pretty much.
12-04-2011, 09:49 PM | #5 |
Oh okay thank you for the info I appreciate it.
12-05-2011, 12:38 AM | #6 |
Active Member
Here's a pic of front brakes.
12-05-2011, 01:31 PM | #7 |
Grandpa in the rustmobile...
Yeah that link rocks lol drum brakes are hard the first couple times lol
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
09-08-2016, 09:54 AM | #8 |
09-08-2016, 11:58 AM | #9 |
Two bits of advice. Get a drum brake tool/spring return, and wear EYE protection. Messing around with pliers and all that is dangerous and so easy to really scratch yourself up or take an eye out. It can be done with pliers, but alot easier and less frustration with a tool and dont forget EYE PROTECTION!
09-08-2016, 12:17 PM | #10 |
+1 invest in a drum tool!
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback |
09-08-2016, 02:00 PM | #11 |
I couldn't figure out how to use the tool to replace the springs. I are dumb, I guess.
I used a t handle spring tool, used on motorcycles and atv exhaust. |
09-08-2016, 04:33 PM | #12 |
I have found the "tool" for drum brakes to be very hard to use. I just did all four of my drum brakes and all I used was a small vice grips. To remove the springs just clamp it tight up by the hooks, at a 90 degree angle, and stretch them and unhook -- the springs are not that strong. For the shoe keeps (the slotted washer), I used the same vice grips to grab the edge of the washer straight-on (just enough to hold them) and then hold the pin from behind, push in and do a half twist. The special tool doesn't always grab when you twist. -- putting them together is just the same, in reverse. I actually did each one several times (for various reasons, like the new parking brake cables were the wrong length), I've gotten real good at it after doing 8 of them Hope this helps, Ken
09-08-2016, 07:14 PM | #13 |
Might have picked up a cheap pair? Mine work great.
09-08-2016, 07:39 PM | #14 |
09-09-2016, 11:13 PM | #15 |
I do it the same way as kda2000, after much trial and error and attempts to use the special tool I found this method is quite simple and safe and actually easy.
57 suburban(sitting in the driveway), 2 69 C20 longbeds (sitting in the field ) and a 2003 8.1 Suburban Endeavor to persevere. "All of a sudden, I'm the old timer!" Some old timer on American Pickers. |
09-10-2016, 10:49 AM | #16 |
08-20-2022, 06:04 PM | #17 |
10-03-2016, 09:46 PM | #18 |
So there are "two" sizes of shoes? The larger always go towards the rear and the shorter (Seems like two different sizes?) go towards the front? Is this correct? (They are all setup the same way.)
1966 Chevelle SS 396 1970 C-10 project (for sale) 1984 Chevy C30 Ramp truck My YouTube |
10-06-2016, 07:37 PM | #19 |
That was how mine were, and I put new shoes on the same way. My 1970 shop manual also shows the larger on the aft side!
1970 C-10 LWB 1998 Jeep Wrangled TJ 2009 Honda VTX 1300 2013 Buick Enclave |
10-06-2016, 09:44 PM | #20 |
Something many people forget is to wear eye-protection when rebuilding drum brakes. Those springs will go flyin!
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801 |
10-08-2016, 02:47 PM | #21 |
my book says primary and secondary for the hold down springs, they are different so which goes where? primary hold down the rear shoe on the fronts?
10-08-2016, 04:16 PM | #22 |
Primary shoes (shorter lining) always face forward. The brake system on these trucks is a " duo -servo" system which is a fancy way of saying that the front (short) shoe is used to "jam the rear shoe (secondary) against the anchor pin & against the drum making the brakes more effective. Some brake systems are "single acting" brakes. The brakes on these systems are anchored opposite from the wheel cylinder (usually on the bottom) and both brake linings on the front & rear shoes are the same length. The shoes simply pivot out when the brakes are applied
Got long winded there, if one anchor spring is shorter it goes on the rear shoe. It is shorter because it is also retaining the self adjuster arm. |
10-08-2016, 04:22 PM | #23 |
thanx bw, my truck been apart a long while and cant find my hardware either. i just went thru this with the rear dana 60. i have 12'' brakes. i need both adjuster wheel springs and both small return springs. gonna post a pic on the wanted side
10-09-2016, 11:40 AM | #24 |
I have the 12" brakes also, here are some part #'s:
Brake shoe set CQ S127 Brake Hose, Rear CQ SP4999 wheel cylinder, left CQ WCA34474 wheel cylinder, right CQ WCA34475 hardware kit adjuster kit, left H2554 adjuster kit, right CQ H2555 Spring, transfer bar CQ 1338-2A adjuster screw, left CQ 1530 adjuster screw, right CQ 1531 Parking brake cable set Inline Tube BST6943 brake drum CQ 8911 CQ is Car Quest, if you get the adjuster kit the adjuster screw comes with it. I have the hardware kit but did not record the P/N, will check this on Monday |
10-09-2016, 12:00 PM | #25 |
These are front brake numbers?
