Old 06-08-2012, 12:58 PM   #1
chevy72blu
chevy72blu's Avatar
"Re-purposed" 2 core aluminum radiator?
Hey folks,
I've been asking a lot of questions lately and is one of the few that I have left.
I've decided that im for sure going to a 5.3/4l60e in my 72. Back when I was doing the big block swap, I bought a new Griffin aluminum 2 core. It has been sitting unused... At first, I thought I needed an LSX specific rad, but some google-fu has revealed that people are making the stock ones work (I have a stock 72' copper 4 core also... Which would be nice as I dont have to fab mounts).
I dont have the specs in front of me, but will the Griffin rad work? edit: Actually this is my OLD radiator which I sent back for a replacement - inlet/outlet was on the wrong side. Its the same rad only with them reversed.
Along with this fan setup (which also has been sitting unused)
I've read that I need to drill a hole for the "steam port" in the water pump. Can someone tell me what the function of this is, and is there a faq/picture thread on how to do it?
Will a standard overflow canister work or do I need something else? Now that I have fuel down (Boyd's tank, in take pump, external vette regulator), this is my last big ticket issue.
Edit again: It looks like I need both inlet and outlet on the right side? Maybe im better off just selling what I have and buying one of theses http://www.entropyrad.com/index.php?...d&productId=21
chevy72blu is offline   Reply With Quote
Old 06-08-2012, 01:38 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: "Re-purposed" 2 core aluminum radiator?
I re purposed the same be-cool that the PO had put in my truck back when it had a 355. Had to "make" some custom hoses but was easy, fits and looks pretty good.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-08-2012, 02:03 PM   #3
chevy72blu
chevy72blu's Avatar
How did you tackle the steam port? Do you need to route it from the rad to the water pump? I figure I could always take the rad to a shop and have them install the fitting...
The entropy rig is very nice, but its way over budget unfortunately.
Old 06-08-2012, 05:18 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
its tapped into a coolant hose on the high side, kinda hard to picture, but its not into the pump like many do. Haven't had an issue thoughl
Old 06-08-2012, 10:33 PM   #5
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
I'm running a copper 4 core and it keeps it cool no problem with a pair of electric fans. As for the steam vent...there was an extra port on my radiator. Not sure what it was for... but it feeds into the passenger side tank, so I'm using it for the steam vent port.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 06-09-2012, 12:44 AM   #6
awhite4557
awhite4557's Avatar
I used my original 4 row radiator and had a fitting soldered in on the top passenger side for mine. You can get this fitting from JTR (Jaguars That Run) and use it with the aluminum radiator. Hers the link http://www.jagsthatrun.com/Pages/Par...g_LSI-tee.html
1950 Chevy 3100 Ramp Bed 1-ton
http://67-72chevytrucks.com/vboard/s...d.php?t=749386
1965 Chevy Step Side
1971 Chevy Short Wide Bed
http://67-72chevytrucks.com/vboard/s...d.php?t=277191
1971 Chevy Chevelle
1972 Chevrolet C-30 1 ton
2002 Winnebego Class A MH Ford E-550 Chassis V-10
2005 Dodge Ram 2500 5.9 Cummins
2008 GMC Denali
2020 Jeep Wrangler Unlimited Rubicon
awhite4557 is offline   Reply With Quote
Old 07-18-2012, 02:28 AM   #7
mcmlxix
Collector of Projects
mcmlxix's Avatar
Did you ever finalize your radiator and fans? I have been looking at the AFCO dual pass radiator with the Inlet/Outlet on the passenger side. $230 shipped. AFCO p/n: 80126N
I would have a bung for the steam vent welded into the radiator...
They say Made in USA...
Rich
1972 K5 Blazer CST Click HERE
