12-12-2012, 01:14 PM | #1 |
Another 700r4 question
So, I'm now to the point of swapping speedo gears on my 700R4. My question is, do I need to put back the "sleeve" that was on the shaft that butts up against the gear? It's about 3 1/2-4 inches long. I can't find anything that talks about it.
'67 C20 LBW |
12-12-2012, 01:15 PM | #2 |
Re: Another 700r4 question
I guess I should include I'm swapping from electric to mechanical speedo gears.
'67 C20 LBW |
12-12-2012, 07:24 PM | #3 |
I don't remember a sleeve when I did mine from elect to mech... I would say if the gear fits on the shaft tight then I say no. It would help if I knew exactly what the part was.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
12-12-2012, 07:59 PM | #4 |
If the slip yoke has a "weep hole" in it....You need the sleeve.
If not.....Leave it off. The weep hole relieves pressure buildup caused by the yoke moving back an forth as the vehicle passes over bumps. If you have a weep hole & need to reinstall the sleeve....Replace the O-ring GM P/N 3764601 |
12-13-2012, 12:36 AM | #5 | |
12-13-2012, 07:59 PM | #6 |
Take the yoke off the drive shaft, Drill & tap the hole to 10-32, Cut down a 10-32 screw to about 3/8", Put some Red Loctite on it & run it in, Let sit for 24 hours to let the Loctite cure, This is a permanent fix, & beats buying a $100 Yoke.
12-13-2012, 11:35 AM | #7 | |
that answers my question, thanks!!
'67 C20 LBW |
12-20-2012, 12:42 PM | #8 | |
'67 C20 LBW |
Tags |
700r4, 700r4 swap |
