It's alsways something.....
![]() Join Date: Nov 2008
Need 1/8" Pipe thread temp sender compatible with stock gauge
2003 5.3
1971 Blazer Autometer 2277 adapter-goes into head on pass side and has 1/8" thread port for sender----1/8" NPT Female to M12x1.5 Male http://www.autometer.com/cat_accesso...il.aspx?vid=61 What I am looking for is a 1/8" sender that will screw into the adapter and be accurate for the stock Blazer gauge. The Autometer site sez "If using with a Short Sweep Electric Temperature gauge, sender #2259 is also required." http://www.autometer.com/cat_accesso...il.aspx?vid=33 Will this sender correctly operate the factory gauge? If not, Autometer sells others or another 1/8" sender might work. Anyone know? I am not looking for other alternatives such as drilling and tapping the head- I only want to now about a sender--Thanks!
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie 1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts 1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e |
Truck and auto performance nut
Re: Need 1/8" Pipe thread temp sender compatible with stock gauge
I just tapped the passenger sides head to fit my autometers slightly larger sender size. Magnet, some grease, and a lot of care to pull the metal out of the hole while drilling. Factory sender is in the drivers side head for the efi...so yes I have 2 senders!
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
![]() Join Date: May 2012
What was the magnet for? Did it do a good job. Jk That is a really good tip and I probably will use it.
[QUOTE=69CST6.0;5931962]What was the magnet for?
The real question is, what does a magnet do to aluminum shavings? Anyone know where I can find out about compatible 1/8" senders to the 1971 gauge?
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie 1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts 1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e Last edited by chuckmc8; 03-07-2013 at 07:44 AM. |
I'm using #2259 on my 71, and everything seems to be working fine. I got the Idea from others using it as well, and never noticed that it said only works on 95 and newer guages until I read the link you posted.
#6 | |
[quote=chuckmc8;5932413]
Here is what i did.
![]() Posted via Mobile Device |
What does Street and Performance have to offer?
![]() Join Date: Feb 2004
I bought a aluminum pipe off ebay that was tapped for a stock sender. Cut the upper radiator hose and installed it ofchorse i dont see temp till the thermostat opens. But its the cheapest way. And you can always find a sender or gauge to work even cheap auto store gauges. I know that if i dont see temp with in a few min of driving i would have to have a stuck thermostat. Lol the puter monoters temp to and if the engine gets to hot it will attempt to cool it with extra fuel makeing the thing run real funny!
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
Just to update this thread with a conclusion- The autometer 2259 and the autometer adapter was the ticket- no drilling and threading and the factory gauge works like new. Thanks for the help.
Have you checked the engine and radiator with a I/R gun to see if they ate reading the same?
#12 | |
![]() Quote:
What the gauge gives you is a 'normal' baseline anyway. Once that is established, the gauge just lets you know that something is amiss. if anyone installs this sender and adapter and has access to an I/R gun, please post the results to seep this thread updated, since this is valuable info for swappers. If anyone would like to send me an I/R gun or a gift certificate, please PM me for addy ![]()
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie 1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts 1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e Last edited by chuckmc8; 04-11-2013 at 06:08 AM. |
So with those 2 autometer products you were able to use the factory gauges and not have to do any extra drill and tapping?
#14 | |
sorry for the tilted pics-it's just beyond me
#15 | |
#16 |
Beats me
#17 |
Thanks man! This helped striaghten out some questions I had about the temp gauge.
#18 |
Thanks chuck. This will help multiple people, including me.
#19 |
In case anyone is interested...... here is the resistance vs temp chart for both the 2258 and 2259 sender
#20 | |
Now how do I get it to read from 230* down to 180*
#21 |
![]() Join Date: Nov 2007
I put cjohnson6772 data on my temperature sender data. Doesn't exactly match either the 60-66 GM sender or the late model GM sender but it is closer to the late model one.
I have yet to find a sender in small size that works for the 60-66 stock gage. (The late model sender overheats from high current and pegs the stock gage at any water temperature.) The attached file gives a bigger picture. TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
#22 | |
Also: if I=V/R wouldn't the late model gauge have less current? (Constant voltage and greater resistance?) Posted via Mobile Device |
#23 |
This is great info thinking of converting to this setup. I'm currently using one of street and performance adaptors and the original sending unit my tuner says its not reading correctly because the adaptor is so long and the water is not constantly moving cross the sender.
#24 | |
#25 | |
Old member
![]() Quote:
![]() ![]() ![]() http://www.harborfreight.com/non-con...ing-60725.html
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
