06-13-2013, 08:26 PM | #1 |
Diesel help!!?
The farm truck started acting strange yesterday. Dad drove to town, and parked for a while. He started it up and it ran fine, but it had no power at all. Going 100kmh -60mph it has to be at nearly WOT. I replaced the fuel filter today, lots of fuel in there so the lift pump is good. I can hear the turbo spooling, so it is still good. Do any of you have ideas about what it could be?
Thanks By the way it is a 2000 dodge with a cummins 5.9 Posted via Mobile Device |
06-13-2013, 09:20 PM | #2 |
Re: Diesel help!!?
Boost leaks? Check the intercooler boots for tears/rips.
Check fuel pressure!! The filter housing being full of fuel means nothing. Codes? |
06-14-2013, 12:24 AM | #3 |
Re: Diesel help!!?
I will check for tears tomorrow. I don't have a fuel pressure gauge or a code reader though. I will be investing in both eventually, just havent needed either until now.
06-14-2013, 11:59 AM | #4 |
*** That's interesting ***
Re: Diesel help!!?
At WOT going 60 MPH, is it spitting tremendous amounts of black smoke or not?
Tom Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... |
06-14-2013, 12:18 PM | #5 |
Re: Diesel help!!?
No smoke at all.
Maybe spark plugs or distributor? Thats what my friend thought! Posted via Mobile Device Last edited by 72chevynoob; 06-14-2013 at 12:42 PM. |
06-14-2013, 01:31 PM | #6 | |
Re: Diesel help!!?
Lots of black smoke can mean intake plumbing problems (leaking). Lack of black smoke can mean fuel delivery problems. I just wanted to narrow that down first.
06-14-2013, 02:00 PM | #7 |
Re: Diesel help!!?
So possibly injection pump or injectors then?
06-14-2013, 02:15 PM | #8 |
Re: Diesel help!!?
You are absolutely sure of the lift pump? Our 98 would lose the lift pump intermittently, and my uncle drove it like that until the injector pump fried.
06-14-2013, 03:52 PM | #9 |
6>8 Plugless........
Re: Diesel help!!?
You should be able to cycle the ignition switch 3 times and the odometer will display the codes if there are any. When you remove the fuel filter, drain some fuel from the bowl, turn the ignition on and bump the starter. The lift pump should run and you need to time how long it takes to fill up the fuel filter canister. If it is slow and low volume, chances are your lift pump is bad. These fail a lot on these trucks and take out the injection pump. You could also have a bad map sensor too. Try checking for codes and let us know if there are any.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
06-14-2013, 05:03 PM | #10 |
Re: Diesel help!!?
There are no codes. I checked and it just says "p done" which apparently means no trouble codes. The lift pump fills really quick, actually suprised me and made a mess.
06-14-2013, 05:23 PM | #11 |
Re: Diesel help!!?
Is it manual or auto trans? How does the trans shift during normal driving?
06-14-2013, 05:28 PM | #12 |
Re: Diesel help!!?
It is an auto trans. Usually when at wot it takes a long time to shift. The trans has never let it accelerate very fast, but it always had power. I did check the fluid level and it was good, maybe high.
06-14-2013, 05:27 PM | #13 |
Never Ending Projects
Re: Diesel help!!?
24 valve Cummins, it is very common for the pump to not keep up with enough pressure. You MUST check this under load, not just in your driveway. Run your injector pump too long with low fuel pressure, you'll be replacing it at the tune of about $2000. You might be getting a lot of fuel but not enough pressure. This is about 99% of the time, the issue when it suddenly happens.
This is why I bought a 12 valve Cummins as they don't have nearly any problems with fuel pressure issues like the 24 valve engines (which start in 98.5 production year).
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
06-14-2013, 07:32 PM | #14 |
Re: Diesel help!!?
It sounds like you might have an APPS, applied pedal pressure sensor, issue. Do you have a fluke meter or equivelant? Do you have the means to check fuel pressure at the injection pump? It should have 8-14psi on a stock lift pump. Anything below 8 is asking for trouble. I strongly recommend an aftermarket lift pump on these trucks. It is a form of insurance for your VP44.
06-14-2013, 11:18 PM | #15 |
Re: Diesel help!!?
By fluke meter you mean multimeter? I have one of those. I think we will end up replacing the lift pump. Would this be a good choice? http://www.summitracing.com/parts/bd...2500/year/2000
So I should use the multimeter to measure the resistance on the APPS? Where is that located, and how do I measure it? Posted via Mobile Device |
06-14-2013, 11:23 PM | #16 |
Re: Diesel help!!?
Holly cow! For that kind of money, you might as well get an Airdog! Have you heard of airtex pumps? If your truck is stock, you can go to an Orielly's and they carry the airtex which will replace the stock lift pump. Here is a guy that has the best option for apps sensors, and a good deal of info on them.
http://www.dodgecumminsapps.com/calibration.html
06-14-2013, 11:42 PM | #17 |
Re: Diesel help!!?
Would any other parts stores carry airtex? We don't have oreillys in Canada. Should I go with the in tank or external pump? Gotta have this thing on the road in under a week.
06-17-2013, 09:02 AM | #18 |
Re: Diesel help!!?
Check the Cummins boards. there are enough options to make your head spin. Also see which pumps to avoid, ie the Holley black pump. Apps failure is relatively common. I didn't check the link but the IH version with the adapter harness used to be the cheapest.
06-18-2013, 05:39 PM | #19 |
Re: Diesel help!!?
Ok, we brought it in to a shop today. They hooked up their code reader, then told us it was the MAP sensor. They replaced it and its as good as new! Thanks for all the suggestions and advice!
