09-24-2013, 08:18 PM | #1 |
Old member
2003 LSx swap thread...here we go
Ok everyone here is the begining of the swap. Well at least I'm working on stuff.
Got the motor hoist setup and went to get my motor and my buddy had a motor on his so it will be tomorrow before I can get it. I did take all the front brackets off except for the AC since I want be using it not worth the trouble to clean it up yet. Motor hoist. $198.00 at Harbor Freight 1000 lbs. $2200.00 Motor,trans, stand alone wiring harness, motor mounts, fuel pump 198.00 Hoist $12.00 paint I keep the cost updated as I go or at least try. I came home and started cleaning stuff and primered & painted some. I started with the coils and hardware and dipstick. Cleaned the brackets up and painted them and cleaned up the coils. Cleaned up all the front brackets and got primered and some painted not all though. Man I wished they get the gallery fixed where I could put the pictures as I did them. Just bare with me everyone. Pictures are just as I can load them.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
09-24-2013, 08:25 PM | #2 |
Old member
Re: 2003 LSx swap thread...here we go
5 pictures at a time it's going to be a slow process! It's going to take longer doing the updates than the work!
I bought some cheap paint at wally world for the brackets and will by motor paint when I get it prepped. I'm thinking about painting the fan blades Red! What... I primered everything and then sprayed the metalic silver to them. I will go back and do the pulleys black along with the PS pump.
09-24-2013, 08:30 PM | #3 |
Old member
I think is going to turnout pretty after it's all said and done. I plan to just take my time on this and do it slow and right the first time I hope. I got the front brackets all primered and one coat of paint on them and they are drying over night.
09-24-2013, 08:37 PM | #4 |
Old member
I plan to paint the whole motor except for the heads once I get it home and cleaned up. I painted the back plastic of the alternator RED!That's what gave me the idea to paint the fan blades red!
The picture of me holding the coil wiring it's all dirty and I wiped it off 2 but it just looks nasty to me. Is that covering heat insulated are will regular black tape with conduit be OK? That's it for tonight I'm done. Got to get the motor tomorrow and close up the pool so it may not get nothing done...yea right!
09-24-2013, 11:15 PM | #5 |
Looks good
Posted via Mobile Device |
09-24-2013, 11:47 PM | #6 |
Nice job...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
09-25-2013, 12:15 AM | #7 |
meowMEOWmeowMEOW
Andy, host your images on a file service like photobucket or imageshack etc. You won't be limited to 5 images, and the service will burden the storage instead of our site.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
09-25-2013, 09:24 AM | #8 | |
Old member
Well wouldn't u know it, it's pouring down raining here today. I may not get the motor today either!
09-25-2013, 09:50 AM | #9 |
Let's see some pictures of the engine!
09-25-2013, 10:08 AM | #10 |
Old member
I haven't started on the engine yet since it's been at my buddies shop but here is what it looked like last week when I picked it up. It sat in the truck over nite at the house then went to my friends shop because I had no way to get it out of the truck. My son needed his truck for work.
That's why I bought a engine hoist yesterday. Now I can do it myself!
09-25-2013, 10:14 AM | #11 |
Is that out of a 1500?
09-25-2013, 10:32 AM | #12 |
Old member
Yes as far as I know. It was sitting in the guy's garage when I bought it.Said it came out of a 2003 truck.
09-25-2013, 11:00 AM | #13 |
Just an FYI, it's a 2001, in 2002 they stopped using the EGR valve. You can eliminate it and have the emissions deleted in the tune to make it cleaner looking. Also, it's out of a 2500 or 3500 since it's got a 4l80e behind it.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
09-25-2013, 07:59 PM | #14 | |
Old member
So I got the motor home between down pours today and started cleaning again. I guess they make a block off for the intake? Where the hose to the EGR valve goes. Here are a few more photo's for u. I printed the manual off at work the other night and made me a note book to keep up with things. Here it is back at the house and I started on it agin getting the ac off. Opened up the valve covers and saw this.
09-25-2013, 10:29 PM | #15 |
You can get the block off for the intake at the dealer, not sure of the part number though. It's a small stamped steel plate with an o ring that bolts on to the intake. You'll probably be changing exhaust manifolds so that part you shouldn't have to worry about.
09-25-2013, 10:40 PM | #16 |
Old member
Do I need this black bracket?
I'm done for the night. Will try and get the garage cleaned up some tomorrow. May do a little don't know, wife has some Honey do's to do. I took the senors out and painted the brackets for them. Junk pile are trading stuff which ever. He said it was a corvett manifold. I don't know what it is.The flange is twice as big as the truck manifolds u can see in the picture. The stock AC compressor and pulley + mount.
09-26-2013, 01:40 AM | #17 |
Looking forward to following this build.
09-27-2013, 02:08 PM | #18 |
meowMEOWmeowMEOW
There is a starter cover? Thats news to me.
09-27-2013, 04:36 PM | #19 |
Old member
Yes it was on the starter and it just slips on. I took the starter this morning to O- Reilly's and they tested it for me. It worked fine so now I will clean it up and paint it as well.
Got the new temerature senor to while I was there.
09-28-2013, 11:55 AM | #20 |
meowMEOWmeowMEOW
Take a look on this thread
http://ls1tech.com/forums/conversion...ntake-egr.html I don't think the one you posted would work. The factory part # is 12558346 its like $13
09-28-2013, 01:31 PM | #21 | |
Old member
11-12-2013, 07:02 AM | #22 |
Hey Andy, I'm just stopping in to say "hi" and let you know that I am following along. What are your plans for your license plate and the "71 TPI" air brush work on your truck?
1969 C10 SWB Project Charity Case AKA "Roscoe" 1971 Cheyenne Super A Combined Effort The Service Station-A practical ministry for those in need |
11-20-2013, 03:32 PM | #23 | |
Old member
Good to hear from U. Have U ordered from S&P yet? I have been thinking about it and haven't decided yet. I don't know if I will try and get a 71 LSx tag now are just go with a regular tag! The side art work and tailgate I hope can be changed, I hope! Haven't checked on it yet.
11-20-2013, 07:18 PM | #24 | |
11-20-2013, 08:45 PM | #25 | |
Old member
