02-12-2014, 06:30 PM | #1 |
86 GMC, Porterbuilt Mild front and rear
Figured I would finally post what I have been working on. The story goes that I bought my 86 GMC while on leave in 2009. It sat in my fathers garage for the next year until I could come back and get it. When I did get back, I did a mild build on it which included a Mcgaughy's 4/6 drop with big brakes, 20/22" Coy C5's, and a 5.3L/4L60E swap. I drove daily for a few months before getting deployed again and then it sat once at my fathers house. Fast forward to late 2012 and a separation from the Corps and it's build time!
So for the second go around, I decided to run a Porterbuilt Mild dropmember front and rear. I built a cammed 6.0 LQ9, Performabuilt Stage 2 trans, 3.73 gears with eaton tru trac. I figured I would post some of the issues I have run into as well, mainly steering linkage and headers. Attachment 1213713 Attachment 1213714 |
02-12-2014, 06:36 PM | #2 |
Re: 86 GMC, Porterbuilt Mild front and rear
A few build pictures
02-12-2014, 06:39 PM | #3 |
More build, 6.0L, raised bed floor with liner.
02-12-2014, 06:44 PM | #4 |
Fabbed ECM mount. Headers are Hedman Muscle rod. I had to notch the dropmember to get the correct angles for the steering. The drivers side header has the front tube rerouted to clear the joints.
04-12-2020, 01:04 PM | #5 | |
How did you connect your first u-joint at the steering column? Did you cut a piece of steering shaft stock and mount it in the residing location, and then mount the u-joint to that?
'84 Suburban C10 Silverado - laying pinchweld to the ground on 22/24. /Porterbuilt / Accuair / Bonspeed / Landsail / Auburn Gear / Richmond Gear / Moser / Raybestos / ProMaxx / Edlebrock / Street Demon / Taylor Wire / K&N / MSD / KillMat / SOLD: 1985 GMC Sierra Classic 2500 3+3 Crew Cab Long Bed |
04-12-2020, 01:36 PM | #6 |
No. The factory column has a DD shaft end already. These columns usually have the DD end or a splined end.
02-12-2014, 06:54 PM | #7 |
Looks sick , will nice to see more of it
02-12-2014, 09:47 PM | #8 |
Love it!
02-12-2014, 10:40 PM | #9 |
sweet build bro!
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
02-13-2014, 02:03 PM | #10 |
Thanks guys! Really appreciate your comments
02-13-2014, 03:22 PM | #11 |
Nice, I have the same year Chevy. I'm looking to drop in an Eaton True Trac as well, let me know how easy it is to install and how you like it!
Semper Fi!! |
02-13-2014, 03:49 PM | #12 |
I haven't had a chance to use it yet. The installation was pretty straight forward. I used a nitro gear rebuild kit and it's the stock 10 bolt. You will need a press for the bearings and an in/lb torque wrench.
02-13-2014, 07:09 PM | #13 |
awesome build man im looking in to porterbuilt stuff now my self
02-15-2014, 11:34 AM | #14 |
Thanks! Honestly, if I were to do it again, I would just go with the extreme version. It would be less fab and fitment issues.
02-15-2014, 12:36 PM | #15 |
nice!
My build thread... http://67-72chevytrucks.com/vboard/s...d.php?t=515829 Disabled Veteran 82nd Airborne Division Operations: Desert Shield, Desert Storm, and Uphold Democracy |
03-13-2014, 05:07 PM | #16 |
Header modified to clear steering. |
03-13-2014, 05:53 PM | #17 |
Headers looks good
03-13-2014, 11:57 PM | #18 |
Looks good! I'd like to hear that beast.
Current Build 89 s10 ecsb 2wd 4.3/700r4 50k OG Miles Instagram- shaggin_s10 '86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt (Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD |
03-14-2014, 12:04 AM | #19 |
Like the look of the setup, headers fit nice, should be a real nice ride.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
03-14-2014, 12:21 AM | #20 |
Great looking build so far.Good job modifying the headers to bit.
03-14-2014, 09:55 AM | #21 |
As soon as I can get the exhaust hooked back up, I'll get a video of it running.
03-27-2014, 06:39 PM | #22 |
I sent you a PM, and was wondering if you could get a picture and maybe some info on how you modified the inner frame support for the steering shaft clearance? I'm at that point and it would be a great help.
Thanks, Wade |
03-31-2014, 05:25 PM | #23 |
I'm at a crossroads right now and need opinions. Should I shave and repaint the firewall? Or, make a panel to resemble the a/c heater and put some undercoating back to look kinds stock?
03-31-2014, 06:37 PM | #24 |
Depends on the look your going for. I've redone so many things I've lost count. Thinking I'd be happy with it and not dough what I really wanted to do in the first place. If you like the look of a smooth newly painted firewall, do it now, or you'll be redoin it later. It's gonna be super nice either way!
Wade |
05-15-2014, 02:43 AM | #25 |
Do you have any pics of you raising the bed floor? Or closer up pics of the mounts??
Truck looks amazing.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
Tags |
headers, steering |
