Old'er engine in New'er truck [ straight 6 in 85 S15 ? ]
Anyone seen someone stick a 250ish straight 6 into a newer S15? No other reason then to have a straight and give it a diff look, carb'ed V6 needs to go. |
Re: Old'er engine in New'er truck [ straight 6 in 85 S15 ? ]
I think that would be kinda neat. But the length might present problems but I think it would be very doable.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
I know we got lots of threads about putting a T5 onto a straight 6, any chance a v6 700R4 would mate to one???
If it's off a 4.3 it will, but if it's the original 2.8 700r4, it won't work.
^ probably for the best. its a 3.1 S15 Gypsy
I like it. A nostagic straight six under the hood of a S15 would be cool.
65 C20 292 4spd 4:56 Eaton HO52 |
I also like the simplicity of it from a mechanical point of view.
Too many projects
I would be worried about the length of an inline, as it would be roughly twice the length of a v6. The 250/292 is at least 8 inches longer than a small block, and a small block is a very tight fit in an S10.
If you need any inliner dimensions, let me know and I'll grab them off of my 63 Chevy II.
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
First I gotta see what I can find for a deal, I guess after that ill have to wing it.
Though always easier when they just sit down in there but im not afraid to make things fit ![]() |
blood type; Retumbo
you're going to need a sawzall, a welder, and LOTS of patience and ingenuity. I'd just swap in an injected 4.3 and all the electrical or get a stand-alone fuel injection kit.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
