03-12-2014, 01:28 AM | #1 |
60-66 Nut
HD Carrier Bearing Mount
I will be making more of these in the future but as of now I have just this one. If you currently have the light duty driveshaft and carrier bearing that hangs from the top of the trailing arm crossmember and you want to upgrade to the HD driveshaft and carrier bearing, you will need this bracket. This mount bolts to the bottom of the trailing arm crossmember and the carrier bearing bolts to it.
The mount I am selling is shown in the first two pics. The rusty one in the third pic is an original mount. The price on this new mount is $47.50 plus shipping of $9.20.This pricing is always current and up to date. As always, I will combine shipping when you purchase two or more of my products. To make a purchase, post in this thread, send me a PM or send an email to captainfab454@hotmail.com, and I will give you the ordering and payment instructions and current lead time.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 10-08-2021 at 09:47 PM. Reason: Shipping cost increase |
03-15-2014, 09:30 PM | #2 |
Re: HD Carrier Bearing Mount
Will this work for the regular 70 c10 U-shaped carrier bearing?
03-16-2014, 12:19 AM | #3 |
60-66 Nut
If you are referring to the HD carrier braring, yes it will work, That is what this mount is made for, the '63-'72 HD carrier bearing.
03-16-2014, 01:29 AM | #4 |
are you still selling these?
03-16-2014, 01:35 AM | #5 |
60-66 Nut
I have only 1 of these right now.
I am hoping to make more, but that depends on the interest in them.
03-16-2014, 01:49 AM | #6 |
Sorry I'm a noob.
Does it line up for this part? for the hole to hole measurement? http://www.oreillyauto.com/site/c/de...upport+bearing |
03-16-2014, 01:57 AM | #7 |
60-66 Nut
Yes it should. My mount is a duplicate of the original mount.
03-16-2014, 02:03 AM | #8 |
sweet! that's what I need
03-16-2014, 11:47 PM | #9 |
60-66 Nut
I'll send you a PM with payment info.
03-18-2014, 12:10 AM | #10 |
I'm definitely interested in one if this is still available.
Doug Old Build Thread - 383/T56 http://www.67-72chevytrucks.com/vboa...d.php?t=540838 Updated Build Thread - Modern Relic - 66 C10 536 Dark Aqua 5.3/4L60E - BTR Stage IV Truck Cam - Vintage Air - Dakota Digital http://67-72chevytrucks.com/vboard/s...d.php?t=778784 |
03-18-2014, 01:06 AM | #11 |
60-66 Nut
This one is sold to 66 C10 383.
I guess I'll see about making up some more.
08-09-2014, 12:48 AM | #12 |
60-66 Nut
I do have more of these available. They are $35.00 plus $5.50 for shipping.
Here are a couple pics of the HD driveshaft for those not familar with how it compares to the light duty driveshaft assembly. The front half: The rear half:
09-09-2014, 10:54 AM | #13 |
Is that rear shaft a slip shaft? Going to have to inspect my C-20 to see if I have the HD bearing in there...
1968 LWB C20 / AC / Wood Bed |
09-09-2014, 08:57 PM | #14 |
Hmmm ok I don't have the HD bearing. I don't see how this bracket would work for me though -- the support bearing hangs down on the backside of the crossmember while this one would mount to the front side -- I'd need new driveshafts to make this work for me, correct?
09-09-2014, 09:37 PM | #15 | |
07-06-2015, 04:46 PM | #16 |
Captain
Do you still make/have any of these brackets? I may need one. Not sure yet if its going to work with my crossmember though. My 3/4 - 1/2 ton conversion is fighting me at every turn. I thought I did all the research before I bought the new drop xmember and coil spring set up, but I did not at that time know about the different carrier bearings and drive shaft combos. Basically if I could find the 1/2 ton HD carrier bearing with the 1.378" ID bearing that would be great and would work perfectly with the parts I already have. But I have found nothing like that. My thought is that I could use your bracket but bent the tabs back down to flat, then drill holes in my xmember. My xmember is flat on the bottom side, unlike the stock one. |
07-06-2015, 10:57 PM | #17 |
60-66 Nut
Yes I still make these carrier bearing mounts as well as all of my other products.
I can weld the mounting tabs on, flat instead of angled to fit the original crossmember. I was not aware of a difference in the HD carrier bearing between the C10 and C20's.
07-07-2015, 12:28 AM | #18 |
60-66 Nut
You might PM or email me the center to center dimension of your carrier bearing mounting bracket. I will check it against my mounting bracket.
07-07-2015, 01:00 AM | #19 | |
I'm going to do some more thinking, but I may take you up on your offer to make a bracket with the tabs welded on flat. I'm trying to avoid drilling into my new powder coated crossmember if at all possible. This is a temporary solution to get the truck mobile. I am moving to Alabama soon and the relo company will only transport the truck running and driving, otherwise it's my responsibility and expense. When I do the engine/trans swap I will obviously have to buy a new driveshaft. |
06-06-2017, 11:21 AM | #20 |
Are these still for sale? I need one ASAP. Thanks,
Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 06-06-2017 at 12:43 PM. |
06-06-2017, 11:39 PM | #21 |
60-66 Nut
All of my products are for sale everyday. I replied to your email earlier today.
06-07-2017, 08:24 AM | #22 |
Payment sent. Thanks John!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
06-08-2017, 12:44 AM | #23 |
60-66 Nut
01-10-2018, 01:12 AM | #24 |
60-66 Nut
I am officially notifying everyone that I will be on vacation from 02-05-18 thru 02-13-18. I will do my best to get all orders built and shipped before I leave, if placed by 01-31-18. Orders placed while I am gone will be built and shipped in order of receipt of payment once I return. Thanks for understanding.
01-10-2018, 08:37 PM | #25 |
Enjoy your time off.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
