05-16-2014, 10:09 AM | #1 |
griffin radiator does not fit its application !
My 66 c-10 is getting a zz-4 gm crate and 200-r4.
I got a griffin 'direct fit' . Its 3 1/8 deep and too thick to fit into stock brackets. Any been there with this problem ? Its a good looking unit. Hate to return it. |
05-16-2014, 11:38 AM | #2 |
Senior Enthusiast
Re: griffin radiator does not fit its application !
I'd call Griffin and see if perhaps you were sent the wrong unit.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
05-16-2014, 11:46 AM | #3 |
There are 2 sizes of stock brackets. You have the radiator thats fits the wide bracket(heavy duty v8). You apparently have the std duty bracket. You just need to track down a wide stock bracket, cuz no one makes them. Or you could fab one up.
05-16-2014, 12:17 PM | #4 |
Actually, I went through the same exact thing recently. Even the V8 rad. brackets do not fit the Griffin. Sucks. I returned mine.
05-16-2014, 12:31 PM | #5 |
I did email griffin and did not get good resolution. Basically was told the radiator was engineered to oem specs.
What vehicles have the HD radiators? thanks |
05-16-2014, 06:05 PM | #6 |
This Thread should help you make it fit. He fabricated some brackets to make it work. Overall, it sounds like he was very pleased with the quality of the Griffin radiator.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
05-16-2014, 06:11 PM | #7 |
It's Better With Nitro
Griffin is a premium radiator (I used Griffins on my last two Super Gas drag car builds). I would've modified or found the wider saddle mounts to use that radiator.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
05-16-2014, 06:43 PM | #8 |
rideblue..... thanks for the reply.... can you say best vehicles to look for HD brackets.....
lugnuts..... perfect solution. thanks. I was thinking this was where this was leading. just bums me that griffin has ignored the buck here and has not addressed this problem yet. paul |
05-17-2014, 08:36 AM | #9 |
My c20 has one. Ill try to get measurements for you.
